7 Replies Latest reply on Dec 19, 2013 3:40 PM by xbizkoot
    How can I get Adobe Edge Animate to not hang after every mouse click?
    xbizkoot
      Everytime i open Adobe Edge Animate, it takes a good minute or too to stop the spinning ball. Then after every mouse click, it spins for another couple of minutes, and so on.
      I have tried creating the launchd.conf file with the proxy information, I have uninstalled and installed numerous times. I am working from CC with a Mac Book Pro Retina, 15-inch, Early 2013 OSX 10.8.5.
      I am having no other issues with any of my other applications and them being responsive.
      Ideas?
        • 1. Re: How can I get Adobe Edge Animate to not hang after every mouse click?
          elainecc Adobe Employee
          Hi, xbizkoot-
          It definitely sounds like you're experiencing the problem with the firewall as per this kb.  It sounds like you've already tried the launchd.conf workaround, but can you double check to make sure you have the correct settings?  Did rebooting after changing the launchd.conf help any?
          http://helpx.adobe.com/edge-animate/kb/edge-animate-proxy-issues.html
          It would also help if you could get a crash log.  While the spinning ball is running, you can just kill the process by pressing Cmd-Option-Escape and selecting Animate to Force Quit.  That should get you a crash log we can use to help you diagnose the issue.
          -Elaine
          • 2. Re: How can I get Adobe Edge Animate to not hang after every mouse click?
            xbizkoot Level 1
            Thanks Elaine, I will send you the report
            • 3. Re: How can I get Adobe Edge Animate to not hang after every mouse click?
              xbizkoot Level 1
              Hi Elaine,
              Here is the result after I launch EA and then force quit.
              Please forgive the length.
              Date/Time:       2013-12-19 10:58:59 -0800
              OS Version:      10.8.5 (Build 12F45)
              Architecture:    x86_64
              Report Version:  11
              Command:         Edge Animate
              Path:            /Applications/Adobe Edge Animate CC/Adobe Edge Animate.app/Contents/MacOS/Adobe Edge Animate
              Version:         2.0.1 (2.0.1.0)
              Parent:          launchd [126]
              PID:             562
              Event:           hang
              Duration:        0.99s
              Steps:           10 (100ms sampling interval)
              Hardware model:  MacBookPro10,1
              Active cpus:     8
              Free pages:      2261828 pages (-2865)
              Pageins:         5 pages
              Pageouts:        0 pages
              Process:         Adobe Edge Animate [562]
              Architecture:    i386
              UID:             501
              Task size:       14168 pages
                Thread 0x87d5b    priority 58
                10 start + 53 (Adobe Edge Animate) [0x2f65]
                  10 main + 1416 (Adobe Edge Animate) [0x43fe8]
                    10 exo::app::OS_AppBase::RunEventLoop() + 67 (exo) [0x121ba13]
                      10 -[NSApplication run] + 855 (AppKit) [0x902af5cc]
                        10 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 119 (AppKit) [0x902b916c]
                          10 _DPSNextEvent + 724 (AppKit) [0x902b993a]
                            10 BlockUntilNextEventMatchingListInMode + 88 (HIToolbox) [0x9185fb44]
                              10 ReceiveNextEventCommon + 162 (HIToolbox) [0x9185fbf5]
                                10 RunCurrentEventLoopInMode + 242 (HIToolbox) [0x9185ff5a]
                                  10 CFRunLoopRunInMode + 123 (CoreFoundation) [0x9457be8b]
                                    10 CFRunLoopRunSpecific + 378 (CoreFoundation) [0x9457c01a]
                                      10 __CFRunLoopRun + 1842 (CoreFoundation) [0x9457cbb2]
                                        10 __CFRunLoopDoTimer + 709 (CoreFoundation) [0x94597da5]
                                          10 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 22 (CoreFoundation) [0x94598406]
                                            10 __NSFireTimer + 117 (Foundation) [0x91d319b4]
                                              10 -[ExoMacApplication idle:] + 134 (exo) [0x121cc36]
                                                10 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 121 (dvacore) [0x2aec69]
                                                  10 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 125 (dvacore) [0x2ad12d]
                                                    10 helium::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0<int>) + 65 (Adobe Edge Animate) [0x2d2a1]
                                                      10 boost::detail::function::function_obj_invoker0<boost::_bi::bind_t<int, int (*)(boost::function0<void>*, void*), boost::_bi::list2<boost::_bi::value<boost::function0<void>*>, boost::_bi::value<void*> > >, int>::invoke(boost::detail::function::function_buffer&) + 24 (dvacore) [0x2ad6d8]
                                                        10 int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 66 (dvacore) [0x2ad0a2]
                                                          10 boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf0<void, exo::app::AppBase>, boost::_bi::list1<boost::_bi::value<exo::app::OS_AppBase*> > >, void>::invoke(boost::detail::function::function_buffer&) + 32 (exo) [0x121ea00]
                                                            10 helium::App::DoIdle() + 51 (Adobe Edge Animate) [0x1eca3]
                                                              10 helium::HeliumModel::DoIdle(lua_State*) + 74 (Adobe Edge Animate) [0x2f6ba]
        10 lua_pcall + 528 (AgKernel) [0x20e6700]
        10 luaD_pcall(lua_State*, void (*)(lua_State*, void*), void*, int, int) + 100 (AgKernel) [0x20f22e4]
        10 AgExceptionsPrivate_runProtectedCall + 38 (AgKernel) [0x20e0396]
        10 f_call(lua_State*, void*) + 33 (AgKernel) [0x20e6741]
        10 luaD_call(lua_State*, lua_TValue*, int) + 119 (AgKernel) [0x20f1fc7]
        10 luaV_execute(lua_State*, int) + 8576 (AgKernel) [0x21080a0]
        10 luaD_precall(lua_State*, lua_TValue*, int) + 1430 (AgKernel) [0x20f1e36]
        10 (anonymous namespace)::lua_reallyPCall(lua_State*) + 74 (Adobe Edge Animate) [0x37c6a]
        10 luaD_call(lua_State*, lua_TValue*, int) + 99 (AgKernel) [0x20f1fb3]
        10 l_easy_perform + 372 (lua_curl) [0x278e944]
        10 Curl_do_perform + 190 (lua_curl) [0x27bf94e]
        10 Curl_async_resolved + 49 (lua_curl) [0x27a2171]
        10 Curl_setup_conn + 423 (lua_curl) [0x27c3db7]
        10 Curl_connecthost + 388 (lua_curl) [0x2790d34]
        10 singleipconnect + 3060 (lua_curl) [0x27919f4]
        10 __select + 10 (libsystem_kernel.dylib) [0x988e9be6]
        *10 ??? (mach_kernel + 3613728) [0xffffff8000572420]
                Thread 0x87d76    DispatchQueue 1701273966 priority 49
                10 _dispatch_mgr_thread + 53 (libdispatch.dylib) [0x9a4887a9]
                  10 kevent + 10 (libsystem_kernel.dylib) [0x988ea9ae]
                   *10 ??? (mach_kernel + 3504704) [0xffffff8000557a40]
                Thread 0x87d95    priority 47
                10 thread_start + 34 (libsystem_c.dylib) [0x95cbfdce]
                  10 _pthread_start + 344 (libsystem_c.dylib) [0x95cd55b7]
                    10 ??? (libcef.dylib + 462847) [0x298ffff]
                      10 ??? (libcef.dylib + 478252) [0x2993c2c]
                        10 ??? (libcef.dylib + 478113) [0x2993ba1]
                          10 ??? (libcef.dylib + 348157) [0x2973ffd]
                            10 ??? (libcef.dylib + 350271) [0x297483f]
                              10 ??? (libcef.dylib + 366123) [0x297862b]
                                10 ??? (libcef.dylib + 452498) [0x298d792]
                                  10 ??? (libcef.dylib + 452891) [0x298d91b]
                                    10 ??? (libcef.dylib + 449816) [0x298cd18]
                                      10 pthread_cond_wait$UNIX2003 + 71 (libsystem_c.dylib) [0x95d60089]
                                        10 __psynch_cvwait + 10 (libsystem_kernel.dylib) [0x988e98e2]
                                         *10 psynch_cvcontinue + 0 (mach_kernel) [0xffffff80005bdcb0]
                Thread 0x87d96    priority 47
                    10 ??? (libcef.dylib + 12005589) [0x34920d5]
                      10 ??? (libcef.dylib + 12007769) [0x3492959]
                        10 ??? (libcef.dylib + 11169436) [0x33c5e9c]
                          10 semaphore_wait_trap + 10 (libsystem_kernel.dylib) [0x988e780a]
                           *10 semaphore_wait_continue + 0 (mach_kernel) [0xffffff8000234050]
                Thread 0x87d97    priority 47
                              10 ??? (libcef.dylib + 237084) [0x2958e1c]
                                10 ??? (libcef.dylib + 237855) [0x295911f]
                                  10 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 278 (Foundation) [0x91d5bbb6]
                                        10 __CFRunLoopRun + 1247 (CoreFoundation) [0x9457c95f]
                                          10 __CFRunLoopServiceMachPort + 185 (CoreFoundation) [0x94576f79]
                                            10 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x988e77ce]
                                             *10 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                Thread 0x87d99    priority 47
                              10 ??? (libcef.dylib + 233201) [0x2957ef1]
                                10 ??? (libcef.dylib + 7644990) [0x306973e]
                Thread 0x87d9a    priority 47
                Thread 0x87d9b    priority 47
                              10 ??? (libcef.dylib + 233427) [0x2957fd3]
                Thread 0x87d9d    priority 47
                Thread 0x87d9e    priority 47
                      10 ??? (libcef.dylib + 485569) [0x29958c1]
                        10 ??? (libcef.dylib + 484173) [0x299534d]
                          10 ??? (libcef.dylib + 450318) [0x298cf0e]
                            10 pthread_cond_timedwait$UNIX2003 + 70 (libsystem_c.dylib) [0x95d600d4]
                Thread 0x87d9f    priority 47
                Thread 0x87da0    priority 47
                Thread 0x87da5    priority 47
                Thread 0x87da6    priority 47
                    10 worker_thread + 572 (AgKernel) [0x210c7bc]
                Thread 0x87da7    priority 47
                Thread 0x87da8    priority 47
                Thread 0x87da9    priority 47
                Thread 0x87daa    priority 47
                Thread 0x87dab    priority 47
                Thread 0x87dac    priority 47
                Thread 0x87dad    priority 47
                Thread 0x87dae    priority 47
                Thread 0x87daf    priority 47
                Thread 0x87db0    priority 47
                Thread 0x87db1    priority 47
                Thread 0x87db2    priority 47
                Thread 0x87db3    priority 47
                Thread 0x87db4    priority 47
                Thread 0x87db5    priority 47
                Thread 0x87db6    priority 47
                Thread 0x87db7    priority 47
                Thread 0x87db8    priority 47
                Thread 0x87db9    priority 47
                Thread 0x88065    priority 47
                10 start_wqthread + 30 (libsystem_c.dylib) [0x95cbfdaa]
                  10 _pthread_wqthread + 448 (libsystem_c.dylib) [0x95cd7e79]
                    10 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x988ea0ee]
                     *10 ??? (mach_kernel + 3943920) [0xffffff80005c2df0]
                Binary Images:
                            0x1000 -            0xa1feb  com.adobe.Adobe Edge Animate.application 2.0.1 (2.0.1.0) <E590A148-E8A1-3D6E-8821-59283A5688EA> /Applications/Adobe Edge Animate CC/Adobe Edge Animate.app/Contents/MacOS/Adobe Edge Animate
                          0x287000 -           0x4caff3  com.adobe.dvacore.framework 2.0.1 (2.0.1.0) <243522F4-0213-31FD-A59E-5B570B5C4857> /Applications/Adobe Edge Animate CC/Adobe Edge Animate.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                         0x1214000 -          0x12d0ff3  com.adobe.exo.framework 2.0.1 (2.0.1.0) <20637074-F63B-3C36-9BD6-E068457BB0E1> /Applications/Adobe Edge Animate CC/Adobe Edge Animate.app/Contents/Frameworks/exo.framework/Versions/A/exo
                         0x20d2000 -          0x2120ff7  com.adobe.AgKernel.framework 2.0.1 (2.0.1.0) <84FDB3F5-C002-3132-9E35-DCFE5A6BC866> /Applications/Adobe Edge Animate CC/Adobe Edge Animate.app/Contents/Frameworks/AgKernel.framework/Versions/A/AgKernel
                         0x278b000 -          0x27dbfff  com.adobe.lua_curl.framework 2.0.1 (2.0.1.0) <E7A8C024-7B62-3F73-B9EF-9E45FDD9717D> /Applications/Adobe Edge Animate CC/Adobe Edge Animate.app/Contents/Frameworks/lua_curl.framework/Versions/A/lua_curl
                         0x291f000 -          0x4c99fe3  libcef.dylib <74228A31-D67B-3F9E-8407-2D3AF01046CD> /Applications/Adobe Edge Animate CC/Adobe Edge Animate.app/Contents/Frameworks/dvawebview.framework/Versions/A/cef/libcef.dylib
                        0x90156000 -         0x90d12ff3  com.apple.AppKit 6.8 (1187.40) <94E92235-7AD9-37EF-9B7C-B79074762370> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                        0x91808000 -         0x91bebfff  com.apple.HIToolbox 2.0 <ECC3F04F-C4B7-35BF-B10E-183B749DAB92> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                        0x91cb8000 -         0x91fd8ff3  com.apple.Foundation 6.8 (945.18) <BDC56A93-45C5-3459-B307-65A1CCE702C5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                        0x94545000 -         0x9472dffb  com.apple.CoreFoundation 6.8 (744.19) <DDD3AA21-5B5F-3D8F-B137-AD95FCA89064> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                        0x95cbf000 -         0x95d7cffb  libsystem_c.dylib <A5C0B70C-5F14-3BF8-AA5B-B22E7B12A4AE> /usr/lib/system/libsystem_c.dylib
                        0x988d5000 -         0x988efffc  libsystem_kernel.dylib <9B50E922-DCEA-3066-A9B2-613A6D2C5C69> /usr/lib/system/libsystem_kernel.dylib
                        0x9a484000 -         0x9a496ff7  libdispatch.dylib <86EF7D45-2D97-3465-A449-95038AE5DABA> /usr/lib/system/libdispatch.dylib
              *0xffffff8000200000 - 0xffffff8000741d0c  mach_kernel <EA38B02E-2B88-309F-BA68-1DE29F605DD8> /mach_kernel
              Process:         accountsd [174]
              Path:            /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
              UID:             501
              Sudden Term:     Clean (allows idle exit)
              Task size:       1449 pages (+3)
                Thread 0x708      DispatchQueue 1          priority 29
                10 start + 1 (libdyld.dylib) [0x7fff8c95c7e1]
                  10 ??? (accountsd + 3048) [0x10b105be8]
                    10 CFRunLoopRunSpecific + 290 (CoreFoundation) [0x7fff945250e2]
                      10 __CFRunLoopRun + 1078 (CoreFoundation) [0x7fff94525916]
                        10 __CFRunLoopServiceMachPort + 195 (CoreFoundation) [0x7fff94520233]
                          10 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff8a252686]
                Thread 0x72e      DispatchQueue 2          priority 33
                10 _dispatch_mgr_thread + 54 (libdispatch.dylib) [0x7fff926179ee]
                  10 kevent + 10 (libsystem_kernel.dylib) [0x7fff8a254d16]
                Thread 0x8828d    priority 31
                4 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8d5ba191]
                  4 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8d5cfce3]
                    4 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8a2546d6]
                     *4 ??? (mach_kernel + 3943920) [0xffffff80005c2df0]
                Binary Images:
                       0x10b105000 -        0x10b105fff  accountsd <0982A50A-159D-3E63-A2EC-6447F3706436> /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
