11 Replies Latest reply on Apr 29, 2008 7:23 AM by koosei
    System Audio
    koosei
      I want to record audio via my sound card but my Captivate 3 Input Source options shows only Microphone and Line in. System Audio is unavailable. What might be possible causes and what should I do?
        • 1. Re: System Audio
          Hi koosei and welcome to our community
          As I understand it, the ability to record system sounds is largely dependent on the capabilities of your audio hardware. Mine isn't enabled either. I questioned TechSmith support because in Camtasia Studio I could record this way on my desktop PC but not my laptop. And that was the answer given to me. Because I'm seeing the same behavior in Captivate, I am assuming this is the case.
          Cheers... Rick
          • 2. Re: System Audio
            Hi again
            I forgot to add how you might accomplish the goal. You could obtain a small patch cable from somewhere like Radio Shack that would plug from the Speaker out jack to the Microphone in jack. I've done this before as well. Now if you need to blend a Microphone with that, you would need to either obtain a mixing device or something like that. Connect the components to the mixing device, then connect the mixing device to the computer via either Line In or Microphone.
            Just a thought... Rick
            • 3. Re: System Audio
              Hi again
              Sorry to be so chatty here. But your question piqued my curiosity. So I did some Googling to see if there was any sort of utility out there that could help with this. I found one that is totally free that may work. It is called FreeCorder toolbar. You may take a look at it by Clicking here.
              Might be worth trying. Also keep in mind that most of the system sounds exist separately as .WAV files that are accessed when needed. So one way to use them might be to insert something like a Click Box object that doesn't pause and does nothing when clicked. Then attach the audio to that and time as needed. Or you could use a Transparent Caption with no text and do the same thing.
              Cheers... Rick
              • 4. Re: System Audio
                koosei Level 1
                Hi
                thanks for the prompt response. good to know that it was not my laptop that was misbehaving. I will try all the different ways in addition to doing the screen capture of what I talk about in my audio recording. once again thanks
                • 5. Re: System Audio
                  koosei Level 1
                  can you recommend desktop pcs that support systems audio. optiplex GX520 supports systems audio. are there any?
                  • 6. Re: System Audio
                    Level 7
                    Generally speaking, if there is any kind of sound card in the PC then you
                    should be fine. I'd be surprised if you can find many with no sound
                    capability at all.
                    What are you trying to achieve?
                    Steve
                    Adobe Community Expert: eLearning, Mobile and Devices
                    European eLearning Summit - EeLS
                    Adobe-sponsored eLearning conference.
                    http://www.elearningsummit.eu
                    • 7. Re: System Audio
                      koosei Level 1
                      I am trying record slides via system audio feature in Captivate 3.
                      I have pre-recorded and edited my narration with Audition 3 and wanna play it on my pc so that I record the video as it plays on a media player.
                      so far, I am able achieve this on my office optiplex GX520 but not on my desktop pc at home which is hp pentium 4.
                      thanks for the quick response and support.
                      • 8. Re: System Audio
                        Level 7
                        > it
                        What's not working? You don't hear the audio on your home PC? Have you
                        opened your Sound properties and ensure WAVW and other outputs are not
                        muted?
                        Steve
                        • 9. Re: System Audio
                          Level 7
                          > muted?
                          Oops - should be WAVE
                          Steve
                          • 10. Re: System Audio
                            Heya Steve
                            I could be mistaken here, but I think the issue is that when koosei is using Captivate, the ability to record "System Audio" is not an available option. With certain types of sound cards, I don't believe it's supported.
                            Cheers... Rick
                            • 11. Re: System Audio
                              koosei Level 1
                              Steve
                              Thanks; but i think Captiva8r is got my point.
