2 Replies Latest reply on Dec 9, 2007 2:50 AM by BKBK
    Moving ColdFusion DB Connection Data?
    opry-guru
      Hi, am currently using CF 6.1 MX and came across a problem. CF was installed before I started working here on a machine that is now failing. I've built a new server and installed CF successfully. However, on the old server when I log into the administrator settings, the left NAV pane is blank - no links at all which is preventing me from seeing the DATA sources.
      Unfortunately no one here remembers or knows anything about the Data Sources because they were done by a third party years ago. My question is how do I recover or even directly import that data into my new server? I moved the *query.xml file to the new server and restarted the CF server but I don't think it worked.
      Any help is MUCH appreciated - thanks in advance! ~Rich