                    0x7fff8a242000 -     0x7fff8a25dff7  libsystem_kernel.dylib <4B7993C3-F62D-3AC1-AF92-414A0D6EED5E> /usr/lib/system/libsystem_kernel.dylib
                    0x7fff8c95a000 -     0x7fff8c95dff7  libdyld.dylib <F59367C9-C110-382B-A695-9035A6DD387E> /usr/lib/system/libdyld.dylib
                    0x7fff8d5b9000 -     0x7fff8d685ff7  libsystem_c.dylib <543B05AE-CFA5-3EFE-8E58-77225411BA6B> /usr/lib/system/libsystem_c.dylib
                    0x7fff92613000 -     0x7fff92628ff7  libdispatch.dylib <D26996BF-FC57-39EB-8829-F63585561E09> /usr/lib/system/libdispatch.dylib
                    0x7fff944f0000 -     0x7fff946daff7  com.apple.CoreFoundation 6.8 (744.19) <0F7403CA-2CB8-3D0A-992B-679701DF27CA> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
              Process:         Adobe Photoshop CC [351]
              Path:            /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/MacOS/Adobe Photoshop CC
              UID:             501
              Task size:       330121 pages
              CPU Time:        0.008s
              Process:         Adobe QT32 Server [445]
              Path:            /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Adobe QT32 Server.app/Contents/MacOS/Adobe QT32 Server
              Architecture:    i386
              UID:             501
              Task size:       3791 pages
              Process:         AdobeCrashDaemon [354]
              Path:            /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app/Con tents/MacOS/AdobeCrashDaemon
              Parent:          Adobe Photoshop CC [351]
              UID:             501
              Task size:       1073 pages
              CPU Time:        0.001s
              Process:         AdobeCrashDaemon [443]
              Path:            /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app/Con tents/MacOS/AdobeCrashDaemon
              Parent:          After Effects [441]
              UID:             501
              Task size:       1066 pages
              Process:         AdobeCrashDaemon [564]
              Path:            /Applications/Adobe Edge Animate CC/Adobe Edge Animate.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.ap p/Contents/MacOS/AdobeCrashDaemon
              Parent:          Adobe Edge Animate [562]
              UID:             501
              Task size:       1045 pages
              Process:         After Effects [441]
              Path:            /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/MacOS/After Effects
              UID:             501
              Task size:       59625 pages
              CPU Time:        0.013s
              Process:         Alerts Daemon [252]
              Path:            /Applications/Microsoft Office 2011/*/Alerts Daemon.app/Contents/MacOS/Alerts Daemon
              Architecture:    i386
              UID:             501
              Task size:       2123 pages
              Process:         appleeventsd [63]
              Path:            /System/Library/CoreServices/appleeventsd
              Parent:          launchd [1]
              UID:             71
              Sudden Term:     Dirty (allows idle exit)
              Task size:       893 pages
                Thread 0x30b      DispatchQueue 2          priority 33
                Thread 0x30c      DispatchQueue 7          priority 31
                10 _dispatch_sig_thread + 45 (libdispatch.dylib) [0x7fff92614d85]
                  10 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib) [0x7fff8a254566]
                Binary Images:
                       0x10873a000 -        0x10873afff  appleeventsd <33899092-67A8-3A39-A63C-27BAC6C22174> /System/Library/CoreServices/appleeventsd
              Process:         AppleIDAuthAgent [159]
              Path:            /System/Library/CoreServices/AppleIDAuthAgent
              UID:             501
              Task size:       586 pages
                Thread 0x696      DispatchQueue 2          priority 33
                Thread 0x699      DispatchQueue 7          priority 31
                Thread 0xd1a      DispatchQueue 16         priority 31
                10 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8d5ba191]
                  10 _pthread_wqthread + 404 (libsystem_c.dylib) [0x7fff8d5cfcdb]
                    10 _dispatch_worker_thread2 + 249 (libdispatch.dylib) [0x7fff926161c3]
                      10 _dispatch_queue_invoke + 52 (libdispatch.dylib) [0x7fff926162f1]
                        10 _dispatch_queue_drain + 180 (libdispatch.dylib) [0x7fff92616448]
                          10 _dispatch_queue_invoke + 72 (libdispatch.dylib) [0x7fff92616305]
                            10 _dispatch_source_invoke + 691 (libdispatch.dylib) [0x7fff9261729b]
                              10 _dispatch_client_callout + 8 (libdispatch.dylib) [0x7fff926150b6]
                                10 _dispatch_after_timer_callback + 22 (libdispatch.dylib) [0x7fff9261996f]
                                    10 _dispatch_call_block_and_release + 15 (libdispatch.dylib) [0x7fff92618f01]
                                      10 ??? (AppleIDAuthAgent + 9227) [0x10809840b]
                                        10 semaphore_wait_trap + 10 (libsystem_kernel.dylib) [0x7fff8a2526c2]
                Binary Images:
                       0x108096000 -        0x1080c6fff  AppleIDAuthAgent <91A3B8DC-AD42-399C-9A44-413CF8DF2CA4> /System/Library/CoreServices/AppleIDAuthAgent
              Process:         AppleSpell [231]
              Path:            /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
              UID:             501
              Sudden Term:     Clean
              Task size:       3970 pages
                Thread 0xd0c      DispatchQueue 1          priority 46
                  10 ??? (AppleSpell + 7271) [0x102c4fc67]
                    10 -[NSSpellServer run] + 73 (Foundation) [0x7fff8d33dee6]
                      10 CFRunLoopRun + 97 (CoreFoundation) [0x7fff94533dd1]
                Thread 0xd0e      DispatchQueue 2          priority 48
                Binary Images:
                       0x102c4e000 -        0x102d03ff7  com.apple.AppleSpell 1.9 (173.1) <6ED0981A-B081-3345-8EBB-E4AB821B077A> /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
                    0x7fff8d1bb000 -     0x7fff8d51afff  com.apple.Foundation 6.8 (945.18) <1D7E58E6-FA3A-3CE8-AC85-B9D06B8C0AA0> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
              Process:         apsd [69]
              Path:            /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
              Parent:          launchd [1]
              UID:             0
              Task size:       2256 pages
                Thread 0x2a9      DispatchQueue 1          priority 31
                  10 ??? (apsd + 21686) [0x108c334b6]
                    10 -[NSRunLoop(NSRunLoop) run] + 74 (Foundation) [0x7fff8d1ef1aa]
                      10 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 268 (Foundation) [0x7fff8d2567ee]
                Thread 0x33f      DispatchQueue 2          priority 33
                Thread 0x7e5      priority 63
                10 thread_start + 13 (libsystem_c.dylib) [0x7fff8d5ba1a1]
                  10 _pthread_start + 327 (libsystem_c.dylib) [0x7fff8d5cd772]
                    10 __NSThread__main__ + 1345 (Foundation) [0x7fff8d251562]
                      10 +[NSURLConnection(Loader) _resourceLoadLoop:] + 356 (Foundation) [0x7fff8d1f3546]
                Thread 0xdbd      priority 31
                    10 __select + 10 (libsystem_kernel.dylib) [0x7fff8a254322]
                Binary Images:
                       0x108c2e000 -        0x108cacff7  apsd <79FEFFFF-D855-3F06-BF98-C24F741AB4E7> /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
              Process:         autofsd [68]
              Path:            /usr/libexec/autofsd
              Parent:          launchd [1]
              UID:             0
              Sudden Term:     Clean
              Task size:       530 pages
                Thread 0x2db      DispatchQueue 2          priority 33
                Thread 0x2dc      DispatchQueue 7          priority 31
                Binary Images:
                       0x1092b8000 -        0x1092b9fff  autofsd <A0DF58CA-512D-3C2D-ACA4-2230682315DB> /usr/libexec/autofsd
              Process:         blued [66]
              Path:            /usr/sbin/blued
              Parent:          launchd [1]
              UID:             0
              Sudden Term:     Clean
              Task size:       1143 pages
                Thread 0x2a6      DispatchQueue 1          priority 31
                  10 ??? (blued + 91142) [0x10f395406]
                Thread 0x2da      DispatchQueue 2          priority 33
                Thread 0x3ad      priority 31
                Binary Images:
                       0x10f37f000 -        0x10f3f6ff7  blued <01AC05A9-3693-34FA-8568-D1B24E51FED9> /usr/sbin/blued
              Process:         CalendarAgent [160]
              Path:            /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
              UID:             501
              Task size:       5177 pages
                Thread 0x684      DispatchQueue 1          priority 31
                  10 ??? (CalendarAgent + 2739) [0x1016e2ab3]
                Thread 0x718      DispatchQueue 2          priority 33
                Thread 0x833      priority 31
                      10 -[CalAgentAPSConnectionManager _calAPSMain] + 731 (CalendarAgent) [0x1016ee0fc]
                Thread 0xb15      priority 63
                Thread 0xb31      priority 31
                Thread 0x880aa    priority <multiple>
                  10 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8d5cfce3]
                    10 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8a2546d6]
                Thread 0x880ab    priority 33
                Binary Images:
                       0x1016e2000 -        0x1016e2fff  CalendarAgent <D7916728-291A-3B77-B1A8-53FD7017C4A0> /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
                       0x1016e9000 -        0x1016ffff7  com.apple.CalendarAgent 1.0 (57) <762A246C-65FC-339D-A0F2-8ED9C907A9C2> /System/Library/PrivateFrameworks/CalendarAgent.framework/Versions/A/CalendarAgent
              Process:         CEPServiceManager [178]
              Path:            /Library/Application Support/Adobe/*/CEPServiceManager.app/Contents/MacOS/CEPServiceManager
              Architecture:    i386
              Parent:          launchd [1]
              UID:             501
              Task size:       2082 pages (+2)
              Process:         cfprefsd [22]
              Path:            /usr/sbin/cfprefsd
              Parent:          launchd [1]
              UID:             0
              Task size:       495 pages
                Thread 0x183      DispatchQueue 2          priority 33
                Thread 0x185      DispatchQueue 7          priority 31
                Thread 0x88147    priority 31
                Thread 0x88148    priority 31
                Thread 0x88149    priority 31
                Binary Images:
                       0x101ea3000 -        0x101ea3ff7  cfprefsd <B96D16CE-D6B9-38D9-898E-C6F984EB15BC> /usr/sbin/cfprefsd
              Process:         cfprefsd [102]
              Parent:          launchd [99]
              UID:             88
              Task size:       287 pages
                Thread 0x4df      DispatchQueue 2          priority 33
                Thread 0x4e1      DispatchQueue 7          priority 31
                Binary Images:
                       0x107b9b000 -        0x107b9bff7  cfprefsd <B96D16CE-D6B9-38D9-898E-C6F984EB15BC> /usr/sbin/cfprefsd
              Process:         cfprefsd [132]
              UID:             501
              Task size:       2267 pages
                Thread 0x617      DispatchQueue 2          priority 33
                Thread 0x619      DispatchQueue 7          priority 31
                Thread 0x87bf5    priority 31
                Thread 0x87bf6    priority 31
                Thread 0x880df    priority 31
                Binary Images:
                       0x1008bf000 -        0x1008bfff7  cfprefsd <B96D16CE-D6B9-38D9-898E-C6F984EB15BC> /usr/sbin/cfprefsd
              Process:         cfprefsd [245]
              Parent:          launchd [241]
              UID:             89
              Task size:       297 pages
                Thread 0xe45      DispatchQueue 2          priority 33
                Thread 0xe47      DispatchQueue 7          priority 31
                Binary Images:
                       0x1064c7000 -        0x1064c7ff7  cfprefsd <B96D16CE-D6B9-38D9-898E-C6F984EB15BC> /usr/sbin/cfprefsd
              Process:         com.apple.audio.ComponentHelper [271]
              Path:            /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.ComponentHe lper.xpc/Contents/MacOS/com.apple.audio.ComponentHelper
              Parent:          launchd [1]
              UID:             501
              Task size:       1237 pages
                Thread 0x17f3     DispatchQueue 7          priority 31
                Thread 0x17f5     DispatchQueue 2          priority 33
                Binary Images:
                       0x1006e8000 -        0x1006eafff  com.apple.audio.ComponentHelper 1.0 (1) <E74AD017-16EB-37E7-8BE4-DBF0784FEB01> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.ComponentHe lper.xpc/Contents/MacOS/com.apple.audio.ComponentHelper
              Process:         com.apple.audio.ComponentHelper [559]
              Parent:          launchd [1]
              UID:             501
              Task size:       1204 pages
                Thread 0x870a1    DispatchQueue 7          priority 31
                Thread 0x870a3    DispatchQueue 2          priority 33
                Binary Images:
                       0x10c051000 -        0x10c053fff  com.apple.audio.ComponentHelper 1.0 (1) <E74AD017-16EB-37E7-8BE4-DBF0784FEB01> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.ComponentHe lper.xpc/Contents/MacOS/com.apple.audio.ComponentHelper
              Process:         com.apple.audio.SandboxHelper [225]
              Path:            /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
              Parent:          launchd [1]
              UID:             202
              Task size:       1172 pages
                Thread 0xc44      DispatchQueue 7          priority 31
                Thread 0xc46      DispatchQueue 2          priority 33
                Binary Images:
                       0x10c500000 -        0x10c508fff  com.apple.audio.SandboxHelper 1.0 (1) <3E23CE49-31E9-302E-AD8C-35474D064CFC> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
              Process:         com.apple.audio.SandboxHelper [270]
              Parent:          launchd [1]
              UID:             501
              Task size:       1150 pages
                Thread 0x17ee     DispatchQueue 7          priority 31
                Thread 0x17f0     DispatchQueue 2          priority 33
                Binary Images:
                       0x107c1b000 -        0x107c23fff  com.apple.audio.SandboxHelper 1.0 (1) <3E23CE49-31E9-302E-AD8C-35474D064CFC> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
              Process:         com.apple.audio.SandboxHelper [558]
              Parent:          launchd [1]
              UID:             501
              Task size:       1140 pages
                Thread 0x87096    DispatchQueue 7          priority 31
                Thread 0x87098    DispatchQueue 2          priority 33
                Binary Images:
                       0x103b3e000 -        0x103b46fff  com.apple.audio.SandboxHelper 1.0 (1) <3E23CE49-31E9-302E-AD8C-35474D064CFC> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
              Process:         com.apple.dock.extra [198]
              Path:            /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Conte nts/MacOS/com.apple.dock.extra
              Parent:          launchd [1]
              UID:             501
