1. Re: Lighting Effect Question
Chuck Uebele Dec 14, 2013 6:37 AM (in response to ColdForest)Can you post some examples?
3. Re: Lighting Effect Question
Chuck Uebele Dec 14, 2013 7:28 AM (in response to ColdForest)FRom your samples, this looks normal. The lighting effect does apply to the entire layer. You just have to adjust the values to your needs. If you want the color that you appled to be just applied to the spot and the spot to lighting the image, you might want to consider dropping down the ambient light then use a layer blend mode such as screen or lighten to blend the results.
4. Re: Lighting Effect Question
Chuck Uebele Dec 14, 2013 7:36 AM (in response to ColdForest)Exactly how would you like the lighting effect to look?
5. Re: Lighting Effect Question
ColdForest Dec 14, 2013 7:36 AM (in response to Chuck Uebele)Thanks for your comments.
I must be missing something since all of the tutorials/reading I've done on this suggest that the default filter settings will result in a more "narrow" (spotlight) effect (as opposed to what this looks like to me, which seems to be more like an "infinite light" effect - i.e., applied to the whole layer). I thought the default "spot effect" would focus the light more directly??
6. Re: Lighting Effect Question
I'm after a "spotlight" effect (don't konw how to describe this more specifically, but hopefully you know what I mean ).
8. Re: Lighting Effect Question
Chuck Uebele Dec 14, 2013 7:49 AM (in response to ColdForest)I'm not sure if you want the yellow color over the entire image. If not, then set it in top control that says color. If you want the spot to be brighter, increase the intensity of that top control. The yellow color as you have it now mutes everything, especially since you have a negative value for the intensity. You can further control how bright the rest of the image looks by ambience. A value of 100% will give you the full tonal value of your origianl layer. Here's a little sample if putting a reg spot on an image. I don't know it that along the lines that you want.
9. Re: Lighting Effect Question
Chuck Uebele Dec 14, 2013 7:51 AM (in response to ColdForest)Just saw your last post. In that case, you need to drop down the ambience, and if you want the yellow cast over the entire image, boost up the intensity, as well as increase the intensity of the main light (top control).
10. Re: Lighting Effect Question
ColdForest Dec 14, 2013 8:17 AM (in response to Chuck Uebele)Something has got to be wrong with my setup - intensity and ambience don't seem to do anything (meaningful/relevant). I can remove the overall yellow cast by changing colorize to 'white' (along with the color of the top control - to white), but ambience just changes the whole image from dark to light and intensity doesn't do *anything*.
Weird?
11. Re: Lighting Effect Question
Chuck Uebele Dec 14, 2013 9:00 AM (in response to ColdForest)1 person found this helpfulColor control the actual color of the light source, and intensity controls how bright that light source is. The two work with each other in that the darker the color, the less intensity you can get.
Colorize color the entire image, and exposure controls how much of the colorized color affects the light source, so a lower value will lower the light source intensity and make the light more the color of the color selected in the colorized box.
Ambience is also tied to the colorize control. It will adjust the overall brightness on the image based on the color selected. With white, you can bring up the value to see the original image at 100%. With black there is no affect, as there is no "light" to brighten the image.
14. Re: Lighting Effect Question
ColdForest Dec 14, 2013 10:39 PM (in response to Chuck Uebele)Ya, odd - sure would be nice to get this figured out...
Graphics card is AMD Radeon HD6450
Here's the system info:
Adobe Photoshop Version: 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00) x64
Operating System: Windows 7 64-bit
Version: 6.1 Service Pack 1
System architecture: Intel CPU Family:6, Model:10, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 3392 MHz
Built-in memory: 8174 MB
Free memory: 5044 MB
Memory available to Photoshop: 7192 MB
Memory used by Photoshop: 70 %
Image tile size: 1024K
Image cache levels: 4
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
NumGPUs=1
gpu[0].OGLVersion="3.0"
gpu[0].MemoryMB=1024
gpu[0].RectTextureSize=16384
gpu[0].Renderer="AMD Radeon HD 6450"
gpu[0].RendererID=26489
gpu[0].Vendor="ATI Technologies Inc."
