3 Replies Latest reply on Dec 17, 2013 7:49 PM by Mi_D
    How to use the script placemultipagePDF with reduction?
    MarthaR Level 1
      In need to use the script placemultipagePDF, but in need this have a reduction 77%
        • 1. Re: How to use the script placemultipagePDF with reduction?
          @Martha – I do not know that script, but maybe you could use Scott Zanelli's "MultiPageImporter2.5.jsx"-script?
          See:
          http://indesignsecrets.com/zanelli-releases-multipageimporter-for-importing-both-pdf-and-i ndd-files.php
          You could scale to 77% while placing (importing) the PDF pages.
          What exact version of InDesign, what exact version of OS do you use?
          Uwe
          • 2. Re: How to use the script placemultipagePDF with reduction?
            MarthaR Level 1
            I use cs6 and and OS X (10.7.5)
            • 3. Re: How to use the script placemultipagePDF with reduction?
              Mi_D Level 3
              try below code, i modifide sample cone provide adobe as per ur requirement.
              main();
              function main(){
                  //var myCounter = 1;
                  var myDocument = app.documents.item(0);
                  var myPage = myDocument.pages;
                  var myPDFFile = new File("E:\\Work\\Scripting InDesign CS3-4 with JavaScript April 2009.pdf");
                      if((myPDFFile != null)){
                          for (var p=0; myPage.length>p; p++){
                      myPlacePDF(myDocument, myPage[p], myPDFFile);
              function myPlacePDF(myDocument, myPage, myPDFFile){
                  var myPDFPage;
                  app.pdfPlacePreferences.pdfCrop = PDFCrop.cropMedia;
                  var myCounter = 1;
                  var myBreak = false;
                  while(myBreak == false){
                      if(myCounter > 1){
                          myPage = myDocument.pages.add(LocationOptions.after, myPage);
                      app.pdfPlacePreferences.pageNumber = myCounter;
                      myPDFPage = myPage.place(File(myPDFFile), [0,0])[0];
                      myPDFPage.verticalScale =77;
                      myPDFPage.horizontalScale = 77;
                      if(myCounter == 1){
                          var myFirstPage = myPDFPage.pdfAttributes.pageNumber;
                      else{
                          if(myPDFPage.pdfAttributes.pageNumber == myFirstPage){
                              myPage.remove();
                              myBreak = true;
                      myCounter = myCounter + 1;