              Task size:       3933 pages
                Thread 0x898      DispatchQueue 1          priority 47
                10 ??? (com.apple.dock.extra + 5956) [0x10e912744]
                  10 xpc_service_main + 433 (XPCService) [0x7fff92db7d15]
                    10 NSApplicationMain + 869 (AppKit) [0x7fff913c2bd6]
                      10 -[NSApplication run] + 517 (AppKit) [0x7fff9141e1a3]
                        10 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128 (AppKit) [0x7fff91426df2]
                          10 _DPSNextEvent + 685 (AppKit) [0x7fff91427533]
                            10 BlockUntilNextEventMatchingListInMode + 62 (HIToolbox) [0x7fff89952ae3]
                              10 ReceiveNextEventCommon + 356 (HIToolbox) [0x7fff89952c52]
                                10 RunCurrentEventLoopInMode + 209 (HIToolbox) [0x7fff89952eb4]
                Thread 0x8a0      DispatchQueue 2          priority 49
                Binary Images:
                       0x10e911000 -        0x10e915fff  com.apple.dock.extra 1.0 (1) <A2505C4B-D033-34DF-8C99-13E49EBA2BBD> /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Conte nts/MacOS/com.apple.dock.extra
                    0x7fff898f3000 -     0x7fff89c23fff  com.apple.HIToolbox 2.0 <656D08C2-9068-3532-ABDD-32EC5057CCB2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                    0x7fff912d2000 -     0x7fff91efffff  com.apple.AppKit 6.8 (1187.40) <F12CF463-6F88-32ED-9EBA-0FA2AD3CF576> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                    0x7fff92db6000 -     0x7fff92dbdfff  com.apple.XPCService 2.0 (1) <4B83D804-9CE3-359D-A5FA-C81CB5B09544> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
              Process:         com.apple.hiservices-xpcservice [207]
              Path:            /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.a pple.hiservices-xpcservice
              Parent:          launchd [1]
              UID:             501
              Task size:       1102 pages
                Thread 0x9e7      DispatchQueue 1          priority 31
                10 ??? (com.apple.hiservices-xpcservice + 5156) [0x10563c424]
                  10 ??? (com.apple.hiservices-xpcservice + 5851) [0x10563c6db]
                    10 xpc_service_main + 440 (XPCService) [0x7fff92db7d1c]
                Thread 0x9eb      DispatchQueue 2          priority 33
                Binary Images:
                       0x10563b000 -        0x10563eff7  com.apple.hiservices-xpcservice 1.10 (417) <634C3744-431F-399B-A270-0B0B51B02589> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.a pple.hiservices-xpcservice
              Process:         com.apple.qtkitserver [269]
              Path:            /System/Library/XPCServices/com.apple.qtkitserver.xpc/Contents/MacOS/com.apple.qtkitserve r
              Architecture:    i386
              Parent:          launchd [1]
              UID:             501
              Task size:       1049 pages
                Thread 0x17e1     priority 47
                10 start + 1 (libdyld.dylib) [0x93ccb725]
                  10 main + 158 (com.apple.qtkitserver) [0xde1c2]
                    10 xpc_service_main + 460 (XPCService) [0x119d03]
                      10 CFRunLoopRun + 129 (CoreFoundation) [0x9458bab1]
                Thread 0x17e6     DispatchQueue 1701273966 priority 49
                Binary Images:
                           0xd1000 -            0xfffff  com.apple.qtkitserver 1.0 (1) <712FE27F-E5F1-3446-A4F9-3C95427BE16D> /System/Library/XPCServices/com.apple.qtkitserver.xpc/Contents/MacOS/com.apple.qtkitserve r
                          0x118000 -           0x11fff7  com.apple.XPCService 2.0 (1) <E204208C-8338-34F3-A74A-06756A08597E> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
                        0x93cc9000 -         0x93ccbfff  libdyld.dylib <05D6FF2A-F09B-309D-95F7-7AF10259C707> /usr/lib/system/libdyld.dylib
              Process:         com.apple.ShareKitHelper [323]
              Path:            /System/Library/PrivateFrameworks/ShareKit.framework/Versions/A/XPCServices/com.apple.Sha reKitHelper.xpc/Contents/MacOS/com.apple.ShareKitHelper
              Parent:          launchd [1]
              UID:             501
              Task size:       6141 pages
                Thread 0x2a921    DispatchQueue 1          priority 47
                Thread 0x2a936    DispatchQueue 2          priority 49
                Binary Images:
                       0x104713000 -        0x104715fff  com.apple.ShareKitHelper 1.0 (119.13) <868523CD-3EFF-344B-AEE9-88064EEB0349> /System/Library/PrivateFrameworks/ShareKit.framework/Versions/A/XPCServices/com.apple.Sha reKitHelper.xpc/Contents/MacOS/com.apple.ShareKitHelper
              Process:         configd [17]
              Path:            /usr/libexec/configd
              Parent:          launchd [1]
              UID:             0
              Sudden Term:     Clean
              Task size:       1268 pages
                Thread 0x167      DispatchQueue 1          priority 31
                  10 ??? (configd + 7263) [0x103cd5c5f]
                    10 ??? (configd + 10127) [0x103cd678f]
                Thread 0x169      DispatchQueue 2          priority 33
                  10 __select_nocancel + 10 (libsystem_kernel.dylib) [0x7fff8a254336]
                Thread 0x16b      priority 31
                    10 ??? (configd + 12444) [0x103cd709c]
                Thread 0x195      priority 31
                    10 ??? (configd + 54376) [0x103ce1468]
                Thread 0x198      priority 31
                Thread 0x1ae      priority 31
                    10 pppcntl_run_thread + 2390 (PPPController) [0x10410b8a6]
                Binary Images:
                       0x103cd4000 -        0x103d02ff7  configd <66DE8AD9-5CCC-395C-91DB-465897FADFF9> /usr/libexec/configd
                       0x104100000 -        0x104141ff7  com.apple.SystemConfiguration.PPPController 1.8 (1.8) <1C34258C-F220-3A82-A65F-86D4884D4F5C> /System/Library/SystemConfiguration/PPPController.bundle/Contents/MacOS/PPPController
              Process:         cookied [507]
              Path:            /System/Library/Frameworks/CFNetwork.framework/Versions/A/Support/cookied
              UID:             501
              Sudden Term:     Clean
              Task size:       511 pages
                Thread 0x701fd    DispatchQueue 1          priority 31
                  10 _cookied_main + 1190 (CFNetwork) [0x7fff8cc21f66]
                Thread 0x70203    DispatchQueue 2          priority 33
                Binary Images:
                       0x101d51000 -        0x101d51fff  cookied <19DDC61A-3CF2-372A-BB4D-309A83C3BE5A> /System/Library/Frameworks/CFNetwork.framework/Versions/A/Support/cookied
                    0x7fff8cb26000 -     0x7fff8cc9bff7  com.apple.CFNetwork 596.5 (596.5) <22372475-6EF4-3A04-83FC-C061FE4717B3> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
              Process:         Core Sync [209]
              Path:            /Applications/Utilities/Adobe Creative Cloud/*/Core Sync.app/Contents/MacOS/Core Sync
              Parent:          Creative Cloud [164]
              UID:             501
              Task size:       3973 pages
              Process:         coreaudiod [145]
              Path:            /usr/sbin/coreaudiod
              Parent:          launchd [1]
              UID:             202
              Sudden Term:     Dirty
              Task size:       4118 pages (+3)
                Thread 0x64e      DispatchQueue 1          priority 63
                  10 ??? (coreaudiod + 422293) [0x10ac20195]
                Thread 0x667      DispatchQueue 2          priority 33
                Thread 0x91d      priority 61
                    10 ??? (coreaudiod + 468639) [0x10ac2b69f]
                      10 ??? (coreaudiod + 435005) [0x10ac2333d]
                Thread 0x8826f    priority 31
                7 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8d5ba191]
                  7 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8d5cfce3]
                    7 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8a2546d6]
                     *7 ??? (mach_kernel + 3943920) [0xffffff80005c2df0]
                Binary Images:
                       0x10abb9000 -        0x10ac92fff  coreaudiod <A470CB9F-4557-3AE7-80E1-06C7E39E77EF> /usr/sbin/coreaudiod
              Process:         coreservicesd [24]
              Path:            /System/Library/CoreServices/coreservicesd
              Parent:          launchd [1]
              UID:             0
              Sudden Term:     Clean
              Task size:       10170 pages
                Thread 0x1ac      DispatchQueue 1          priority 31
                  10 _CoreServicesServerMain + 691 (CarbonCore) [0x7fff940b6ff5]
                Thread 0x1b2      DispatchQueue 2          priority 33
                Thread 0x267      priority 31
                    10 fmodWatchConsumer + 581 (CarbonCore) [0x7fff940bcbf7]
                      10 __psynch_cvwait + 10 (libsystem_kernel.dylib) [0x7fff8a2540fa]
                Thread 0x268      priority 31
                    10 read + 10 (libsystem_kernel.dylib) [0x7fff8a254ffa]
                     *10 hndl_unix_scall64 + 19 (mach_kernel) [0xffffff80002cf453]
                       *10 unix_syscall64 + 522 (mach_kernel) [0xffffff80005e97ba]
                         *10 read_nocancel + 130 (mach_kernel) [0xffffff800057e822]
                           *10 ??? (mach_kernel + 3664382) [0xffffff800057e9fe]
                             *10 ??? (mach_kernel + 1198151) [0xffffff8000324847]
                               *10 tsleep + 88 (mach_kernel) [0xffffff80005722d8]
                                 *10 ??? (mach_kernel + 3612640) [0xffffff8000571fe0]
                                   *10 thread_block_reason + 300 (mach_kernel) [0xffffff800022db9c]
                                     *10 ??? (mach_kernel + 190673) [0xffffff800022e8d1]
                                       *10 machine_switch_context + 366 (mach_kernel) [0xffffff80002b496e]
                Binary Images:
                       0x100fca000 -        0x100fcafff  coreservicesd <46E63883-6EEA-31B9-8D9F-D8B607D36974> /System/Library/CoreServices/coreservicesd
                    0x7fff940b6000 -     0x7fff943cdff7  com.apple.CoreServices.CarbonCore 1037.6 (1037.6) <1E567A52-677F-3168-979F-5FBB0818D52B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
              Process:         Creative Cloud [164]
              Path:            /Applications/Utilities/Adobe Creative Cloud/*/Creative Cloud.app/Contents/MacOS/Creative Cloud
              Architecture:    i386
              UID:             501
              Task size:       10278 pages
              CPU Time:        0.001s
              Process:         CVMServer [97]
              Path:            /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
              Parent:          launchd [1]
              UID:             0
              Sudden Term:     Dirty
              Task size:       658 pages
                Thread 0x4d3      DispatchQueue 7          priority 31
                Thread 0x4d6      DispatchQueue 2          priority 33
                Thread 0x880ee    priority 31
                Binary Images:
                       0x108f6e000 -        0x108f77fff  CVMServer <B1A078DF-159E-3A25-BBEF-0ABCF85E1C37> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
              Process:         diskarbitrationd [16]
              Path:            /usr/sbin/diskarbitrationd
              Parent:          launchd [1]
              UID:             0
              Sudden Term:     Dirty
              Task size:       520 pages
                Thread 0x166      DispatchQueue 1          priority 31
                  10 ??? (diskarbitrationd + 33766) [0x1045193e6]
                Thread 0x16c      DispatchQueue 2          priority 33
                Binary Images:
                       0x104511000 -        0x10452bfff  diskarbitrationd <173CBBB5-300F-33F6-A669-2ADBE1EB95B0> /usr/sbin/diskarbitrationd
              Process:         distnoted [20]
              Path:            /usr/sbin/distnoted
              Parent:          launchd [1]
              UID:             0
              Task size:       585 pages
                Thread 0x172      DispatchQueue 1          priority 31
                  10 ??? (distnoted + 14743) [0x10c4c3997]
                Thread 0x17f      DispatchQueue 2          priority 33
                Binary Images:
                       0x10c4c0000 -        0x10c4c5ff7  distnoted <1AD693FE-8ACE-3EF5-B496-2FBFEB9F463D> /usr/sbin/distnoted
              Process:         distnoted [130]
              UID:             501
              Task size:       1199 pages
                Thread 0x60c      DispatchQueue 1          priority 31
                  10 ??? (distnoted + 14743) [0x10422a997]
                Thread 0x613      DispatchQueue 2          priority 33
                Thread 0x880e0    priority 31
                Thread 0x880e1    priority 31
                Thread 0x880e2    priority 31
                Thread 0x880e3    priority 31
                Thread 0x880e4    priority 31
                Thread 0x880e5    priority 31
                Thread 0x880e6    priority 31
                Thread 0x880e7    priority 31
                Thread 0x881ca    priority 31
                Binary Images:
                       0x104227000 -        0x10422cff7  distnoted <1AD693FE-8ACE-3EF5-B496-2FBFEB9F463D> /usr/sbin/distnoted
              Process:         distnoted [244]
              UID:             89
              Task size:       453 pages
                Thread 0xe3b      DispatchQueue 1          priority 31
                  10 ??? (distnoted + 14743) [0x104204997]
                Thread 0xe3c      DispatchQueue 2          priority 33
                Binary Images:
                       0x104201000 -        0x104206ff7  distnoted <1AD693FE-8ACE-3EF5-B496-2FBFEB9F463D> /usr/sbin/distnoted
              Process:         Dock [142]
              Path:            /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
              UID:             501
              Task size:       17158 pages
              CPU Time:        0.004s
                Thread 0x64a      DispatchQueue 1          priority 47
                  10 ??? (Dock + 843262) [0x108284dfe]
                Thread 0x65b      DispatchQueue 2          priority 49
                Thread 0x887      priority 47         cpu time   0.004s
                    7 ??? (Dock + 100664) [0x1081cf938]
                      7 __psynch_cvwait + 10 (libsystem_kernel.dylib) [0x7fff8a2540fa]
                       *7 psynch_cvcontinue + 0 (mach_kernel) [0xffffff80005bdcb0]
                    3 clock_sleep_trap + 10 (libsystem_kernel.dylib) [0x7fff8a252776]
                     *3 hndl_mach_scall64 + 19 (mach_kernel) [0xffffff80002cf473]
                       *3 ??? (mach_kernel + 681286) [0xffffff80002a6546]
                         *3 clock_sleep_trap + 434 (mach_kernel) [0xffffff800021d462]
                           *3 thread_block_reason + 300 (mach_kernel) [0xffffff800022db9c]
                             *3 ??? (mach_kernel + 190673) [0xffffff800022e8d1]
                               *3 machine_switch_context + 366 (mach_kernel) [0xffffff80002b496e]
                Thread 0x87d60    priority 47
                Thread 0x87fd2    priority 47
                Thread 0x880de    priority 47
                Thread 0x880e8    priority 47
                Thread 0x880e9    priority 45
                Thread 0x880ef    priority 45
                Thread 0x880f0    priority 45
                Thread 0x880f1    priority 47
                Binary Images:
                       0x1081b7000 -        0x108411fff  com.apple.dock 1.8 (1168.8) <126B9757-39DF-318A-8FC6-D7054975CFAC> /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
              Process:         dynamic_pager [60]
              Path:            /sbin/dynamic_pager
              Architecture:    unknown
              Parent:          launchd [1]