gpu[0].VendorID=4098
gpu[0].HasNPOTSupport=1
gpu[0].DriverVersion="8.850.0.0"
gpu[0].Driver="aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64. dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dl l"
gpu[0].DriverDate="20110419000000.000000-000"
gpu[0].CompileProgramGLSL=1
gpu[0].TestFrameBuffer=1
gpu[0].OCLSupported=0
gpu[0].CUDASupported=0
gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.10"
gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[214748 3647]
gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[32]
gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[16384]
gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[16384]
gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[29]
gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
Serial number: 96040573687862543208
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\
Temporary file path: C:\Users\David\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 915.2G, 277.2G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Required\Plug-Ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Plug-ins\
Installed components:
ACE.dll ACE 2013/07/14-12:09:50 79.543790 79.543790
adbeape.dll Adobe APE 2013/02/04-09:52:32 0.1160850 0.1160850
AdobeLinguistic.dll Adobe Linguisitc Library 7.0.0
AdobeOwl.dll Adobe Owl 2013/03/03-12:10:08 5.0.13 79.533484
AdobePDFL.dll PDFL 2013/03/13-12:09:15 79.499517 79.499517
AdobePIP.dll Adobe Product Improvement Program 7.0.0.1786
AdobeXMP.dll Adobe XMP Core 2013/03/13-12:09:15 79.151481 79.151481
AdobeXMPFiles.dll Adobe XMP Files 2013/03/13-12:09:15 79.151481 79.151481
AdobeXMPScript.dll Adobe XMP Script 2013/03/13-12:09:15 79.151481 79.151481
adobe_caps.dll Adobe CAPS 7,0,0,21
AGM.dll AGM 2013/07/14-12:09:50 79.543790 79.543790
ahclient.dll AdobeHelp Dynamic Link Library 1,8,0,31
aif_core.dll AIF 5.0 79.534508
aif_ocl.dll AIF 5.0 79.534508
aif_ogl.dll AIF 5.0 79.534508
amtlib.dll AMTLib (64 Bit) 7.0.0.169 BuildVersion: 7.0; BuildDate: Mon Apr 8 2013 2:31:50) 1.000000
ARE.dll ARE 2013/07/14-12:09:50 79.543790 79.543790
AXE8SharedExpat.dll AXE8SharedExpat 2011/12/16-15:10:49 66.26830 66.26830
AXEDOMCore.dll AXEDOMCore 2011/12/16-15:10:49 66.26830 66.26830
Bib.dll BIB 2013/07/14-12:09:50 79.543790 79.543790
BIBUtils.dll BIBUtils 2013/07/14-12:09:50 79.543790 79.543790
boost_date_time.dll DVA Product 7.0.0
boost_signals.dll DVA Product 7.0.0
boost_system.dll DVA Product 7.0.0
boost_threads.dll DVA Product 7.0.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CIT.dll Adobe CIT 2.1.6.30929 2.1.6.30929
CITThreading.dll Adobe CITThreading 2.1.6.30929 2.1.6.30929
CoolType.dll CoolType 2013/07/14-12:09:50 79.543790 79.543790
dvaaudiodevice.dll DVA Product 7.0.0
dvacore.dll DVA Product 7.0.0
dvamarshal.dll DVA Product 7.0.0
dvamediatypes.dll DVA Product 7.0.0
dvaplayer.dll DVA Product 7.0.0
dvatransport.dll DVA Product 7.0.0
dvaunittesting.dll DVA Product 7.0.0
dynamiclink.dll DVA Product 7.0.0
ExtendScript.dll ExtendScript 2013/03/21-12:10:31 79.535742 79.535742
FileInfo.dll Adobe XMP FileInfo 2013/03/19-12:09:02 79.151561 79.151561
filter_graph.dll AIF 5.0 79.534508
