29 Replies Latest reply on Feb 13, 2018 12:01 PM by rob day
    Auto save for InDesign documents?
    mlonthebeach Level 1
      Is there a way to set InDesign to automatically save a document every 15 minutes (or some other time period) while it's being worked on?  When we used Quark we had that option, but see nothing like it in InDesign.
        • 1. Re: Auto save for InDesign documents?
          InDesign has an autorecovery feature that records every change and writes it to a recovery file. In the case of an imporper shutdown, ID will automatically attempt to open the recovery file when you restart the application, and is usually successful unless something has corrupted the data it contains (this does happen, but the feature is extremely robust). If succesful you generazlly will not lose more than a few minutes work, if any.
          • 2. Re: Auto save for InDesign documents?
            Daniel Flavin Level 4
            InDesign keeps a "near real time version" mirror copy of all open files.
            You will not close a file without being prompted to Save if changes have been made and if InDesign or the OS crashes, the mirror copy will open upon InDesign's next launch.
            It works well, but could be a few edits short.
            • 3. Re: Auto save for InDesign documents?
              BUT if someone mistakenly responds "no" when asked if they want to save, is there any version saved automatically?  Guessing there's no way to set InDesign to do a regularly scheduled auto save as we did in Quark.
              • 4. Re: Auto save for InDesign documents?
                John Mensinger Adobe Community Professional & MVP
                As already mentioned; there's nothing to set. InDesign's auto-recovery seems like old hat now that I've enjoyed its benefits for years, but it's better at butt-saving than any other recovery feature I've ever seen.
                • 6. Re: Auto save for InDesign documents?
                  Agreed, the auto-recovery feature is great for power outages or improper shutdown. Had someone on my staff 'goof' and lost yesterday's work prompting me to research what we previously had in Quark. Thanks for the input everyone.
                  • 7. Re: Auto save for InDesign documents?
                    I'd ask over in the scripting forum to see if it's possible to set up a script that would run automatically on file open and save a copy periodically, or perhaps better, one that would run on file close. InDesign Scripting
                    • 8. Re: Auto save for InDesign documents?
                      Oh....great idea!!! Thanks!
                      • 9. Re: Auto save for InDesign documents?
                        mosheyri Level 1
                        Here's a thread that discusses this and the script solution:
                        How to set automatic backups to specific folder in InDesign
                        • 10. Re: Auto save for InDesign documents?
                          saholmes99 Level 1
                          This thread is not FALSE!!!!   You will lose hours and hours of work if you wait between saves.   Just happened to me and abode has no support.   This is for the adobe inDesign 11.0.1.105.
                          Total unacceptable that a backup file is not made!!   It is the 21st century.
                          -Scott
                          2 people found this helpful
                          • 11. Re: Auto save for InDesign documents?
                            drasahershoff Level 1
                            Scott is correct.. there is NO working autosave, and cant find a plugin to do it...
                            In my experience 90% crashing documents (and there LOADS of those in InDesign, very flawed) are NOT RECOVERED.
                            This has persisted at least since earliest versions of CC and long before.
                            Hours of work are easily lost if you are immersed enough to forget to save manually.
                            It is REPREHENSIBLE that Adobe is 10 years behind in such a simple software task. AND THEY DONT CARE!!!!
                            • 12. Re: Auto save for InDesign documents?
                              If you experience crashing documents on a regular basis it's much more likely a local system problem (i.e. something on your own computer) than a problem with InDesign itself, though the latest release seems to have a few more bugs than normal. Your assertion that this has been going on since long before CC leads me to think the problem is on your system as there is no history of InDesign instability similar to your description.
                              Other than with documents known to crash other users systems (opened for testing and diagnosis), I don't believe I see more than one crash per year here, and I would say that is pretty typical.
                              • 13. Re: Auto save for InDesign documents?
                                BobLevine MVP & Adobe Community Professional
                                I do not recall ever losing a document due to a crash.