              UID:             0
              Task size:       199 pages
                Thread 0x2a0      priority 63
                10 ??? [0x7fff8a252686]
                Binary Images:
              Process:         dynamiclinkmanager [358]
              Path:            /Library/Application Support/Adobe/*/dynamiclinkmanager.app/Contents/MacOS/dynamiclinkmanager
              Architecture:    i386
              UID:             501
              Task size:       2019 pages
              Process:         eapolclient [197]
              Path:            /System/Library/SystemConfiguration/EAPOLController.bundle/Contents/Resources/eapolclient
              Parent:          configd [17]
              UID:             501
              Task size:       1378 pages
                Thread 0x886      DispatchQueue 1          priority 31
                  10 ??? (eapolclient + 7743) [0x1035e6e3f]
                Thread 0x889      DispatchQueue 2          priority 33
                Thread 0x888      priority 31
                Binary Images:
                       0x1035e5000 -        0x1035f4ff7  eapolclient <2BAE7F32-2E26-391B-A31C-851DADCDFED5> /System/Library/SystemConfiguration/EAPOLController.bundle/Contents/Resources/eapolclient
              Process:         filecoordinationd [172]
              Path:            /usr/sbin/filecoordinationd
              Parent:          launchd [1]
              UID:             0
              Sudden Term:     Clean
              Task size:       1090 pages
                Thread 0x6f3      DispatchQueue 7          priority 31
                Thread 0x6f4      DispatchQueue 2          priority 33
                Binary Images:
                       0x10e270000 -        0x10e270ff7  filecoordinationd <6E46FB95-0458-38CD-84BE-9775D69FF9A8> /usr/sbin/filecoordinationd
              Process:         Finder [144]
              Path:            /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
              UID:             501
              Sudden Term:     Dirty
              Task size:       20685 pages (+8)
              CPU Time:        0.003s
                Thread 0x64c      DispatchQueue 1          priority 46
                  10 ??? (Finder + 23382) [0x103159b56]
                Thread 0x66e      DispatchQueue 2          priority 48
                Thread 0xa47      priority 46
                10 ??? [0xdeadbea7dad]
                  10 ??? [0x1078fa743]
                    10 thread_suspend + 71 (libsystem_kernel.dylib) [0x7fff8a24ee28]
                       *10 special_handler_continue + 0 (mach_kernel) [0xffffff800023cb10]
                Thread 0xa4b      priority 46
                      10 -[NSConnection run] + 126 (Foundation) [0x7fff8d2a9a35]
                Thread 0xa4e      priority 46
                Thread 0x2bf5a    priority 62
                    10 thread_fun + 25 (QuartzCore) [0x7fff8a658dc6]
                      10 CA::Render::Server::server_thread(void*) + 403 (QuartzCore) [0x7fff8a5d417b]
                Thread 0x871ac    priority 46
                Thread 0x875e9    priority 46
                     *9 ??? (mach_kernel + 3943920) [0xffffff80005c2df0]
                     *1 hndl_unix_scall64 + 19 (mach_kernel) [0xffffff80002cf453]
                       *1 unix_syscall64 + 522 (mach_kernel) [0xffffff80005e97ba]
                         *1 workq_kernreturn + 478 (mach_kernel) [0xffffff80005c272e]
                           *1 ??? (mach_kernel + 3940068) [0xffffff80005c1ee4]
                             *1 thread_block_reason + 275 (mach_kernel) [0xffffff800022db83]
                               *1 ??? (mach_kernel + 187921) [0xffffff800022de11]
                                 *1 processor_idle + 237 (mach_kernel) [0xffffff800022f35d]
                                   *1 machine_idle + 434 (mach_kernel) [0xffffff80002ba222]
                Thread 0x8812a    priority 46
                Thread 0x8812b    priority 0
                Thread 0x8812c    priority 46         cpu time   0.003s
              *5 ??? (mach_kernel + 3944432) [0xffffff80005c2ff0]
                Thread 0x8812c    DispatchQueue 95         priority 46
                1 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8d5ba191]
                  1 _pthread_wqthread + 404 (libsystem_c.dylib) [0x7fff8d5cfcdb]
                    1 _dispatch_worker_thread2 + 249 (libdispatch.dylib) [0x7fff926161c3]
                      1 _dispatch_queue_invoke + 52 (libdispatch.dylib) [0x7fff926162f1]
                        1 _dispatch_queue_drain + 235 (libdispatch.dylib) [0x7fff9261647f]
                          1 _dispatch_client_callout + 8 (libdispatch.dylib) [0x7fff926150b6]
                            1 _dispatch_call_block_and_release + 15 (libdispatch.dylib) [0x7fff92618f01]
                              1 __PostNodeTaskRequest_block_invoke_0 + 91 (DesktopServicesPriv) [0x7fff8b022be1]
                                1 ExceptionSafeBlock(void ()() block_pointer) + 12 (DesktopServicesPriv) [0x7fff8b022c40]
                                  1 __block_global_1 + 82 (DesktopServicesPriv) [0x7fff8b09613f]
                                    1 TNode::HandleNodeRequest(TCountedPtr<TNodeTask> const&, TCountedPtr<TVolumeSyncThread> const&) + 757 (DesktopServicesPriv) [0x7fff8b022f8b]
                                      1 TNode::HandleSync(TCountedPtr<TNodeTask> const&, TNodePtr const&) + 42 (DesktopServicesPriv) [0x7fff8b046988]
                                        1 TNode::HandleSync(unsigned int) + 502 (DesktopServicesPriv) [0x7fff8b032972]
                                          1 TFSInfo::Initialize(__CFURL const*) + 254 (DesktopServicesPriv) [0x7fff8b01d0aa]
                                            1 TFSInfo::FetchProperties() + 1274 (DesktopServicesPriv) [0x7fff8b01d61c]
                                              1 _FSURLGetVolumePropertyFlags + 1 (CoreServicesInternal) [0x7fff8c93eaad]
                                                1 <executing in user space>
                Binary Images:
                       0x103154000 -        0x10360eff7  com.apple.finder 10.8.3 (10.8.3) <5AF2416D-6AF0-386F-86D5-A276C74780E6> /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
                    0x7fff8a517000 -     0x7fff8a6c5fff  com.apple.QuartzCore 1.8 (304.3) <F450F2DE-2F24-3557-98B6-310E05DAC17F> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                    0x7fff8b011000 -     0x7fff8b131fff  com.apple.desktopservices 1.7.4 (1.7.4) <ED3DA8C0-160F-3CDC-B537-BF2E766AB7C1> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                    0x7fff8c92b000 -     0x7fff8c959fff  com.apple.CoreServicesInternal 154.3 (154.3) <F4E118E4-E327-3314-83D7-EA20B1717ED0> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
              Process:         fontd [173]
              Path:            /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support /fontd
              UID:             501
              Sudden Term:     Clean
              Task size:       2011 pages (+3)
                Thread 0x703      DispatchQueue 1          priority 31
                  10 main_handler + 4757 (libATSServer.dylib) [0x7fff90ee7ff7]
                Thread 0x710      DispatchQueue 2          priority 33
                Thread 0x88289    priority 31
                5 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8d5ba191]
                  5 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8d5cfce3]
                    5 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8a2546d6]
                     *5 ??? (mach_kernel + 3943920) [0xffffff80005c2df0]
                Binary Images:
                       0x10e589000 -        0x10e58cfff  fontd <8EE3DBFC-B8F0-3A32-9ED8-29E195EF9269> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support /fontd
                    0x7fff90e69000 -     0x7fff90f10fff  libATSServer.dylib <531C17E4-40BE-3D3D-A0C4-1F895FF3191E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libATSServer.dylib
              Process:         fseventsd [33]
              Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/Support/fseventsd
              Parent:          launchd [1]
              UID:             0
              Task size:       1363 pages
                Thread 0x27a      DispatchQueue 1          priority 31
                  10 ??? (fseventsd + 5581) [0x105d7d5cd]
                    10 mach_msg_server + 335 (libsystem_kernel.dylib) [0x7fff8a252433]
                      10 mach_msg_overwrite_trap + 10 (libsystem_kernel.dylib) [0x7fff8a252692]
                Thread 0x27f      DispatchQueue 2          priority 33
                Thread 0x27b      priority 49
                    10 ??? (fseventsd + 43276) [0x105d8690c]
                      10 ??? (fseventsd + 42504) [0x105d86608]
                Thread 0x27c      priority 31
                    10 ??? (fseventsd + 12957) [0x105d7f29d]
                Thread 0x27d      priority 50
                Thread 0x27e      priority 31
                    10 ??? (fseventsd + 29434) [0x105d832fa]
                Thread 0x332      priority 31
                Thread 0x334      priority 31
                Thread 0x335      priority 31
                Thread 0x337      priority 31
                Thread 0x33a      priority 31
                Thread 0x33b      priority 31
                Thread 0x33c      priority 31
                Thread 0x33d      priority 31
                Thread 0x342      priority 31
                Thread 0x343      priority 31
                Thread 0x345      priority 31
                Thread 0x346      priority 31
                Thread 0x34d      priority 31
                Thread 0x34e      priority 31
                Thread 0x352      priority 31
                Thread 0x353      priority 31
                Thread 0x354      priority 31
                Thread 0x355      priority 31
                Thread 0x357      priority 31
                Thread 0x35c      priority 31
                Thread 0x35d      priority 31
                Thread 0x360      priority 31
                Thread 0x361      priority 31
                Thread 0x362      priority 31
                Thread 0x364      priority 31
                Thread 0x369      priority 31
                Thread 0x36c      priority 31
                Thread 0x6d6      priority 31
                Thread 0x743      priority 31
                Thread 0x758      priority 31
                Thread 0x763      priority 31
                Thread 0x7c0      priority 31
                Thread 0x851      priority 31
                Thread 0x85b      priority 31
                Thread 0x85c      priority 31
                Thread 0x85d      priority 31
                Thread 0x85e      priority 31
                Thread 0x85f      priority 31
                Thread 0x860      priority 31
                Thread 0x861      priority 31
                Thread 0x862      priority 31
                Thread 0x882      priority 31
                Thread 0x883      priority 31
                Thread 0x890      priority 31
                Thread 0x892      priority 29
                Thread 0x893      priority 30
                Thread 0x896      priority 31
                Thread 0x90b      priority 31
                Thread 0xa36      priority 31
                Thread 0xb67      priority 31
                Thread 0xbf6      priority 31
                Thread 0x3b7a     priority 31
                Thread 0x2a316    priority 31
                Thread 0x337d6    priority 31
                Thread 0x866ae    priority 31
                Thread 0x86db9    priority 31
                Thread 0x87735    priority 31
                Binary Images:
                       0x105d7c000 -        0x105d91fff  fseventsd <AF82DA10-72E0-3BB0-952C-7BAC2BAD3BFA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/Support/fseventsd
              Process:         Google Chrome [402]
              Path:            /Applications/Google Chrome.app/Contents/MacOS/Google Chrome
              Architecture:    i386
              UID:             501
              Task size:       19513 pages
              Process:         Google Chrome Helper [405]
              Path:            /Applications/Google Chrome.app/Contents/Versions/31.0.1650.63/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper
              Architecture:    i386
              Parent:          Google Chrome [402]
              UID:             501
              Task size:       10161 pages
              Process:         helpd [157]
              Path:            /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/Resources/helpd
              UID:             501
              Sudden Term:     Clean
              Task size:       594 pages (+3)
                Thread 0x681      DispatchQueue 1          priority 31
                  10 ??? (helpd + 41173) [0x10ccb80d5]
                Thread 0x69f      DispatchQueue 2          priority 33
                Thread 0x88274    priority 31
                6 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8d5ba191]
                  6 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8d5cfce3]
                    6 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8a2546d6]
                     *6 ??? (mach_kernel + 3943920) [0xffffff80005c2df0]
                Binary Images:
                       0x10ccae000 -        0x10ccbdfff  helpd <18369DE6-2FD3-3D31-8E69-F1CE023B0B8F> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/Resources/helpd
              Process:         hidd [58]
              Path:            /usr/libexec/hidd
              Parent:          launchd [1]
              UID:             0
              Sudden Term:     Clean
              Task size:       879 pages
              CPU Time:        0.005s
                Thread 0x29e      DispatchQueue 1          priority 31
                  10 ??? (hidd + 3863) [0x107fecf17]
                Thread 0x2d2      DispatchQueue 2          priority 33
                Thread 0x4e8      priority 63         cpu time   0.005s
                    10 __IOHIDSessionStartOnThread + 402 (IOKit) [0x7fff92e1c254]
                Thread 0x87d19    priority 31
                Binary Images:
                       0x107fec000 -        0x107fecfff  hidd <BD8355E6-6A73-315F-A65A-86AB1B004B48> /usr/libexec/hidd
                    0x7fff92dec000 -     0x7fff92e5aff7  com.apple.framework.IOKit 2.0.1 <A90038ED-48F2-3CC9-A042-53A3D7985844> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
              Process:         Image Capture Extension [217]
              Path:            /System/Library/Image Capture/Support/Image Capture Extension.app/Contents/MacOS/Image Capture Extension
              UID:             501
              Sudden Term:     Clean
              Task size:       4228 pages
                Thread 0xb5d      DispatchQueue 1          priority 46
                Thread 0xb61      DispatchQueue 2          priority 48
                Thread 0x2bc16    priority 46
                Binary Images:
                       0x100c4c000 -        0x100cb3fff  com.apple.ImageCaptureExtension2 8.0.1 (8.0.1) <4C3765E8-FAB8-3525-8474-EB9767FC75D8> /System/Library/Image Capture/Support/Image Capture Extension.app/Contents/MacOS/Image Capture Extension
              Process:         imagent [156]
              Path:            /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
              UID:             501
              Task size:       2364 pages (+3)
                Thread 0x680      DispatchQueue 1          priority 31
                  10 ??? (imagent + 32939) [0x10cb5b0ab]
                Thread 0x6d8      DispatchQueue 2          priority 33
                Thread 0x6f8      priority 31
                      10 ??? (IMDPersistence + 6074) [0x7fff898aa7ba]
                Thread 0xcd8      priority 31
                    10 ??? (AIM + 85840) [0x10e432f50]
                      10 ??? (AIM + 86738) [0x10e4332d2]
                        10 ??? (AIM + 87652) [0x10e433664]
                Thread 0xd33      priority 31
                Thread 0x8827d    priority 31
                Binary Images:
