1 Reply Latest reply on Dec 16, 2013 5:23 AM by resdesign
    large "pop-up"
    vimster303909 Level 1
      here's what I want to do:
      I have a map with several locations indicated with a pin circle. Clicking a location pin circle animates a large "pop-up" that covers everything (I have a "close button" that removes the pop-up). The pop-up is a symbol.
      It all works ONLY when the pin circles are in a layer ABOVE the pop-ups >>> which is not good (cirles need to be covered when the pop-up is activated)
      When I put the pop-up in a layer UNDER the pin circles, it all works, but obviously the pin circles are visible and that's not good...
      Can anyone help me with this??
      thanks, j
        • 1. Re: large "pop-up"
          resdesign Adobe Community Professional & MVP
          There are several ways you could do this but my guess is that you could change the z-index of your pins and pop-ups on the click events.
          on circle click
          on popup buttons:
          The value of the z-index depends on where your layers are.
          But not seeing your files, it is hard to say if this would work.
