0 Replies Latest reply on Dec 6, 2007 5:10 PM by Newsgroup_User
    Flex 3 Drag and Drop slow performance
    Level 7
      I have a scenario where I have 2 trees in a custom component that allows data
      to be dragged from one to the other. In a particular case, I have 2000 nodes
      at a certain level in a tree. When I try to copy 2000 at a single time, the
      application basically freezes. I am currnently using an ArrayCollection as the
      dataprovider. While debugging, I have increased the script execution timout to
      about 60 seconds. It seems to take about 45 seconds to copy 2000 nodes. Each
      node is a lightweight object that simply contains two properties: label and
      data. Obviously 45 seconds is unacceptable. In fact, I wouldn't accept
      anything over a second or two. I'm assuming that internally, flex is firing a
      bunch of events and trying to redraw the tree each time a single item is delete
      from the tree. This would explain the length of time it currently takes. If
      anyone knows how to resolve this, please let me know. Thanks!