                       0x10cb53000 -        0x10cb7afff  com.apple.imagent 8.0 (900) <0F128A3A-D546-3C5E-8F32-F695DC6EADE3> /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
                       0x10e41e000 -        0x10e595ff7  com.apple.imservice.aim 7.0.1 (800) <448E6A46-32EE-31C3-9D49-708D4AA42DB1> /Library/Messages/*/AIM
                    0x7fff898a9000 -     0x7fff898efff7  com.apple.IMDPersistence 8.0 (900) <8F359FC3-BD5E-3269-9A79-80849E9CC2DE> /System/Library/PrivateFrameworks/IMDPersistence.framework/Versions/A/IMDPersistence
              Process:         iTunesHelper [171]
              Path:            /Applications/iTunes.app/Contents/MacOS/iTunesHelper.app/Contents/MacOS/iTunesHelper
              UID:             501
              Task size:       1974 pages (+3)
                Thread 0x6d0      DispatchQueue 1          priority 46
                10 ??? (iTunesHelper + 6948) [0x100001b24]
                  10 ??? (iTunesHelper + 13193) [0x100003389]
                Thread 0x714      DispatchQueue 2          priority 48
                Thread 0x74e      priority 46
                Thread 0x88284    priority 46
                Binary Images:
                       0x100000000 -        0x100023ff7  com.apple.iTunesHelper 11.1.3 (11.1.3) <9B9C6400-99FB-365C-85D4-0ED8EFF89326> /Applications/iTunes.app/Contents/MacOS/iTunesHelper.app/Contents/MacOS/iTunesHelper
              Process:         KernelEventAgent [56]
              Path:            /usr/sbin/KernelEventAgent
              Parent:          launchd [1]
              UID:             0
              Sudden Term:     Clean
              Task size:       286 pages
                Thread 0x29c      DispatchQueue 1          priority 31
                  10 main + 908 (KernelEventAgent) [0x100bda6ec]
                Thread 0x2bf      DispatchQueue 2          priority 33
                Thread 0x2be      priority 31
                Binary Images:
                       0x100bd9000 -        0x100bdffff  KernelEventAgent <F160063A-1452-388A-AF35-18892F224ADC> /usr/sbin/KernelEventAgent
              Process:         kextd [12]
              Path:            /usr/libexec/kextd
              Parent:          launchd [1]
              UID:             0
              Task size:       1557 pages
                Thread 0x15c      DispatchQueue 1          priority 31
                  10 ??? (kextd + 7152) [0x104dacbf0]
                Thread 0x164      DispatchQueue 2          priority 33
                Binary Images:
                       0x104dab000 -        0x104dc9fff  kextd <EBB5497D-D578-3B23-A870-995F5DF17A0B> /usr/libexec/kextd
              Process:         launchd [1]
              Path:            /sbin/launchd
              Parent:          kernel_task [0]
              UID:             0
              Task size:       614 pages (-1)
              CPU Time:        0.005s
                Thread 0xf0       DispatchQueue 1          priority 31         cpu time   0.005s
                  10 ??? (launchd + 15472) [0x104923c70]
                    10 ??? (launchd + 24092) [0x104925e1c]
                      9 xpc_pipe_try_receive + 89 (libxpc.dylib) [0x7fff8c600bbd]
                        9 _xpc_pipe_receive + 116 (libxpc.dylib) [0x7fff8c600db0]
                          9 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff8a252686]
                           *9 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                      1 xpc_pipe_try_receive + 258 (libxpc.dylib) [0x7fff8c600c66]
                        1 ??? (launchd + 28819) [0x104927093]
                          1 ??? (launchd + 4031) [0x104920fbf]
                            1 ??? (launchd + 23864) [0x104925d38]
                              1 ??? (launchd + 29218) [0x104927222]
                                1 ??? (launchd + 87775) [0x1049356df]
                                  1 ??? (launchd + 32417) [0x104927ea1]
                                    1 __socketpair + 10 (libsystem_kernel.dylib) [0x7fff8a25458e]
                                         *1 socketpair + 172 (mach_kernel) [0xffffff80005a81ec]
                                           *1 falloc + 64 (mach_kernel) [0xffffff8000554100]
                                             *1 falloc_locked + 214 (mach_kernel) [0xffffff80005541f6]
                                               *1 zalloc_canblock + 242 (mach_kernel) [0xffffff8000243d52]
                                                 *1 ??? (mach_kernel + 279619) [0xffffff8000244443]
                Thread 0xff       priority 31
                    9 __select + 10 (libsystem_kernel.dylib) [0x7fff8a254322]
                     *9 ??? (mach_kernel + 3613728) [0xffffff8000572420]
                    1 ??? (launchd + 19362) [0x104924ba2]
                      1 ??? (launchd + 3716) [0x104920e84]
                        1 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff8a252686]
                         *1 hndl_mach_scall64 + 19 (mach_kernel) [0xffffff80002cf473]
                           *1 ??? (mach_kernel + 681286) [0xffffff80002a6546]
                             *1 mach_msg_overwrite_trap + 427 (mach_kernel) [0xffffff800021970b]
                               *1 ipc_mqueue_receive + 59 (mach_kernel) [0xffffff800021310b]
                Thread 0x100      priority 31
                    10 ??? (launchd + 15865) [0x104923df9]
                      10 sleep + 61 (libsystem_c.dylib) [0x7fff8d657652]
                        10 __semwait_signal + 10 (libsystem_kernel.dylib) [0x7fff8a254386]
                Binary Images:
                       0x104920000 -        0x104946ff7  launchd <7DCC9489-2DF5-3807-83FA-EF5666EE8078> /sbin/launchd
                    0x7fff8c5fe000 -     0x7fff8c620ff7  libxpc.dylib <70BC645B-6952-3264-930C-C835010CCEF9> /usr/lib/system/libxpc.dylib
              Process:         launchd [99]
              Path:            /sbin/launchd
              Parent:          launchd [1]
              UID:             88
              Sudden Term:     Dirty
              Task size:       245 pages
                Thread 0x4d9      DispatchQueue 1          priority 31
                  10 ??? (launchd + 15472) [0x10cce6c70]
                    10 ??? (launchd + 24092) [0x10cce8e1c]
                      10 xpc_pipe_try_receive + 89 (libxpc.dylib) [0x7fff8c600bbd]
                        10 _xpc_pipe_receive + 116 (libxpc.dylib) [0x7fff8c600db0]
                Thread 0x4dc      priority 31
                Binary Images:
                       0x10cce3000 -        0x10cd09ff7  launchd <7DCC9489-2DF5-3807-83FA-EF5666EE8078> /sbin/launchd
              Process:         launchd [126]
              Path:            /sbin/launchd
              Parent:          launchd [1]
              UID:             501
              Sudden Term:     Dirty
              Task size:       430 pages
                Thread 0x5fb      DispatchQueue 1          priority 31
                  10 ??? (launchd + 15472) [0x10956ac70]
                    10 ??? (launchd + 24092) [0x10956ce1c]
                Thread 0x5fc      priority 31
                Binary Images:
                       0x109567000 -        0x10958dff7  launchd <7DCC9489-2DF5-3807-83FA-EF5666EE8078> /sbin/launchd
              Process:         launchd [241]
              Path:            /sbin/launchd
              Parent:          launchd [1]
              UID:             89
              Sudden Term:     Dirty
              Task size:       231 pages
                Thread 0xe28      DispatchQueue 1          priority 31
                  10 ??? (launchd + 15472) [0x10e67cc70]
                    10 ??? (launchd + 24092) [0x10e67ee1c]
                Thread 0xe2f      priority 31
                Binary Images:
                       0x10e679000 -        0x10e69fff7  launchd <7DCC9489-2DF5-3807-83FA-EF5666EE8078> /sbin/launchd
              Process:         launchdadd [568]
              Path:            /usr/libexec/launchdadd
              Parent:          launchd [1]
              UID:             0
              Sudden Term:     Clean
              Task size:       440 pages
                Thread 0x881de    DispatchQueue 1          priority 31
                9 start + 1 (libdyld.dylib) [0x7fff8c95c7e1]
                  9 main + 281 (launchdadd) [0x106721577]
                    9 CFRunLoopRun + 97 (CoreFoundation) [0x7fff94533dd1]
                      9 CFRunLoopRunSpecific + 290 (CoreFoundation) [0x7fff945250e2]
                        9 __CFRunLoopRun + 1078 (CoreFoundation) [0x7fff94525916]
                          9 __CFRunLoopServiceMachPort + 195 (CoreFoundation) [0x7fff94520233]
                Thread 0x88251    DispatchQueue 2          priority 33
                9 _dispatch_mgr_thread + 54 (libdispatch.dylib) [0x7fff926179ee]
                  9 kevent + 10 (libsystem_kernel.dylib) [0x7fff8a254d16]
                   *9 ??? (mach_kernel + 3504704) [0xffffff8000557a40]
                Thread 0x88252    priority 31
                9 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8d5ba191]
                  9 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8d5cfce3]
                    9 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8a2546d6]
                Binary Images:
                       0x10671a000 -        0x106726fff  launchdadd <635F6227-0868-3C28-94C5-7BFD7464BC9E> /usr/libexec/launchdadd
              Process:         librariand [550]
              Path:            /usr/libexec/librariand
              UID:             501
              Task size:       2192 pages
                Thread 0x86bd4    DispatchQueue 1          priority 31
                  10 ??? (librariand + 9422) [0x1039fe4ce]
                Thread 0x86bd7    DispatchQueue 2          priority 33
                Binary Images:
                       0x1039fc000 -        0x103a0cfff  librariand <773C4A00-1D20-3B6A-A365-DF150A7A95D6> /usr/libexec/librariand
              Process:         logind [111]
              Path:            /System/Library/CoreServices/logind
              Parent:          launchd [1]
              UID:             0
              Task size:       499 pages
                Thread 0x51e      DispatchQueue 1          priority 31
                  10 ??? (logind + 3087) [0x1011c9c0f]
                Thread 0x51f      DispatchQueue 2          priority 33
                Binary Images:
                       0x1011c9000 -        0x1011cbfff  logind <A9CB95FF-33BE-3EF8-AF0E-C5FD4A747C7E> /System/Library/CoreServices/logind
              Process:         loginwindow [54]
              Path:            /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
              Parent:          launchd [1]
              UID:             501
              Task size:       5886 pages
                Thread 0x29a      DispatchQueue 1          priority 48
                  10 ??? (loginwindow + 23464) [0x106da4ba8]
                Thread 0x34a      DispatchQueue 2          priority 50
                Thread 0x880a6    priority 48
                Thread 0x880a7    priority 48
                Thread 0x880a8    priority 50
                Binary Images:
                       0x106d9f000 -        0x106e31ff7  com.apple.loginwindow 8.3 (8.3) <AB3B6690-DF7F-32E1-84CB-3102AC24E5E5> /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
              Process:         lsboxd [324]
              Path:            /usr/libexec/lsboxd
              UID:             501
              Task size:       981 pages
                Thread 0x2a952    DispatchQueue 7          priority 31
                Thread 0x2a954    DispatchQueue 2          priority 33
                Binary Images:
                       0x10f616000 -        0x10f619ff7  lsboxd <2ADCB5AD-2AF5-3678-A383-284C26A1AD2F> /usr/libexec/lsboxd
              Process:         mDNSResponder [51]
              Path:            /usr/sbin/mDNSResponder
              Parent:          launchd [1]
              UID:             65
              Sudden Term:     Clean
              Task size:       992 pages
                Thread 0x297      DispatchQueue 1          priority 31
                10 start + 52 (mDNSResponder) [0x1089d26ac]
                  10 main + 3362 (mDNSResponder) [0x10899fca4]
                Thread 0x2f7      DispatchQueue 2          priority 33
                Thread 0x375      priority 31
                Binary Images:
                       0x10899e000 -        0x108a2dfff  mDNSResponder <1792F6EF-2D34-3047-89FC-1643D1C5C214> /usr/sbin/mDNSResponder
              Process:         mds [50]
              Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/m ds
              Parent:          launchd [1]
              UID:             0
              Task size:       24459 pages (+60)
              CPU Time:        0.002s
                Thread 0x296      DispatchQueue 1          priority 31
                  10 ??? (mds + 58484) [0x107684474]
                Thread 0x2e2      DispatchQueue 2          priority 33
                Thread 0x31f      priority 50
                Thread 0x85f0a    priority 31
                Thread 0x86385    priority <multiple> cpu time   0.002s
                Thread 0x8701f    priority <multiple>
                Thread 0x87923    priority 0
                Binary Images:
                       0x107676000 -        0x107795fff  mds <72984FB4-5955-3336-9DF3-C079D3126DEF> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/m ds
              Process:         mdworker [254]
              Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
              UID:             89
              Sudden Term:     Clean
              Task size:       1607 pages (+158)
              CPU Time:        0.030s
              Note:            Self-throttled
                Thread 0xf91      DispatchQueue 1          priority 0
                  10 ??? (mdworker + 35721) [0x10df04b89]
                Thread 0xf92      DispatchQueue 2          priority 4
                Thread 0xf9b      priority 4          cpu time   0.030s
                    10 ??? (mdworker + 47938) [0x10df07b42]
                      10 ??? (mdworker + 50346) [0x10df084aa]
                Thread 0x880c6    priority 4
                Binary Images:
                       0x10defc000 -        0x10df55ff7  mdworker <14E7C3D3-F1FC-3071-955F-793152A637E2> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
              Process:         mdworker [521]
              UID:             501
              Sudden Term:     Clean
              Task size:       6701 pages
              CPU Time:        0.001s
                Thread 0x780e3    DispatchQueue 1          priority 0
                  10 ??? (mdworker + 35721) [0x10252bb89]
                Thread 0x780e5    DispatchQueue 2          priority 4
                Thread 0x780f3    priority 4          cpu time   0.001s
                    10 ??? (mdworker + 47938) [0x10252eb42]
                      10 ??? (mdworker + 50346) [0x10252f4aa]
                Thread 0x7959d    priority 4
                    10 ??? (mdworker + 118233) [0x10253fdd9]
                Thread 0x8814f    priority 4
                Binary Images:
                       0x102523000 -        0x10257cff7  mdworker <14E7C3D3-F1FC-3071-955F-793152A637E2> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
              Process:         mdwrite [557]
              Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdwrite
              UID:             501
              Sudden Term:     Clean
              Task size:       935 pages
                Thread 0x8705f    DispatchQueue 7          priority 31
                Thread 0x87060    DispatchQueue 2          priority 33
                Binary Images:
                       0x10e730000 -        0x10e749ff7  mdwrite <A5FBF1B5-D076-391A-9BC7-9FE4E65499C4> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdwrite
              Process:         Messages [221]
              Path:            /Applications/Messages.app/Contents/MacOS/Messages
              UID:             501
              Task size:       15198 pages
                Thread 0xbd6      DispatchQueue 1          priority 46