                                I'm not minimizing your experience but I agree with Peter; there's something wrong locally if you're not seeing a recovery. I do see more crashes with recent releases but the recovery always works.
                                • 14. Re: Auto save for InDesign documents?
                                  shawninvancouver Level 2
                                  I just lost about 1 hour of work due to a power outage! That may not seem like a huge loss but it is very discouraging. Especially considering that I've been asking Adobe to add this really simple and highly useful addition to ALL their products for YEARS!
                                  I remember in the 1990's, Word Perfect would also save documents after x number of keystrokes. A brilliant addition that saved countless people from grief.
                                  I know there are a number of Adobe apologists (whom I still respect) who don't understand the need for a flexible auto-backup but that is only because you haven't suffered. Believe me, when it happens to you, I predict that you will change your tune.
                                  Now, my work-around has always been to have the discipline to backup on a regular basis... using filename versioning (i.e. document_1.00, document_1.01, etc.) that way, even with the low possibility of file corruption, it will have several versions to choose from. Additionally, my working folders are also sync'd to the cloud with Dropbox's excellent sync tool. The only problem is that I must actually remember to save on a regular basis! This time I forgot!
                                  Wow... just noticed that EVEN THIS FORUM AUTOSAVES... just looking in the lower left-corner, I see, "Your content was last auto-saved at 12:03 "... perhaps Adobe should consult with the web team that created this forum.
                                  Anyway, enough wasting time... I need to recreate an InDesign document!
                                  • 15. Re: Auto save for InDesign documents?
                                    Buy yourself a UPS (Uninterruptible Power Source), better known as a battery backup. There is no excuse not to have one considering how inexpensive they are. You'll never go down in a power failure.
                                    • 16. Re: Auto save for InDesign documents?
                                      Even in a power failure you would typically lose nothing more than a minute or two of work with a file recovery when you re-open InDesign and I’ll echo Peter’s recommendation. A UPS is a vital piece of equipment. I’ve had one for about 18 years and only replaced the batteries in it twice.
                                      I find the auto recovery better than any auto save I’ve ever seen in any application.
                                      And no, I’m not an apologist; just pointing out the facts. With the autorecovery mechanism there’s simply no reason for an auto save. Even that wouldn’t be fool proof.
                                      • 17. Re: Auto save for InDesign documents?
                                        Peter, I am not going to yell at you out of respect and the fact that you have helped me many times.
                                        But damn it, please stop defending Adobe for a feature that would be extremely useful for all eventualities. Sure, buy a UPS... then what happens when you have an InDesign crash? Or what happens in the event of some unusual computer failure? Even a hard drive failure (it happens!) could prevent loss if Adobe is regularly backing up to a different drive.   (The happy face should help to indicate that I'm not yelling.)
                                        Every other application I use, on a daily basis, offers some form of redundancy... i.e. Madcap Flare, of course my Google Apps and other SAAS tools, my Techsmith apps (Camtasia and Snagit), Oracle tools, Microsoft's products, and a few of my Opensource programs like Notepad ++.
                                        No, it seems to be just Adobe, that can be bothered to add a simple and reasonable feature that could potentially save much grief to many people.
                                        I know what I UPS is... I use them throughout my home... even on my home security. They are inexpensive and "life-saving" when there is a power outage.
                                        But I am at work. It is quite unreasonable to buy a UPS for every workstation in my company... Though I may just buy one for myself (a $70 investment)... it's not the point. Like I already stated, power is just one of many points of failure. A UPS won't protect my InDesign work against a hardware failure.
                                        Why are we even arguing about this? I can't imagine why you think this is an unreasonable option.
                                        Respect,
                                        Shawn
                                        • 18. Re: Auto save for InDesign documents?
                                          No reason?
                                          Good luck with autorecovery when your hard drive fails. Okay, that's an outlier situation but still, I am baffled at your statement because I can name a dozen application that do a much better job of protecting one's work against stupid and/or unintentional faults.
