2 Replies Latest reply on Dec 16, 2013 5:40 AM by wfzen
    set the width of a member
    wfzen Level 1
      I need to put dynamic text into field of a width I define so I can find the height it requires. I can read the width but I can't set the width using the one below.
      member("member name").width = 123
      If I can set widht of the field sprite using sprite(1).width = 123, but it does not actually change the member's width. The text is still aligned based on the width you set in properties.
      Is there a way to change the width of a member?
      wfz
        • 1. Re: set the width of a member
          Sean_Wilson Adobe Community Professional
          So you tried
          sprite(1).member.width = 123
          and it doesn't work?
          What does
          put sprite(1).member.type
          report when executed from your message window with the playhead in the span of the sprite in question?
          • 2. Re: set the width of a member
            wfzen Level 1
            Thank you, Sean.
            Error message:
            sprite(1).member.width = 123 => Script error: Cannot set this properites
            put sprite(1).member.type => #field
            I just found if I use Text member, width is controllable while field member is not controllable. Thanks for the hint. I will change them to text.