                Thread 0xbdf      DispatchQueue 2          priority 48
                Thread 0xcca      priority 62
                    10 CAPThread::Entry(CAPThread*) + 156 (CoreMediaIO) [0x7fff943df2ce]
                      10 CMIO::DAL::RunLoop::OwnThread(void*) + 146 (CoreMediaIO) [0x7fff943e76e8]
                Thread 0xccf      priority 46
                Thread 0xcd0      priority 46
                    10 TPRecvProc + 436 (VideoConference) [0x7fff8c339e27]
                      10 VTP_Select + 1247 (VideoConference) [0x7fff8c3d9d3b]
                Thread 0xcd2      priority 46
                Thread 0xcd5      priority 62
                Thread 0xcda      priority 46
                    10 WTF::wtfThreadEntryPoint(void*) + 15 (JavaScriptCore) [0x7fff8acc725f]
                      10 JSC::BlockAllocator::blockFreeingThreadMain() + 90 (JavaScriptCore) [0x7fff8acb1bfa]
                        10 WTF::ThreadCondition::timedWait(WTF::Mutex&, double) + 118 (JavaScriptCore) [0x7fff8aa8eb66]
                Thread 0xcdb      priority 46
                      10 JSC::MarkStackThreadSharedData::markingThreadMain() + 214 (JavaScriptCore) [0x7fff8ac148b6]
                        10 JSC::SlotVisitor::drainFromShared(JSC::SlotVisitor::SharedDrainMode) + 212 (JavaScriptCore) [0x7fff8ac149d4]
                Thread 0xcdc      priority 46
                Thread 0xcdd      priority 46
                Thread 0x84bfc    priority 53
                    10 startIOThread(void*) + 148 (CoreVideo) [0x7fff94b1bfd7]
                      10 CVDisplayLink::runIOThread() + 689 (CoreVideo) [0x7fff94b1c2a1]
                Binary Images:
                       0x10c4d5000 -        0x10c775ff7  com.apple.iChat 7.0.1 (3322) <64949850-2AF2-3281-8043-859DAD2B7438> /Applications/Messages.app/Contents/MacOS/Messages
                    0x7fff8aa88000 -     0x7fff8ad23ff7  com.apple.JavaScriptCore 8536 (8536.30) <FE3C5ADD-43D3-33C9-9150-8DCEFDA218E2> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                    0x7fff8c328000 -     0x7fff8c441fff  com.apple.viceroy.framework 463 (463) <344D48A4-80DF-3C06-A28F-132858F00985> /System/Library/PrivateFrameworks/VideoConference.framework/Versions/A/VideoConference
                    0x7fff943dd000 -     0x7fff9442afff  com.apple.CoreMediaIO 309.0 (4163.1) <8FD1C1A9-25C5-3B9E-A76D-BE813253B358> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                    0x7fff94b1a000 -     0x7fff94b44ff7  com.apple.CoreVideo 1.8 (99.4) <E5082966-6D81-3973-A05A-38AA5B85F886> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
              Process:         Microsoft AU Daemon [228]
              Path:            /Library/Application Support/Microsoft/*/Microsoft AutoUpdate.app/Contents/MacOS/Microsoft AU Daemon.app/Contents/MacOS/Microsoft AU Daemon
              Architecture:    i386
              UID:             501
              Task size:       986 pages
              Process:         Microsoft Database Daemon [222]
              Path:            /Applications/Microsoft Office 2011/*/Microsoft Database Daemon.app/Contents/MacOS/Microsoft Database Daemon
              Architecture:    i386
              UID:             501
              Task size:       2978 pages
              Process:         Microsoft Outlook [218]
              Path:            /Applications/Microsoft Office 2011/Microsoft Outlook.app/Contents/MacOS/Microsoft Outlook
              Architecture:    i386
              UID:             501
              Task size:       18349 pages
              CPU Time:        0.006s
              Process:         netbiosd [91]
              Path:            /usr/sbin/netbiosd
              Parent:          launchd [1]
              UID:             222
              Sudden Term:     Clean
              Task size:       896 pages
                Thread 0x3ae      DispatchQueue 2          priority 4
                Thread 0x3b0      DispatchQueue 7          priority 4
                Binary Images:
                       0x100fb5000 -        0x101007ff7  netbiosd <4922874C-4FA5-3B80-B887-55240CB9EEFF> /usr/sbin/netbiosd
              Process:         NetworkBrowserAgent [175]
              Path:            /System/Library/CoreServices/NetworkBrowserAgent
              UID:             501
              Sudden Term:     Clean
              Task size:       1414 pages (+3)
                Thread 0x70b      DispatchQueue 1          priority 31
                  10 main + 120 (NetworkBrowserAgent) [0x1053e9775]
                Thread 0x727      DispatchQueue 2          priority 33
                Thread 0x738      priority 31
                Thread 0x8828a    priority 31
                Binary Images:
                       0x1053b9000 -        0x105401fff  NetworkBrowserAgent <B24A4121-BCE9-37EE-8885-1F4D1BECF3BE> /System/Library/CoreServices/NetworkBrowserAgent
              Process:         networkd [90]
              Path:            /usr/libexec/networkd
              Parent:          launchd [1]
              UID:             24
              Task size:       379 pages
                Thread 0x381      DispatchQueue 2          priority 33
                Thread 0x384      DispatchQueue 7          priority 31
                Binary Images:
                       0x101d27000 -        0x101d2dff7  networkd <5612B489-6A6B-39A2-9AAC-834F5409D9CA> /usr/libexec/networkd
              Process:         NexDef [167]
              Path:            /Users/USER/Library/Application Support/Nexdef/Nexdef.app/Contents/MacOS/NexDef
              UID:             501
              Task size:       10140 pages
              Process:         NotificationCenter [152]
              Path:            /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
              UID:             501
              Task size:       4284 pages (+3)
                Thread 0x67c      DispatchQueue 1          priority 31
                  10 ??? (NotificationCenter + 5072) [0x10cf613d0]
                Thread 0x71e      DispatchQueue 2          priority 33
                Thread 0x7e6      priority 38
                Thread 0x88287    priority 31
                Binary Images:
                       0x10cf60000 -        0x10cfa0fff  com.apple.notificationcenterui 1.0 (111.7) <EF72B34F-7764-3468-8DCE-80B99D082BF5> /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
              Process:         notifyd [14]
              Path:            /usr/sbin/notifyd
              Parent:          launchd [1]
              UID:             0
              Task size:       488 pages
                Thread 0x15f      DispatchQueue 2          priority 33
                10 ??? [0x7fff926179ee]
                  10 ??? [0x7fff8a254d16]
                Thread 0x160      DispatchQueue 7          priority 31
                10 ??? [0x7fff92614d85]
                  10 ??? [0x7fff8a254566]
                Thread 0x881ce    priority 31
                10 ??? [0x7fff8d5ba191]
                  10 ??? [0x7fff8d5cfce3]
                    10 ??? [0x7fff8a2546d6]
                Binary Images:
              Process:         ntpd [80]
              Path:            /usr/sbin/ntpd
              Parent:          launchd [1]
              UID:             0
              Task size:       374 pages
                Thread 0x333      DispatchQueue 1          priority 31
                  10 ??? (ntpd + 143653) [0x10b67a125]
                    10 ??? (ntpd + 144853) [0x10b67a5d5]
                      10 __sigsuspend + 10 (libsystem_kernel.dylib) [0x7fff8a254552]
                Thread 0x1f66     DispatchQueue 2          priority 33
                Binary Images:
                       0x10b657000 -        0x10b6adff7  ntpd <620BA025-EBF8-3704-8229-A17D4B371F9F> /usr/sbin/ntpd
              Process:         ocspd [452]
              Path:            /usr/sbin/ocspd
              Parent:          launchd [1]
              UID:             0
              Sudden Term:     Clean
              Task size:       1260 pages
                Thread 0x5d9a8    DispatchQueue 1          priority 31
                  10 ??? (ocspd + 17983) [0x10abad63f]
                    10 ??? (ocspd + 58188) [0x10abb734c]
                      10 ??? (ocspd + 58845) [0x10abb75dd]
                Thread 0x87dd4    DispatchQueue 2          priority 33
                Thread 0x87dd2    priority 31
                    10 ??? (ocspd + 63859) [0x10abb8973]
                      10 ??? (ocspd + 60287) [0x10abb7b7f]
                Thread 0x87dd9    priority 31
                Binary Images:
                       0x10aba9000 -        0x10abc6ff7  ocspd <29C27AFD-6A43-3AD3-B526-289434CBEBBA> /usr/sbin/ocspd
              Process:         opendirectoryd [21]
              Path:            /usr/libexec/opendirectoryd
              Architecture:    x86_64
              Parent:          launchd [1]
              UID:             0
              Sudden Term:     Clean
              Task size:       2958 pages
                Thread 0x18c      DispatchQueue 2          priority 33
                Thread 0x191      DispatchQueue 6          priority 31
                    10 _dispatch_worker_thread2 + 304 (libdispatch.dylib) [0x7fff926161fa]
                          10 ??? (opendirectoryd + 110174) [0x103efbe5e]
                Thread 0x193      DispatchQueue 6          priority 31
                          10 __systemcache_mig_initialize_block_invoke_026 + 39 (SystemCache) [0x1045266f5]
                            10 mach_msg_server + 289 (libsystem_kernel.dylib) [0x7fff8a252405]
                Thread 0x1a1      DispatchQueue 6          priority 31
                          10 __systemcache_mig_initialize_block_invoke_0 + 39 (SystemCache) [0x10452661b]
                Thread 0x18e      DispatchQueue 7          priority 31
                Thread 0x1a0      DispatchQueue 765        priority 31
                        10 _dispatch_async_f_redirect_invoke + 117 (libdispatch.dylib) [0x7fff9261a317]
                              10 __syscall + 10 (libsystem_kernel.dylib) [0x7fff8a2545de]
                Thread 0x881d2    priority 31
                Thread 0x881d3    priority 31
                Thread 0x881d4    priority 31
                Thread 0x881d5    priority 31
                Binary Images:
                       0x103ee1000 -        0x103f42fff  opendirectoryd <510CC3B0-83A3-32AD-A870-60BCCE97C161> /usr/libexec/opendirectoryd
                       0x104507000 -        0x104537ff7  com.apple.opendirectoryd.module.SystemCache 10.8 (197.17.2) <A177FD72-01A8-36C7-AB0D-F4349CBFE7FD> /System/Library/OpenDirectory/Modules/SystemCache.bundle/Contents/MacOS/SystemCache
              Process:         pboard [138]
              Path:            /usr/sbin/pboard
              Parent:          launchd [126]
              UID:             501
              Sudden Term:     Clean
              Task size:       249 pages
                Thread 0x641      DispatchQueue 1          priority 31
                  10 ??? (pboard + 2225) [0x10e56c8b1]
                    10 mach_msg_server + 552 (libsystem_kernel.dylib) [0x7fff8a25250c]
                Binary Images:
                       0x10e56c000 -        0x10e56cff7  pboard <820FD61C-E0A7-389D-9B14-C0B17C66743D> /usr/sbin/pboard
              Process:         pbs [230]
              Path:            /System/Library/CoreServices/pbs
              UID:             501
              Task size:       1153 pages
                Thread 0xcfa      DispatchQueue 2          priority 33
                Thread 0xcfd      DispatchQueue 7          priority 31
                Binary Images:
                       0x10c9a0000 -        0x10c9b4fff  pbs <943832C0-58FC-3DBD-BDB9-F6BC0D2128A0> /System/Library/CoreServices/pbs
              Process:         powerd [18]
              Path:            /System/Library/CoreServices/powerd.bundle/powerd
              Parent:          launchd [1]
              UID:             0
              Task size:       636 pages
                Thread 0x168      DispatchQueue 1          priority 31
                  10 main + 2157 (powerd) [0x109c64531]
                Thread 0x16e      DispatchQueue 2          priority 33
                Binary Images:
                       0x109c5e000 -        0x109c7cff7  powerd <B7E168F1-5AE4-3DD3-ABAC-C6CA1AECE0CD> /System/Library/CoreServices/powerd.bundle/powerd
              Process:         PTPCamera [201]
              Path:            /System/Library/Image Capture/Devices/PTPCamera.app/Contents/MacOS/PTPCamera
              UID:             501
              Sudden Term:     Dirty
              Task size:       3850 pages
                Thread 0x90e      DispatchQueue 1          priority 47
                  10 ICD_main + 24 (ICADevices) [0x10c85fc66]
                    10 ICAApplicationMain + 470 (ICADevices) [0x10c85459e]
                Thread 0x911      DispatchQueue 2          priority 49
                Thread 0x9a3      priority 47
                    10 -[PTPTransport callbackThreadFunction] + 304 (PTPCamera) [0x10c7fb729]
                Thread 0xb5a      priority 47
                Binary Images:
                       0x10c7f8000 -        0x10c82ffff  com.apple.PTPCamera 8.0.5 (8.0.5) <40F62D32-7907-38E1-BE79-B0EF61D4C30E> /System/Library/Image Capture/Devices/PTPCamera.app/Contents/MacOS/PTPCamera
                       0x10c853000 -        0x10c87ffff  com.apple.ICADevices 8.0.2 (8.0.2) <A00B1AB2-746E-3204-AEE5-ABDFFF29208B> /System/Library/Frameworks/ICADevices.framework/Versions/A/ICADevices
              Process:         quicklookd [321]
              Path:            /System/Library/Frameworks/QuickLook.framework/Resources/quicklookd.app/Contents/MacOS/qu icklookd
              UID:             501
              Sudden Term:     Clean
              Task size:       5999 pages
                Thread 0x2a306    DispatchQueue 1          priority 46
                  10 ??? (quicklookd + 15200) [0x1082fbb60]
                Thread 0x2a30d    DispatchQueue 2          priority 48
                   *10 ??? (mach_kernel + 3504704) [0xffffff8000557a40]
                Thread 0x2a317    priority 46
                      10 ??? (quicklookd + 28185) [0x1082fee19]
                Thread 0x2a5a6    priority 46
                      10 ??? (quicklookd + 219853) [0x10832dacd]
                Binary Images:
                       0x1082f8000 -        0x108358ff7  com.apple.QuickLookDaemon 4.0 (555.5) <1B919564-931F-3540-9BE3-0734E1F93450> /System/Library/Frameworks/QuickLook.framework/Resources/quicklookd.app/Contents/MacOS/qu icklookd
              Process:         QuickLookSatellite [518]
              Path:            /System/Library/Frameworks/QuickLook.framework/Versions/A/Resources/quicklookd.app/Conten ts/XPCServices/QuickLookSatellite.xpc/Contents/MacOS/QuickLookSatellite
              Parent:          launchd [1]
              UID:             501
              Task size:       5917 pages
                Thread 0x7808b    DispatchQueue 1          priority 46
                Thread 0x78091    DispatchQueue 2          priority 48
                Thread 0x88106    priority 46
                Binary Images:
                       0x1043fb000 -        0x104400fff  com.apple.quicklook.satellite 4.0 (521.1) <9CFFD831-8BE2-3CAA-8838-CB585D75F06A> /System/Library/Frameworks/QuickLook.framework/Versions/A/Resources/quicklookd.app/Conten ts/XPCServices/QuickLookSatellite.xpc/Contents/MacOS/QuickLookSatellite
              Process:         revisiond [45]
              Path:            /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisi ond
              Parent:          launchd [1]
              UID:             0
              Task size:       767 pages
                Thread 0x2ca      DispatchQueue 2          priority 33
                Thread 0x2d6      DispatchQueue 7          priority 31
                   *10 ??? (mach_kernel + 3613728) [0xffffff8000572420]
                Thread 0x2d4      priority 31
                             *10 ??? (mach_kernel + 1109817) [0xffffff800030ef39]
                               *10 VNOP_READ + 77 (mach_kernel) [0xffffff8000318f5d]
