• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How do you set specific duration for a layer in After Effects cc?
New Here ,
Dec 18, 2013 Dec 18, 2013
This seems like an incredibly basic thing: but how do I type in the duration of a layer in After Effects cc!? (Just as you would type in the duration of a clip in premiere) the only way I can do this is to manually drag the endpoints. This is driving me crazy. Please help!!
TOPICS
How to
Views
87.4K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Jun 17, 2016 Jun 17, 2016
Ctrl click where it says "Source Name" at the top of your list of layers. Go to Columns > Duration. You should now see a new column at the right of your layers, with the duration of each listed in blue. Click on the Duration time for the layer in question and a Time Stretch dialog box will appear. You can set the New Duration in this box, in a similar way to the method you described in Premiere Pro. It's not that easy to find, but very useful – especially when cutting to music created electronic
Votes
Translate
Translate
LEGEND ,
Short of enabling time-stretchin and inputting a fixed value that's just how it works. The bars always represent the full layer duration and you have to trim. You can set in and out points using shortcuts ([ and ] on Englisch versions) or split the layer to facilitate the process.
Mylenium
Votes
Translate
Translate
Report
Report
New Here ,
Thank you for trying to help me : )
So how would you input a fixed value... I just have vector shapes on each layer, so as a basic example could I set : square: 3 seconds, then circle 4 seconds etc
If not possible, why wouldnt people want that level of accuracy when animating, especially when working to music at a specific duration?
Thanks again!
Votes
Translate
Translate
Report
Report
LEGEND ,
...why wouldnt people want that level of accuracy when animating, especially when working to music at a specific duration?
Because often people are animating to words or beats in the music.  Music is rarely performed with a computer-precise beat and tempo.  Musicians aren't robots: they swing the beat sometimes.  They use rubato.  They change tempo.  They change time signatures.  As a result, you have to FIND those words and beats.  It's not a situation where you can say, "There!  I've found the duration of one beat!  Now it's easy to find the rest of them!"
If you try it, you will be very disappointed.
Try finding the precise end of a piece of music that fades or ends on a big chord with a ring-out.  You'll see that it's trial-and-error: what's the point where it becomes inaudible?  It depends on how high your speakers are turned up.  You might have them way up, you set an end point for the layer, and then you do a RAM Preview at a more reasonable volume.  You might say, "Hey!  The music ends before the layer ends!"...  but you KNOW you set the layer's out point when the audio file goes silent.
AE has layer markers that can be used on an audio layer to mark beats, words, etc. They come in very handy.
I guess it comes down to this: because AE can do so much different stuff, there are very few automated procedures.  Oh, Adobe tries with effects that convert audio levels to keyframes, but they're not 100% reliable... especially on something like a capella choral works.  For true accuracy, you need  find the timings yourself.
If you want something simpler, try a different application. But be prepared for lower level of accuracy.
Votes
Translate
Translate
Report
Report
New Here ,
Cheers Dave
Votes
Translate
Translate
Report
Report
LEGEND ,
It depends.  There is no one set solution.
AE defaults to making the duration of STILL IMAGE LAYERS the same length as the composition, and video clips at the length of the clip.
There are a few ways to change the in & out points of any layer.  The easiest may be this:  go to the point in the comp where you want to set such a point.  Highlight the layer.  Hit alt-[ for an in-point or alt-] for an out point.  On a Mac, the correspoinding keystroke combos are opt-[ and opt].
And if you're asking such a basic question, you really, Really, REALLY need to spend a lot of quality time here.  Otherwise you'll get hopelessly lost.  AE's very powerful, and as a result, it isn't very intuitive.  If you blow off the basics, you won't get anywhere.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 15, 2016 Nov 15, 2016
Very helpful! Thanks!
Votes
Translate
Translate
Report
Report
Dec 14, 2020 Dec 14, 2020
Is setting the out point suppost to destroy the in point and vice versa? Because that is what is happening for me.
Votes
Translate
Translate
Report
Report
Explorer ,
Mar 20, 2015 Mar 20, 2015
It's probably not the same as in premiere but this might be of some help.
You can type where you want the playhead to go, by clicking into the gold timecode on the upper left of the keyframing/layer panel; from that point, you can set the start or end point of your layer by typing: option + [  for start or option + ] for end.
Also if you hold shift while you drag in the timeline, elements will snap together. It'll also snap to any markers you place. shift + 1, 2, 3 ,4, 5, 6, 7, 8, 9, 0.
If you can't see the timecode, drag/expand the panel to become larger.
Votes
Translate
Translate
Report
Report
Ctrl click where it says "Source Name" at the top of your list of layers. Go to Columns > Duration. You should now see a new column at the right of your layers, with the duration of each listed in blue. Click on the Duration time for the layer in question and a Time Stretch dialog box will appear. You can set the New Duration in this box, in a similar way to the method you described in Premiere Pro. It's not that easy to find, but very useful – especially when cutting to music created electronically with a fixed tempo. Hope this helps!
Votes
Translate
Translate
Report
Report
Dec 13, 2016 Dec 13, 2016
May also read: "Layer Name". Click it and it will change to "Source Name" as Williams says, but CTRL click brings up the menu regardless, exposing "Columns" option.
Votes
Translate
Translate
Report
Report
New Here ,
Jan 07, 2021 Jan 07, 2021
I have figured out a sort of shortcut. Say, I have a 5 minute main comp. And I want to trim my 1 hour video, that is in its own precomp, to only show 22:00-23:00. (I dont want to shorten the precomp becuase I want to use it in other places too) It would be a pain to slide the video over 6+ times and cut it in the time line with the mouse. So I set the first frame of the video comp to 0:00. Then Ctrl click where it says "Source Name" at the top of your list of layers. Go to Columns > In. Then set the time to "-22:00". This will slide the video over so 22:00 is aligned with 0:00. Then I just have to trim the out side manually, unfortuntly. I wish there was a way to enter the in and out times then just put the video where I want. But I havent figured it out yet.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 18, 2021 Nov 18, 2021
LATEST
I also want to share about the problem I met.
Whenever I drag a file into timeline, the duration will equal to the length of compsitoin. So I adjusted the number in preferences to make the layer can stay specific duration.
The setting path is: Edit > Preferences > Import > Still Footage. Select the second option and change the duration to what you like.
Hope this would help the others who might facing the same problem.
Votes
Translate
Translate
Report
Report