icucnv40.dll International Components for Unicode 2011/11/15-16:30:22 Build gtlib_3.0.16615
icudt40.dll International Components for Unicode 2011/11/15-16:30:22 Build gtlib_3.0.16615
imslib.dll IMSLib DLL 7.0.0.116
JP2KLib.dll JP2KLib 2013/02/19-12:28:44 79.248139 79.248139
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OMP Runtime Library 5.0
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
LogSession.dll LogSession 2.1.2.1785
mediacoreif.dll DVA Product 7.0.0
MPS.dll MPS 2013/03/15-13:25:52 79.535029 79.535029
msvcm80.dll Microsoft® Visual Studio® 2005 8.00.50727.6229
msvcm90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
msvcp100.dll Microsoft® Visual Studio® 2010 10.00.40219.1
msvcp80.dll Microsoft® Visual Studio® 2005 8.00.50727.6229
msvcp90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
msvcr100.dll Microsoft® Visual Studio® 2010 10.00.40219.1
msvcr80.dll Microsoft® Visual Studio® 2005 8.00.50727.6229
msvcr90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
PatchMatch.dll PatchMatch 2013/06/11-12:08:08 79.542390 79.542390
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC CC
Plugin.dll Adobe Photoshop CC CC
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 4.0.1.34
PSArt.dll Adobe Photoshop CC CC
PSViews.dll Adobe Photoshop CC CC
SCCore.dll ScCore 2013/03/21-12:10:31 79.535742 79.535742
ScriptUIFlex.dll ScriptUIFlex 2013/03/21-12:10:31 79.535742 79.535742
svml_dispmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
tbb.dll Intel(R) Threading Building Blocks for Windows 4, 1, 2012, 1003
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 4, 1, 2012, 1003
updaternotifications.dll Adobe Updater Notifications Library 7.0.1.102 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 7.0.1.102
WRServices.dll WRServices Mon Feb 25 2013 16:09:10 Build 0.19078 0.19078
Required plug-ins:
3D Studio 14.1.2 (14.1.2 x001)
Accented Edges 14.1.2
Adaptive Wide Angle 14.1.2
Angled Strokes 14.1.2
Average 14.1.2 (14.1.2 x001)
Bas Relief 14.1.2
BMP 14.1.2
Camera Raw 8.3
Camera Raw Filter 8.3
Chalk & Charcoal 14.1.2
Charcoal 14.1.2
Chrome 14.1.2
Cineon 14.1.2 (14.1.2 x001)
Clouds 14.1.2 (14.1.2 x001)
Collada 14.1.2 (14.1.2 x001)
Color Halftone 14.1.2
Colored Pencil 14.1.2
CompuServe GIF 14.1.2
Conté Crayon 14.1.2
Craquelure 14.1.2
Crop and Straighten Photos 14.1.2 (14.1.2 x001)
Crop and Straighten Photos Filter 14.1.2
Crosshatch 14.1.2
Crystallize 14.1.2
Cutout 14.1.2
Dark Strokes 14.1.2
De-Interlace 14.1.2
Dicom 14.1.2
Difference Clouds 14.1.2 (14.1.2 x001)
Diffuse Glow 14.1.2
Displace 14.1.2
Dry Brush 14.1.2
Eazel Acquire 14.1.2 (14.1.2 x001)
Embed Watermark 4.0
Entropy 14.1.2 (14.1.2 x001)
Extrude 14.1.2
FastCore Routines 14.1.2 (14.1.2 x001)
Fibers 14.1.2
Film Grain 14.1.2
Filter Gallery 14.1.2
Flash 3D 14.1.2 (14.1.2 x001)
Fresco 14.1.2
Glass 14.1.2
Glowing Edges 14.1.2
Google Earth 4 14.1.2 (14.1.2 x001)
Grain 14.1.2
Graphic Pen 14.1.2
Halftone Pattern 14.1.2
HDRMergeUI 14.1.2
IFF Format 14.1.2
Ink Outlines 14.1.2
JPEG 2000 14.1.2
Kurtosis 14.1.2 (14.1.2 x001)
Lens Blur 14.1.2
Lens Correction 14.1.2
Lens Flare 14.1.2
Liquify 14.1.2
Matlab Operation 14.1.2 (14.1.2 x001)
Maximum 14.1.2 (14.1.2 x001)
Mean 14.1.2 (14.1.2 x001)