                                 *10 spec_read + 187 (mach_kernel) [0xffffff800032720b]
                                   *10 cdev_read + 99 (AppleFSCompressionTypeDataless) [0xffffff7f825a79a4]
                                     *10 msleep + 116 (mach_kernel) [0xffffff8000572244]
                                       *10 ??? (mach_kernel + 3612246) [0xffffff8000571e56]
                                         *10 lck_mtx_sleep + 78 (mach_kernel) [0xffffff800022666e]
                Thread 0x2d5      priority 31
                10 fsctl + 10 (libsystem_kernel.dylib) [0x7fff8a254a5a]
                     *10 fsctl + 342 (mach_kernel) [0xffffff800030a4f6]
                       *10 ??? (mach_kernel + 1091694) [0xffffff800030a86e]
                         *10 ??? (mach_kernel + 1098850) [0xffffff800030c462]
                Binary Images:
                       0x10481b000 -        0x10486cfff  revisiond <6FF2058C-8B8C-3E35-A3A6-CE72DCCF5E70> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisi ond
              *0xffffff7f825a6000 - 0xffffff7f825a7ff7  com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 49 (1.0.0d1) <D525C3A2-36A3-3233-BF57-C215580A25AB> /System/Library/Extensions/AppleFSCompressionTypeDataless.kext/Contents/MacOS/AppleFSComp ressionTypeDataless
              Process:         Safari [204]
              Path:            /Applications/Safari.app/Contents/MacOS/Safari
              UID:             501
              Task size:       73682 pages
                Thread 0x9b7      DispatchQueue 1          priority 46
                  10 SafariMain + 266 (Safari) [0x10f85e34c]
                        10 -[BrowserApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 161 (Safari) [0x10f699aef]
                                           *10 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                Thread 0x9c7      DispatchQueue 2          priority 48
                Thread 0x9d0      priority 46
                    10 WTF::wtfThreadEntryPoint(void*) + 15 (JavaScriptCore) [0x10fff25ef]
                      10 WebCore::IconDatabase::iconDatabaseSyncThread() + 303 (WebCore) [0x110b4583f]
                        10 WebCore::IconDatabase::syncThreadMainLoop() + 491 (WebCore) [0x110b48c2b]
                           *10 psynch_cvcontinue + 0 (mach_kernel) [0xffffff80005bdcb0]
                Thread 0x9d8      priority 62
                Thread 0x9d9      priority 62
                Thread 0xa03      priority 46
                      10 JSC::BlockAllocator::blockFreeingThreadMain() + 261 (JavaScriptCore) [0x10fffcd75]
                Thread 0xa04      priority 46
                      10 JSC::GCThread::gcThreadMain() + 88 (JavaScriptCore) [0x10fffd688]
                        10 JSC::GCThread::waitForNextPhase() + 119 (JavaScriptCore) [0x10fffd7f7]
                Thread 0xa05      priority 46
                Thread 0xa06      priority 46
                Thread 0xa07      priority 46
                Thread 0xa08      priority 46
                Thread 0xa09      priority 46
                Thread 0xa54      priority 46
                      10 Safari::MessageRunLoop::threadBody() + 119 (Safari) [0x10f8111d1]
                Thread 0x1040     priority 46
                Thread 0x296b2    priority 53
                Thread 0x84ddb    priority 46
                     *10 ??? (mach_kernel + 3943920) [0xffffff80005c2df0]
                Binary Images:
                       0x10f632000 -        0x10f632fff  com.apple.Safari 6.1.1 (8537.73.11) <16DD7DFC-B1F9-324D-8BE6-1AEC2446E928> /Applications/Safari.app/Contents/MacOS/Safari
                       0x10f63d000 -        0x10fc18fff  com.apple.Safari.framework 8537 (8537.73.11) <6E26A6FA-2D6E-3540-A3E2-7CFDA6BEA700> /System/Library/StagedFrameworks/Safari/Safari.framework/Safari
                       0x10ffe9000 -        0x11038efff  com.apple.JavaScriptCore 8537 (8537.73.10) <70ECF2B6-F6A1-3975-8598-AC0A62207151> /System/Library/StagedFrameworks/Safari/JavaScriptCore.framework/JavaScriptCore
                       0x110b40000 -        0x111c07fff  com.apple.WebCore 8537 (8537.73.13) <D924D5C2-6819-3559-91B5-48FDF841BFA9> /System/Library/StagedFrameworks/Safari/WebCore.framework/WebCore
              Process:         securityd [15]
              Path:            /usr/sbin/securityd
              Parent:          launchd [1]
              UID:             0
              Sudden Term:     Dirty
              Task size:       1888 pages
                Thread 0x163      DispatchQueue 1          priority 31
                  10 ??? (securityd + 243976) [0x10bb20908]
                    10 ??? (securityd + 568332) [0x10bb6fc0c]
                      10 ??? (securityd + 62883) [0x10baf45a3]
                Thread 0x1c1      DispatchQueue 2          priority 33
                Thread 0x1c2      priority 31
                    10 ??? (securityd + 61637) [0x10baf40c5]
                      10 ??? (securityd + 372104) [0x10bb3fd88]
                        10 au_sdev_read_aia + 118 (libbsm.0.dylib) [0x7fff8b3ee822]
                          10 fgetc + 50 (libsystem_c.dylib) [0x7fff8d635cb3]
                            10 __srget + 17 (libsystem_c.dylib) [0x7fff8d639fa3]
                              10 __srefill1 + 27 (libsystem_c.dylib) [0x7fff8d639e63]
                                10 __read_nocancel + 10 (libsystem_kernel.dylib) [0x7fff8a254282]
                                               *10 ??? (mach_kernel + 3395222) [0xffffff800053ce96]
                Thread 0x840b2    priority 31
                      10 ??? (securityd + 61813) [0x10baf4175]
                Binary Images:
                       0x10bae5000 -        0x10bbeffff  securityd <6C9489BB-46BF-3025-954F-58F423803CC1> /usr/sbin/securityd
                    0x7fff8b3df000 -     0x7fff8b3f2ff7  libbsm.0.dylib <F497D3CE-40D9-3551-84B4-3D5E39600737> /usr/lib/libbsm.0.dylib
              *0xffffff8000200000 - 0xffffff8000741d0c  mach_kernel <EA38B02E-2B88-309F-BA68-1DE29F605DD8> /mach_kernel
              Process:         SleepServicesD [43]
              Path:            /System/Library/CoreServices/SleepServicesD
              Parent:          launchd [1]
              UID:             0
              Task size:       473 pages
                Thread 0x28f      DispatchQueue 1          priority 31
                10 start + 1 (libdyld.dylib) [0x7fff8c95c7e1]
                  10 ??? (SleepServicesD + 3974) [0x1082e4f86]
                        10 CFRunLoopRunSpecific + 290 (CoreFoundation) [0x7fff945250e2]
                          10 __CFRunLoopRun + 1078 (CoreFoundation) [0x7fff94525916]
                            10 __CFRunLoopServiceMachPort + 195 (CoreFoundation) [0x7fff94520233]
                              10 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff8a252686]
                Thread 0x2b8      DispatchQueue 2          priority 33
                10 _dispatch_mgr_thread + 54 (libdispatch.dylib) [0x7fff926179ee]
                  10 kevent + 10 (libsystem_kernel.dylib) [0x7fff8a254d16]
                Binary Images:
                       0x1082e4000 -        0x1082ebfff  SleepServicesD <C3646341-90C3-3E5C-9160-189348BB7ECC> /System/Library/CoreServices/SleepServicesD
                    0x7fff8a242000 -     0x7fff8a25dff7  libsystem_kernel.dylib <4B7993C3-F62D-3AC1-AF92-414A0D6EED5E> /usr/lib/system/libsystem_kernel.dylib
                    0x7fff8c95a000 -     0x7fff8c95dff7  libdyld.dylib <F59367C9-C110-382B-A695-9035A6DD387E> /usr/lib/system/libdyld.dylib
              Process:         spindump [566]
              Path:            /usr/sbin/spindump
              Parent:          launchd [1]
              UID:             0
              Sudden Term:     Dirty
              Task size:       1165 pages (+651)
              CPU Time:        0.047s
                Thread 0x881cb    DispatchQueue 1          priority 31
                  10 ??? (spindump + 6841) [0x10247dab9]
                Thread 0x881cc    DispatchQueue 2          priority 33         cpu time   0.001s
                   *6 hndl_unix_scall64 + 19 (mach_kernel) [0xffffff80002cf453]
                     *6 unix_syscall64 + 522 (mach_kernel) [0xffffff80005e97ba]
                       *6 kevent + 52 (mach_kernel) [0xffffff8000556494]
                         *6 ??? (mach_kernel + 3500251) [0xffffff80005568db]
                           *6 kqueue_scan + 187 (mach_kernel) [0xffffff80005572ab]
                             *6 thread_block_reason + 275 (mach_kernel) [0xffffff800022db83]
                               *6 ??? (mach_kernel + 187921) [0xffffff800022de11]
                                 *6 processor_idle + 237 (mach_kernel) [0xffffff800022f35d]
                                   *6 machine_idle + 434 (mach_kernel) [0xffffff80002ba222]
                   *4 ??? (mach_kernel + 3504704) [0xffffff8000557a40]
                Thread 0x881cd    DispatchQueue 15         priority 31         cpu time   0.046s
                                     *10 stack_snapshot2 + 169 (mach_kernel) [0xffffff8000545bd9]
                Thread 0x881fc    priority 31
                Thread 0x881fd    priority 31
                Thread 0x881fe    priority 31
                Thread 0x881ff    priority 31
                Thread 0x88200    priority 31
                Thread 0x88201    priority 31
                Thread 0x88202    priority 31
                Thread 0x88203    priority 31
                Thread 0x88204    priority 31
                Thread 0x88205    priority 31
                Thread 0x88206    priority 31
                Thread 0x88207    priority 31
                Thread 0x88208    priority 31
                Thread 0x88209    priority 31
                Thread 0x8820a    priority 31
                Thread 0x8820b    priority 31
                Thread 0x8820c    priority 31
                Thread 0x8820d    priority 31
                Thread 0x8820e    priority 31
                Thread 0x8820f    priority 31
                Thread 0x88210    priority 31
                Thread 0x88211    priority 31
                Thread 0x88212    priority 31
                Thread 0x88213    priority 31
                Thread 0x88214    priority 31
                Thread 0x88215    priority 31
                Thread 0x88216    priority 31
                Thread 0x88217    priority 31
                Thread 0x88218    priority 31
                Thread 0x88219    priority 31
                Thread 0x8821a    priority 31
                Thread 0x8821b    priority 31
                Thread 0x8821c    priority 31
                Thread 0x8821d    priority 31
                Thread 0x8821e    priority 31
                Thread 0x8821f    priority 31
                Thread 0x88220    priority 31
                Thread 0x88221    priority 31
                Thread 0x88222    priority 31
                Thread 0x88223    priority 31
                Thread 0x88224    priority 31
                Thread 0x88225    priority 31
                Thread 0x88226    priority 31
                Thread 0x88227    priority 31
                Thread 0x88228    priority 31
                Thread 0x88229    priority 31
                Thread 0x8822a    priority 31
                Thread 0x8822b    priority 31
                Thread 0x8822c    priority 31
                Thread 0x8822d    priority 31
                Thread 0x8822e    priority 31
                Thread 0x8822f    priority 31
                Thread 0x88230    priority 31
                Thread 0x88231    priority 31
                Thread 0x88232    priority 31
                Thread 0x88233    priority 31
                Thread 0x88234    priority 31
                Thread 0x88235    priority 31
                Thread 0x88236    priority 31
                Thread 0x88237    priority 31
                Thread 0x88238    priority 31
                Thread 0x88239    priority 31
                Thread 0x8823a    priority 31
                Thread 0x8823b    priority 31
                Thread 0x8823c    priority 31
                Thread 0x8823d    priority 31
                Thread 0x8823e    priority 31
                Thread 0x8823f    priority 31
                Thread 0x88240    priority 31
                Thread 0x88241    priority 31
                Thread 0x88242    priority 31
                Thread 0x88243    priority 31
                Thread 0x88244    priority 31
                Thread 0x88245    priority 31
                Thread 0x88246    priority 31
                Thread 0x88247    priority 31
                Thread 0x88248    priority 31
                Thread 0x88249    priority 31
                Thread 0x8824a    priority 31
                Thread 0x8824b    priority 31
                Thread 0x8824c    priority 31
                Thread 0x8824d    priority 31
                Thread 0x8824e    priority 31
                Thread 0x881fa    priority 31
                8 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8d5ba191]
                  8 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8d5cfce3]
                    8 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8a2546d6]
                     *8 ??? (mach_kernel + 3943920) [0xffffff80005c2df0]
                Thread 0x881fb    priority 31
                Thread 0x881f9    priority 31
                Thread 0x881f7    priority 31
                Thread 0x881f8    priority 31
                Thread 0x881f5    priority 31
                Thread 0x881f6    priority 31
                Thread 0x881f3    priority 31
                4 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8d5ba191]
                  4 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8d5cfce3]
                    4 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8a2546d6]
                     *4 ??? (mach_kernel + 3943920) [0xffffff80005c2df0]
                Thread 0x881f4    priority 31
                Thread 0x881f1    priority 31
                3 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8d5ba191]
                  3 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8d5cfce3]
                    3 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8a2546d6]
                     *3 ??? (mach_kernel + 3943920) [0xffffff80005c2df0]
                Thread 0x881f2    priority 31
                Thread 0x881ed    priority 31
                2 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8d5ba191]
                  2 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8d5cfce3]
                    2 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8a2546d6]
                     *2 ??? (mach_kernel + 3943920) [0xffffff80005c2df0]
                Thread 0x881ee    priority 31
                Thread 0x881f0    priority 31
                Thread 0x881d0    DispatchQueue 30         priority 33
                              1 ??? (spindump + 55553) [0x102489901]
                                1 ??? (spindump + 21934) [0x1024815ae]
                                  1 ??? (spindump + 16084) [0x10247fed4]
                                    1 _dispatch_barrier_sync_f_invoke + 39 (libdispatch.dylib) [0x7fff92616723]
                                        1 ??? (spindump + 14871) [0x10247fa17]
                                          1 dispatch_once_f + 50 (libdispatch.dylib) [0x7fff92615041]
                                              1 ??? (spindump + 61819) [0x10248b17b]
                                                1 __system_launchdJobCopyDictionary + 143 (ServiceManagement) [0x7fff894bfc15]
                                                  1 launchdadd_msg_launchd_request + 165 (ServiceManagement) [0x7fff894ba96c]
                                                     *1 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                Thread 0x881cf    priority 31
                  1 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8d5cfce3]
                    1 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8a2546d6]
                     *1 ??? (mach_kernel + 3943920) [0xffffff80005c2df0]
                Thread 0x881ef    priority 31
                Binary Images:
