11 Replies Latest reply on Dec 16, 2013 6:05 PM by creativejoan0425
    How to break link to cell/table style in a selection
    creativejoan0425 Level 1
      I can break link to cell/table style in a current document, but if I want to do it in a selection, it seem error, anyone would help me to fix it?
      Script A (For Document is ok)
      BreakLinkToCellStyleDocument();
      function BreakLinkToCellStyleDocument(){
          myCells = myDoc.stories.everyItem().tables.everyItem().cells.everyItem().getElements();
          for (var i=0; i<myCells.length; i++){
              myCell = myCells[i];
              myCell.appliedCellStyle = myDoc.cellStyles.item(0), false;
      Script B (For Selection occur error)
      BreakLinkToCellStyleSelection();
      function BreakLinkToCellStyleSelection(){
          var myDoc = app.selection[0];
          myCells = myDoc.tables.everyItem().cells.everyItem().getElements();
        • 1. Re: How to break link to cell/table style in a selection
          Jump_Over Level 5
          app.selection[0] can differ and does not promise a "table" property.
          Your function (script B) should split ways, i.e.:
          BreakLinkToCellStyleSelection ();
          function BreakLinkToCellStyleSelection () {
          var
               mNone = app.activeDocument.cellStyles.item(0),
               mSel = app.selection[0];
          switch(mSel.constructor.name) {
                    case "Cell":
                              mSel.appliedCellStyle = mNone; break;
                    case "Table":
                              mSel.cells.everyItem().appliedCellStyle = mNone;
                              mSel.cells.everyItem().clearCellStyleOverrides();
                              break;
                    default :
                              if (mSel.hasOwnProperty("tables") &&  mSel.tables.length)
                                        mSel.tables.everyItem().cells.everyItem().appliedCellStyle = mNone;
                              break;
          Jarek
          • 2. Re: How to break link to cell/table style in a selection
            I just tested your script, it only can select whole table to do, if I select some cells, there still hv cell style
            從三星手機發送
            • 3. Re: How to break link to cell/table style in a selection
              Jump_Over Level 5
              it keep style or keep format only?
              if format ==> add a line
              mySel.clearCellStyleOverrides();
              to "Cell" case
              Jarek
              • 4. Re: How to break link to cell/table style in a selection
                @Jarek – I tested your code and it worked well.
                Here a variation I tested:
                var
                if(mSel.constructor.name === "Cell" || mSel.constructor.name === "Table") {
                    return;
                if(mSel.hasOwnProperty("baselineShift")){
                    mSel.tables.everyItem().cells.everyItem().clearCellStyleOverrides();
                    return;
                Uwe
                • 5. Re: How to break link to cell/table style in a selection
                  @creativejoan0425 – is a table style involved that includes a cell style?
                  Uwe
                  • 6. Re: How to break link to cell/table style in a selection
                    Marc Autret Level 5
                    Maybe we should offer increasing levels of cleaning, from the minimalist clearCellStyleOverrides(false) to a complete removing of style attributes:
                    var breakLinkToCellStyleSelection = function F(/*0|1|2|3*/LEVEL)
                    // LEVEL 0  => only clear overrides relative to *defined* style attributes
                    // LEVEL 1  => clear all overrides (through root style)
                    // LEVEL 2  => clear all overrides and apply [None]
                    // LEVEL 3  => apply [None] *in depth* (i.e. release all attributes)
                        // Cache
                        F.RE_DOC_SPEC || (F.RE_DOC_SPEC=/\/document\[[^\]]+\]/);
                        var o = app.properties.selection && app.selection[0];
                        // Validation
                        if( !o ) return 0;
                        while( !('cells' in o) )
                            if( 'cells' in o.parent )
                                { o=o.parent; break; }
                            if( ('tables' in o) && o.tables.length )
                                { o=o.tables.everyItem(); break; }
                            return 0;
                        // [None] style
                        var NONE_STYLE = resolve((o.toSpecifier().match(F.RE_DOC_SPEC)||['/'])[0]).
                            cellStyles.itemByName("$ID/[None]");
                        // Process
                        o = o.cells.everyItem();
                        o.clearCellStyleOverrides(!!LEVEL);
                        if( 1 < LEVEL ) o.appliedCellStyle = NONE_STYLE;
                        if( 2 < LEVEL ) o.properties = NONE_STYLE.properties;
                    breakLinkToCellStyleSelection(3); // warning: deep cleaning!
                    Marc
                    • 7. Re: How to break link to cell/table style in a selection
                      Jean-Claude Tremblay User Group Manager
                      Marc,
                      How can we set the Level number in that powerful script?
                      • 8. Re: How to break link to cell/table style in a selection
                        @Jean-Claude – see the last line of the code.
                        There is a number inside the brackets.
                        This is the level number.
                        It's the argument to the function F in line one, where Marc points at four possible values in the comments.
                        In fact there are more values possible, but suggested are 0, 1, 2, 3.
                        You could also work with floating point numbers. They will fall back to the appropriate level.
                        0 … 0.9999… => 0
                        1 … 1.9999… => 1
                        2 … 2.9999… => 2
                        3 …  => 3
                        Very clever! Numbers higher than 3 will not throw an error, but fall back to level 3.
                        The function is modular, new levels higher than 3 or even sublevels (eg. 1.5) could be easily attached as an added if statement in the process-section of the function.
                        One could rewrite the snippet and substitute all names of the function F with breakLinkToCellStyleSelection and call the function like that (maybe it's clear to you now):
                        //Example of calling level 2:
                        breakLinkToCellStyleSelection(2);
                        function breakLinkToCellStyleSelection(/*0|1|2|3*/LEVEL){
                            // Cache
                            breakLinkToCellStyleSelection.RE_DOC_SPEC || (breakLinkToCellStyleSelection.RE_DOC_SPEC=/\/document\[[^\]]+\]/);
                            // Validation
                            if( !o ) return 0;
                                return 0;
                            // [None] style
                            var NONE_STYLE = resolve((o.toSpecifier().match(breakLinkToCellStyleSelection.RE_DOC_SPEC)||['/'])[0]).
                            // Process
                        @Marc – thank you very much for that snippet!
                        Uwe
                        • 9. Re: How to break link to cell/table style in a selection
                          Jump_Over Level 5
                          ... next door opened...
                          thx Marc for sharing
                          Jarek
                          • 10. Re: How to break link to cell/table style in a selection
                            Thank you Uwe! That was obvious... ;-)
                            • 11. Re: How to break link to cell/table style in a selection
                              For cell Selection is work (but can't keep the style setting after break the link), but I also want to break the table style, but error
                              For both Break link to cell/table style, I want to keep the style setting after break the link
                              BreakLinkToTableStyleSelection();
                              function BreakLinkToTableStyleSelection () {
                              var
                                   mNone = app.activeDocument.tableStyles.item(0),
                                  mSel.tables.everyItem().appliedTableStyle = mNone;
                                  return;
                                  return;
                              var
                                  return;
                                  return;