                                          If Adobe's autorecovery is so great that please help me to understand why it failed so very miserably for me...this time and a few other times? Perhaps I didn't configure it?  I checked the recovery folders, searched for any temporary files and nothing existed that was related to the lost content.
                                          My autorecovery folder is:
                                          C:\Users\shawn\AppData\Local\Adobe\InDesign\Version 11.0\en_US\Caches\InDesign Recovery
                                          ...and not a single file had today's date stamp. Ridiculous considering that had worked on the document for over an hour. After some experimenting, it appears as though it doesn't begin saving to this folder until your first document save operation. Maybe that's it?
                                          The document I was working on began at around 10:46 AM and abruptly ended at 11:58 AM... as you can see, there are no records of anything until my first save today, at 1:21 PM.
                                          • 19. Re: Auto save for InDesign documents?
                                            I just discovered another way in while Autorecovery doesn't work.
                                            If you close InDesign on unsaved work, the autorecovery data is inexplicably erased. Earlier in this thread, someone actually complained about this.
                                            Anyhow, I sent in another feature request, here: Feature Request/Bug Report Form
                                            With the following text:
                                            How would you like the feature to work?
                                            In addition to the current autorecovery, allow the end-user to configure, at regular intervals, the ability to save an open document to a selected location (i.e. a specific volume/folder or to a cloud location - i.e. Adobe's storage cloud).
                                            Why is this feature important to you?
                                            Because autorecovery can fail! There are many situations where it is unsuccessful. Some examples: Accidentally answering NO to Save File after an InDesign shutdown request;  a hard drive failure - on the drive where autorecovery currently stores data. In my case -today- nothing was saved in the ..\InDesign Recovery folder, after a power failure.
                                            • 20. Re: Auto save for InDesign documents?
                                              Shawn,
                                              I'm not saying you don't have a point about auto-recovery. I have seen cases where auto-recovery fails, and even current corruption of an open file, but they're rare. I've never felt a need for auto-save, though because I've basically used your new saving strategy for years. A UPS big enough to run a typical workstation and a flat-screen monitor for the few minutes it takes to save and shut down safely can be had for a lot less than $70, and a unit that will run a dozen workstations can probably be found, though it will most likely cost more than multiple smaller units (I bought the backup power that ran the cash registers at a local grocery store that went out of business for the company I worked for once).
                                              If everyone in your office loses an hour of work every time the power goes of, how long do you think it will take to pay for power backup in lost productivity? Your boss should be happy to buy you a UPS if you show him the upside. No, it won't save you from non-power-loss issues, but losing power simply isn't an excuse for losing your work.
                                              • 21. Re: Auto save for InDesign documents?
                                                I have no idea why you don't seem to be saving the recovery data -- I just tested here with a file that had been open and never saved (a test file for something else) since about 10 a.m. (now 7 pm) and it recovered perfectly. I closed that, created anew file, added a text frame and filled it with placeholder text, then force quit, elapsed time perhaps 1 minute. That one recovered with the text frame, but lost the text.
                                                • 22. Re: Auto save for InDesign documents?
                                                  An autosave strategy could easily be scripted via a startup script (scripts in the Scripts>startup scripts folder automatically run at launch), so it would be worth asking in the scripting forum if something already exists. The script referenced in #9 listens for a save and makes a backup copy, so it isn't a timed autosave.
                                                  How complex the script would be depends on what you are trying to do. A simple startup script could save the active document at a timed interval, like this AppleScript, which would save the front document every 60 seconds:
                                                  tell application "Adobe InDesign CC 2014"
                                                      repeat
                                                          tell active document
                                                              save
                                                              delay 60
                                                          end tell
                                                      end repeat
                                                  end tell
                                                  The obvious downside of this simple script is, you might not always want to save—it will effectively disable the revert command. A more robust script could use save a copy to copy iterations into the same directory, but then you would have worry about available disk space, how many iterations get saved, are they all left in the directory on quit, etc.