Measurement Core 14.1.2 (14.1.2 x001)
Median 14.1.2 (14.1.2 x001)
Mezzotint 14.1.2
Minimum 14.1.2 (14.1.2 x001)
MMXCore Routines 14.1.2 (14.1.2 x001)
Mosaic Tiles 14.1.2
Multiprocessor Support 14.1.2 (14.1.2 x001)
Neon Glow 14.1.2
Note Paper 14.1.2
NTSC Colors 14.1.2 (14.1.2 x001)
Ocean Ripple 14.1.2
Oil Paint 14.1.2
OpenEXR 14.1.2
Paint Daubs 14.1.2
Palette Knife 14.1.2
Patchwork 14.1.2
Paths to Illustrator 14.1.2
PCX 14.1.2 (14.1.2 x001)
Photocopy 14.1.2
Photoshop 3D Engine 14.1.2 (14.1.2 x001)
Photoshop Touch 14.0
Picture Package Filter 14.1.2 (14.1.2 x001)
Pinch 14.1.2
Pixar 14.1.2 (14.1.2 x001)
Plaster 14.1.2
Plastic Wrap 14.1.2
PNG 14.1.2
Pointillize 14.1.2
Polar Coordinates 14.1.2
Portable Bit Map 14.1.2 (14.1.2 x001)
Poster Edges 14.1.2
Radial Blur 14.1.2
Radiance 14.1.2 (14.1.2 x001)
Range 14.1.2 (14.1.2 x001)
Read Watermark 4.0
Reticulation 14.1.2
Ripple 14.1.2
Rough Pastels 14.1.2
Save for Web 14.1.2
ScriptingSupport 14.1.2
Shake Reduction 14.1.2
Shear 14.1.2
Skewness 14.1.2 (14.1.2 x001)
Smart Blur 14.1.2
Smudge Stick 14.1.2
Solarize 14.1.2 (14.1.2 x001)
Spatter 14.1.2
Spherize 14.1.2
Sponge 14.1.2
Sprayed Strokes 14.1.2
Stained Glass 14.1.2
Stamp 14.1.2
Standard Deviation 14.1.2 (14.1.2 x001)
STL 14.1.2 (14.1.2 x001)
Sumi-e 14.1.2
Summation 14.1.2 (14.1.2 x001)
Targa 14.1.2
Texturizer 14.1.2
Tiles 14.1.2
Torn Edges 14.1.2
Twirl 14.1.2
Underpainting 14.1.2
Vanishing Point 14.1.2
Variance 14.1.2 (14.1.2 x001)
Variations 14.1.2 (14.1.2 x001)
Water Paper 14.1.2
Watercolor 14.1.2
Wave 14.1.2
Wavefront|OBJ 14.1.2 (14.1.2 x001)
WIA Support 14.1.2 (14.1.2 x001)
Wind 14.1.2
Wireless Bitmap 14.1.2 (14.1.2 x001)
ZigZag 14.1.2
Optional and third party plug-ins: NONE
Plug-ins that failed to load: NONE
Flash:
Mini Bridge
Kuler
Adobe Exchange
Installed TWAIN devices: NONE
15. Re: Lighting Effect Question
Chris CoxDec 14, 2013 11:11 PM (in response to ColdForest)
Your video card driver is over 2 years out of date...
17. Re: Lighting Effect Question
Chuck Uebele Dec 15, 2013 7:17 AM (in response to ColdForest)Great! I had an issue with lighting also with my AMD card, but in my case it was a switchable card that AMD would not update and left that to HP. They never updated the driver. I ended up getting a new comptuer and making sure I didn't have that type of setup!
18. Re: Lighting Effect Question
ColdForest Dec 15, 2013 7:20 AM (in response to Chuck Uebele)Ya, in this case it's interesting that the effect was present after a driver update; I'd be interested in knowing what exactly was fixed (newly available) in the driver that allowed Photoshop to correctly render the effect. I'm partly curious because it sure would have been nice if PS had the ability to detect this (i.e., driver update required/recommended). Moreover, I typically rely on Windows Update to identify these updates, but in this case this never happened...
Cheers.
19. Re: Lighting Effect Question
Chuck Uebele Dec 15, 2013 7:32 AM (in response to ColdForest)Windows updates don't detect driver updates. It would be nice to have some notice. I was getting a completely black screen, and when using 3D the shadows would never show, then it got so the lights wouldn't show.
