6 Replies Latest reply: Dec 18, 2013 12:12 PM by NorfolkPete RSS
    Reduce Rendering Time
    NorfolkPete Community Member
      Hi there,
      New to Pro and getting used to all it can do however one thing that is causing an issue is rendering.
      A 3 minute clip that has a few smaller clips added to it with a few tweaks is taking 12 minutes to render.
      My thought is Pro is rendering the full sized video as it was recorded and I am editing at this size, when done I'll be exporting to Vimeo at 1920 x 1080.
      Maybe I ask this out of lack of knowledge but is there a way I can reduce the size now, at the working & edit stage so the video is smaller and then should be quicker to render.
      Just asking as in my head this seems logical however as with many things I guess this may not be the case
      Any thoughts on this would be great.
      Regards, Pete
        • 1. Re: Reduce Rendering Time
          Peru Bob Community Member
          What effects and/or transitions are applied?  Are any third party effects or transitions?
          What is your system specs and hard drive setup?
          • 2. Re: Reduce Rendering Time
            John T Smith CommunityMVP
            Information about your computer and what you are editing would be good... PPro Information FAQ http://forums.adobe.com/message/4200840
            • 3. Re: Reduce Rendering Time
              Mark Mapes Employee Hosts
              You're correct, Pete. The settings you're looking for are the sequence's Preview File Format Height and Width. When you create a new sequence, those settings are on the Settings tab. Starting with CC7.1, you can change this setting for existing sequences by selecting a sequence and going Sequence>Sequence Setting...
              • 4. Re: Reduce Rendering Time
                SAFEHARBOR11 Community Member
                Hi Pete,
                When you say "12 minutes to render", do you mean exporting to Vimeo using Media Encoder, or rendering red timeline bar to green?
                I typically do NOT render the timeline, as long as playback is smooth enough for me to see the results of my edits and effects. I'll leave segments red, as stuff all gets rendered when exporting anyway, so why do it twice? On that subject, if you render timeline to green, and in AME check the box for "Use Previews", that might save a little time by not re-rendering the actual effects, but that preview file still needs to be transcoded to the final output format so is still being "rendered" twice. Which begs the question, how good is the "Preview" codec being used and do you really want that extra generation of quality loss? I never use previews and that means that the final export format is rendered directly from the camera-original clips.
                Hope this makes sense. As mentioned in another posting, if you can share your system specs, perhaps we can find a way for you to speed up the renders. Are you using Mercury GPU Acceleration? Makes a world of difference in performance. Sometimes just bumping up the RAM can help a lot also.
                Jeff Pulera
                Safe Harbor Computers
                • 5. Re: Reduce Rendering Time
                  Hi Mark,
                  Thank you. Now I know what to look for I found a few Videos mentioning the same issue and how to remedy this.
                  I went into Sequence > Sequence Settings and changed the Video Previews size by half.
                  This has certainly helped however I certainly need to upgrade the Ram on my PC also.
                  Never had such issues using Elements however while trailing Pro this is all part of trying something new.
                  Thanks you. Pete
                  • 6. Re: Reduce Rendering Time
                    Hi Jeff,
                    It was rendering the edits and effects - red line to green as you mentioned.
                    Sure I have got round the fact that rendering as little as possible is best until it become necessary and viewing at 1/2 rather than full.
                    I also went into Sequence > Sequence Settings and changed the Video Previews size by half. This again helped.
                    On greater inspection I need to double the Ram I have on my PC, didn't have any issues while using Elements however I have been trailing Pro for a few days now and these issues are cropping up.
                    Exporting the finished bit of video takes a while as does uploading to Vimeo however that isn't an issue as I just leave the PC doing this, it was sitting about waiting for the effects and changes to render to green that was getting frustrating today
                    Thanks for your advice. Much appreciated
                    Regards, Pete