                                                  • 23. Re: Auto save for InDesign documents?
                                                    Thanks all for your suggestions and even a little bit of empathy.
                                                    IMHO, it wouldn't take much for Adobe to enhance their backup. Like I said before, the Adobe suite is the only application where I have experienced troubles with lost files... I think about less than ten times in about six years... but still, very discouraging when it happens.
                                                    No, I am not going to buy a UPS (LOL)... this is a work computer and I cannot even justify the expense considering that Adobe is only about 25% of my workload and it's the only application where I could lose data as a result of a power outage. All my other applications are a lot smarter or are cloud based.
                                                    Yes, that would be worse.
                                                    Until Adobe actually makes an improvement, I will stick to disciplining myself to perform manual backups on a regular basis and I promise not to complain any more about this. After yesterday's loss, it will be my fault to allow this to happen again!
                                                    Thanks all,
                                                    Shawn
                                                    • 24. Re: Auto save for InDesign documents?
                                                      YOU shouldn't buy the UPS, your company should. Seems like it would be worth the $50 to them not to lose anything due to power failure when it can be prevented that easily.
                                                      • 25. Re: Auto save for InDesign documents?
                                                        No, I am not going to buy a UPS (LOL)... this is a work computer...
                                                        Heh. Odd how you restate the refusal, and then restate the very reason to acquiesce.
                                                        I work on a campus where a single company has over 1100 desktops running 24/7, and every one of them is powered through an individual UPS. And, there is a closet containing at least 100 new-in-box spares. I suppose just seeing that induces a somewhat different perspective with regard to "justifiable expense."
                                                        • 26. Re: Auto save for InDesign documents?
                                                          You are describing comprehensive, incremental backup software like Retrospect and that would not be a trivial addon. You have to consider file sizes with apps like Photoshop and InDesign. I routinely have multiple 1GB+ PS files open at the same time—InDesign files can be 100s of MB each. In that case, timed incremental backups would fill a large drive in no time, or think of the bandwith problems moving 100MB copies to a cloud server.
                                                          • 27. Re: Auto save for InDesign documents?
                                                            Rob.Wood Level 1
                                                            Hello. If you save your InDesign files to Adobe's Cloud Storage it keeps versions, which you can access and restore via the web interface. It's the same with Dropbox, so if you set up a script to save at intervals you can use the cloud restore in place of "revert".
                                                            It also means that if a colleague save changes to a file without making a backup copy you can revert from the cloud.
                                                            • 28. Re: Auto save for InDesign documents?
                                                              lancem25316445 Level 1
                                                              I'm with you on this. Quark, which saved versions, allowed you to go back to a previous version if some mistake or error was made in the document (or your art director changed his mind suddenly and wanted a previous version after all). For example, I was working on a document and wanted to make a serious change to see how it looked. I saved the document then resaved it as something else (V2).
                                                              The original document reverted to the last saved state PREVIOUSLY, loosing 4 hours of work (Another fabulous Quark feature was auto-save,,,something also missing from InDesign)
                                                              The V2 document, without any of the 4 hours of work in it wouldn't undo from the save point.
                                                              In Quark, it would simply be a matter of closing the documents and opening the last revision prior to the save (you could set this as a default to save up to 10 versions) I can assure you, this is a VALUABLE feature and has saved me over the years. As a new InDesign user i find lack of version saves a reprehensible omission.
                                                              • 29. Re: Auto save for InDesign documents?
        See Rob.Wood's #27—it can be done with Adobe's cloud service. Drobbox will also do it as long as you work in your Dropbox root folder. If you don't want to use a cloud service it can also be scripted.
        This layout is in my user folder's Creative Cloud Files folder, so if want to retrieve an incremental backup it's just a matter of clicking view on web where I would have the option of restoring a version
