2 Replies Latest reply on Dec 16, 2013 7:33 PM by Ramjivk
    Urgent Question:Indesign won't start up
    conabisobafasn
      the program indesign from CS5 Design premium has decided to just stop opening & running. I've re installed it 2x. It won't accept updates. this is ridiculous. Pay a lot for the programs so its not fun when they just stop working.
        • 1. Re: Urgent Question:Indesign won't start up
          Cari Jansen Adobe Community Professional
          • What operating system are you running on?
          • Has anything changed on your system from when it was running?
          • Did you install other software? plug-ins? can you remove these?
          • Have you tried a system reboot?
          Cari
          • 2. Re: Urgent Question:Indesign won't start up
            Ramjivk
            Some of my suggestions
            • If you are using windows OS, you can try opening the application as "Run as Administrator".
            • while installing the Design premium, did you install the full pack or just InDesign. try installing full pack or vise versa.
            • check for the system requirement before installing the software.
            • login to your system as admin and try installing it again.
            • if anything did not work, try installing it in another computer. If it works then the issue could be in your OS. you can format and install the OS again.
            • last chance is contact Adobe support.
            hope it helps.