                       0x10247c000 -        0x102497fff  spindump <A8CC3677-7EB4-3861-ABC1-5B4534955859> /usr/sbin/spindump
                    0x7fff894b9000 -     0x7fff894c4ff7  com.apple.bsd.ServiceManagement 2.0 (2.0) <C12962D5-85FB-349E-AA56-64F4F487F219> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                    0x7fff8d5b9000 -     0x7fff8d685ff7  libsystem_c.dylib <543B05AE-CFA5-3EFE-8E58-77225411BA6B> /usr/lib/system/libsystem_c.dylib
                    0x7fff92613000 -     0x7fff92628ff7  libdispatch.dylib <D26996BF-FC57-39EB-8829-F63585561E09> /usr/lib/system/libdispatch.dylib
                    0x7fff944f0000 -     0x7fff946daff7  com.apple.CoreFoundation 6.8 (744.19) <0F7403CA-2CB8-3D0A-992B-679701DF27CA> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
              Process:         spindump_agent [567]
              Path:            /usr/libexec/spindump_agent
              UID:             501
              Sudden Term:     Clean
              Task size:       480 pages
                Thread 0x881d1    priority 31
                  10 ??? (spindump_agent + 8236) [0x108e0b02c]
                    10 dispatch_main + 45 (libdispatch.dylib) [0x7fff92614c26]
                      10 pthread_exit + 30 (libsystem_c.dylib) [0x7fff8d5ced31]
                        10 _pthread_exit + 146 (libsystem_c.dylib) [0x7fff8d5cd9d2]
                          10 _pthread_tsd_cleanup + 240 (libsystem_c.dylib) [0x7fff8d5d452e]
                            10 _dispatch_queue_cleanup2 + 85 (libdispatch.dylib) [0x7fff92614c9a]
                              10 sleep$NOCANCEL + 61 (libsystem_c.dylib) [0x7fff8d622d59]
                                10 __semwait_signal_nocancel + 10 (libsystem_kernel.dylib) [0x7fff8a25439a]
                                 *10 semaphore_wait_continue + 0 (mach_kernel) [0xffffff8000234050]
                Thread 0x881d7    DispatchQueue 2          priority 33
                Thread 0x881d6    DispatchQueue 7          priority 31
                10 _dispatch_sig_thread + 45 (libdispatch.dylib) [0x7fff92614d85]
                  10 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib) [0x7fff8a254566]
                Thread 0x881d8    priority 33
                10 start_wqthread + 13 (libsystem_c.dylib) [0x7fff8d5ba191]
                  10 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff8d5cfce3]
                    10 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8a2546d6]
                Thread 0x881d9    priority 31
                Thread 0x881da    priority 31
                Thread 0x881db    priority 31
                Thread 0x881dc    priority 31
                Binary Images:
                       0x108e09000 -        0x108e0bff7  spindump_agent <BC7C5F3C-EBB9-38E8-92A7-DE23921F73F9> /usr/libexec/spindump_agent
              Process:         spindump_symbolicator [569]
              Path:            /usr/libexec/spindump_symbolicator
              Parent:          launchd [1]
              UID:             0
              Sudden Term:     Clean
              Task size:       439 pages (-3)
                Thread 0x88253    priority 31
                  9 ??? (spindump_symbolicator + 5078) [0x10c30a3d6]
                    9 dispatch_main + 45 (libdispatch.dylib) [0x7fff92614c26]
                      9 pthread_exit + 30 (libsystem_c.dylib) [0x7fff8d5ced31]
                        9 _pthread_exit + 146 (libsystem_c.dylib) [0x7fff8d5cd9d2]
                          9 _pthread_tsd_cleanup + 240 (libsystem_c.dylib) [0x7fff8d5d452e]
                            9 _dispatch_queue_cleanup2 + 85 (libdispatch.dylib) [0x7fff92614c9a]
                              9 sleep$NOCANCEL + 61 (libsystem_c.dylib) [0x7fff8d622d59]
                                9 __semwait_signal_nocancel + 10 (libsystem_kernel.dylib) [0x7fff8a25439a]
                                 *9 semaphore_wait_continue + 0 (mach_kernel) [0xffffff8000234050]
                Thread 0x88254    DispatchQueue 2          priority 33
                Thread 0x88256    DispatchQueue 7          priority 31
                9 _dispatch_sig_thread + 45 (libdispatch.dylib) [0x7fff92614d85]
                  9 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib) [0x7fff8a254566]
                Thread 0x88255    priority 31
                Thread 0x88258    priority 31
                2 thread_start + 13 (libsystem_c.dylib) [0x7fff8d5ba1a1]
                  2 _pthread_start + 327 (libsystem_c.dylib) [0x7fff8d5cd772]
                    2 ??? (CoreSymbolication + 90952) [0x7fff8c578348]
                      2 __semwait_signal + 10 (libsystem_kernel.dylib) [0x7fff8a254386]
                       *2 semaphore_wait_continue + 0 (mach_kernel) [0xffffff8000234050]
                Binary Images:
                       0x10c309000 -        0x10c30afff  spindump_symbolicator <11F50D3A-94EF-3D25-B98D-903F2592CFF5> /usr/libexec/spindump_symbolicator
                    0x7fff8c562000 -     0x7fff8c5fdfff  com.apple.CoreSymbolication 3.0 (117) <7D43ED93-BD81-338C-8076-6A932A1D19E8> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
              Process:         SpotifyWebHelper [166]
              Path:            /Users/USER/Library/Application Support/Spotify/SpotifyWebHelper
              Architecture:    i386
              UID:             501
              Task size:       822 pages
              Process:         stackshot [42]
              Path:            /usr/libexec/stackshot
              Parent:          launchd [1]
              UID:             0
              Sudden Term:     Clean
              Task size:       364 pages
                Thread 0x28e      DispatchQueue 1          priority 31
                  10 ??? (stackshot + 5915) [0x10b4c771b]
                    10 CFRunLoopRun + 97 (CoreFoundation) [0x7fff94533dd1]
                Thread 0x2b1      DispatchQueue 2          priority 33
                Thread 0x2e9      priority 31
                10 thread_start + 13 (libsystem_c.dylib) [0x7fff8d5ba1a1]
                  10 _pthread_start + 327 (libsystem_c.dylib) [0x7fff8d5cd772]
                    10 ??? (stackshot + 10344) [0x10b4c8868]
                      10 __sigwait + 10 (libsystem_kernel.dylib) [0x7fff8a25457a]
                           *10 __sigwait_nocancel + 362 (mach_kernel) [0xffffff800056eb8a]
                Binary Images:
                       0x10b4c6000 -        0x10b4c9fff  stackshot <3934B7F8-4AE5-39ED-AE78-3B2D3A075247> /usr/libexec/stackshot
              Process:         syslogd [19]
              Path:            /usr/sbin/syslogd
              Parent:          launchd [1]
              UID:             0
              Sudden Term:     Dirty
              Task size:       371 pages
                Thread 0x174      DispatchQueue 2          priority 33
                Thread 0x177      DispatchQueue 6          priority 31
                  10 _pthread_wqthread + 404 (libsystem_c.dylib) [0x7fff8d5cfcdb]
                      10 _dispatch_client_callout + 8 (libdispatch.dylib) [0x7fff926150b6]
                        10 _dispatch_call_block_and_release + 15 (libdispatch.dylib) [0x7fff92618f01]
                          10 ??? (syslogd + 50962) [0x102405712]
                            10 _vprocmgr_log_drain + 70 (liblaunch.dylib) [0x7fff9262f598]
                              10 ??? (liblaunch.dylib + 18464) [0x7fff9262d820]
                Thread 0x179      DispatchQueue 6          priority 31
                          10 ??? (syslogd + 34838) [0x102401816]
                Thread 0x178      DispatchQueue 7          priority 31
                Binary Images:
                       0x1023f9000 -        0x10240dff7  syslogd <94DBAC39-B93D-3479-BAD5-A354E78B4EC5> /usr/sbin/syslogd
                    0x7fff92629000 -     0x7fff92631fff  liblaunch.dylib <2F71CAF8-6524-329E-AC56-C506658B4C0C> /usr/lib/system/liblaunch.dylib
              Process:         syspolicyd [308]
              Path:            /usr/libexec/syspolicyd
              Parent:          launchd [1]
              UID:             0
              Task size:       1105 pages
                Thread 0x297a8    DispatchQueue 7          priority 31
                Thread 0x297aa    DispatchQueue 2          priority 33
                Binary Images:
                       0x106d05000 -        0x106d07ff7  syspolicyd <F902A19B-D3C9-35AD-AB32-0C7979328D45> /usr/libexec/syspolicyd
              Process:         SystemUIServer [143]
              Path:            /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
              UID:             501
              Sudden Term:     Clean
              Task size:       7591 pages
              CPU Time:        0.001s
                Thread 0x64b      DispatchQueue 1          priority 47         cpu time   0.001s
                  10 ??? (SystemUIServer + 83202) [0x105244502]
                    10 -[NSApplication run] + 517 (AppKit) [0x7fff9141e1a3]
                      10 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128 (AppKit) [0x7fff91426df2]
                        10 _DPSNextEvent + 685 (AppKit) [0x7fff91427533]
                          10 BlockUntilNextEventMatchingListInMode + 62 (HIToolbox) [0x7fff89952ae3]
                            10 ReceiveNextEventCommon + 356 (HIToolbox) [0x7fff89952c52]
                              10 RunCurrentEventLoopInMode + 209 (HIToolbox) [0x7fff89952eb4]
                Thread 0x669      DispatchQueue 2          priority 49
                Thread 0x915      priority 47
                    10 __select + 10 (libsystem_kernel.dylib) [0x7fff8a254322]
                Thread 0x87d6d    priority 47
                Thread 0x87d6e    priority 47
                Thread 0x87d6f    priority 47
              *10 ??? (mach_kernel + 3944432) [0xffffff80005c2ff0]
                Binary Images:
                       0x105230000 -        0x10528aff7  com.apple.systemuiserver 1.7 (369.2) <29E36EAF-F4BB-361E-9872-88278B609075> /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
                    0x7fff898f3000 -     0x7fff89c23fff  com.apple.HIToolbox 2.0 <656D08C2-9068-3532-ABDD-32EC5057CCB2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                    0x7fff912d2000 -     0x7fff91efffff  com.apple.AppKit 6.8 (1187.40) <F12CF463-6F88-32ED-9EBA-0FA2AD3CF576> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
              Process:         talagent [141]
              Path:            /System/Library/CoreServices/talagent
              UID:             501
              Sudden Term:     Clean
              Task size:       2155 pages (+3)
                Thread 0x649      DispatchQueue 1          priority 47
                  10 ??? (talagent + 8652) [0x10ae131cc]
                    10 ??? (talagent + 32130) [0x10ae18d82]
                Thread 0x657      DispatchQueue 2          priority 49
                Thread 0x88261    priority 47
                Binary Images:
                       0x10ae11000 -        0x10ae3cff7  talagent <43504756-26E6-3C6E-BCBD-D9130ABF7DAB> /System/Library/CoreServices/talagent
              Process:         taskgated [506]
              Path:            /usr/libexec/taskgated
              Parent:          launchd [1]
              UID:             0
              Task size:       890 pages
                Thread 0x6fcce    DispatchQueue 1          priority 31
                  10 ??? (taskgated + 7011) [0x1011dbb63]
                    10 ??? (taskgated + 26722) [0x1011e0862]
                      10 ??? (taskgated + 27379) [0x1011e0af3]
                Thread 0x6fcd0    DispatchQueue 2          priority 33
                Thread 0x86c29    priority 31
                    10 ??? (taskgated + 31885) [0x1011e1c8d]
                      10 ??? (taskgated + 28633) [0x1011e0fd9]
                Binary Images:
                       0x1011da000 -        0x1011e9ff7  taskgated <52F68683-D580-3266-8EB0-FE12A1C547DD> /usr/libexec/taskgated
              Process:         tccd [181]
              Path:            /System/Library/PrivateFrameworks/TCC.framework/Resources/tccd
              UID:             501
              Sudden Term:     Clean (allows idle exit)
              Task size:       1231 pages
                Thread 0x771      DispatchQueue 7          priority 31
                Thread 0x773      DispatchQueue 2          priority 33
                Binary Images:
                       0x10e0bf000 -        0x10e0c6fff  tccd <2CD13C97-6B64-3026-BFB7-03B28BDB503B> /System/Library/PrivateFrameworks/TCC.framework/Resources/tccd
              Process:         ubd [551]
              Path:            /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Support/ubd
              UID:             501
              Task size:       2456 pages
                Thread 0x86c28    DispatchQueue 1          priority 31
                  10 ??? (ubd + 626000) [0x10ecd3d50]
                Thread 0x86c2c    DispatchQueue 2          priority 33
                Thread 0x86c39    priority 31
                    10 ??? (ubd + 724495) [0x10ecebe0f]
                Thread 0x86c3a    priority 31
                    10 ??? (ubd + 419546) [0x10eca16da]
                Thread 0x86c3b    priority 31
                    10 ??? (ubd + 510008) [0x10ecb7838]
                Thread 0x86c3c    priority 31
                Thread 0x86c3e    priority 31
                    10 ??? (ubd + 214993) [0x10ec6f7d1]
                Thread 0x86c40    priority 31
                Binary Images:
                       0x10ec3b000 -        0x10ed4dff7  ubd <2FE100A5-E353-34A2-B9D4-BF3B1CF327CF> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Support/ubd
              Process:         usbmuxd [39]
              Path:            /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd
              Parent:          launchd [1]
              UID:             213
              Sudden Term:     Clean
              Task size:       764 pages
                Thread 0x28b      DispatchQueue 1          priority 31
                10 ??? (usbmuxd + 5832) [0x1000016c8]
                  10 ??? (usbmuxd + 9145) [0x1000023b9]
                Thread 0x318      DispatchQueue 2          priority 33
                Thread 0x31c      priority 31
                Binary Images:
                       0x100000000 -        0x100016ff7  usbmuxd <9CDB9FB7-62EE-3BEC-B03B-04356E387653> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd
              Process:         UserEventAgent [11]
              Path:            /usr/libexec/UserEventAgent
              Parent:          launchd [1]
              UID:             0
              Sudden Term:     Clean
              Task size:       1261 pages
                Thread 0x15b      DispatchQueue 1          priority 31
                  10 ??? (UserEventAgent + 5198) [0x10131344e]
                    10 -[NSRunLoop(NSRunLoop) run] + 74 (Foundation) [0x7fff8d1ef1aa]
                      10 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 268 (Foundation) [0x7fff8d2567ee]
                Thread 0x206      DispatchQueue 2          priority 33
                Thread 0x20c      priority 31
                    10 captived_thread + 1061 (CaptiveSystemAgent) [0x10266847e]
                Binary Images:
                       0x101312000 -        0x101314ff7  UserEventAgent <E31D6E1C-C264-383B-9A08-9B68A0528F26> /usr/libexec/UserEventAgent
                       0x102665000 -        0x102683fff  com.apple.CaptiveSystemAgent 12.0 (1.11) <29FA455E-E356-3F22-8314-5384ABE7CC34> /System/Library/UserEventPlugins/CaptiveSystemAgent.plugin/Contents/MacOS/CaptiveSystemAg ent
                    0x7fff8d1bb000 -     0x7fff8d51afff  com.apple.Foundation 6.8 (945.18) <1D7E58E6-FA3A-3CE8-AC85-B9D06B8C0AA0> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
              Process:         UserEventAgent [129]
              UID:             501
              Sudden Term:     Clean
              Task size:       2869 pages
                Thread 0x60b      DispatchQueue 1          priority 31
                  10 ??? (UserEventAgent + 5198) [0x10cb9d44e]
                Thread 0x63c      DispatchQueue 2          priority 33
                Thread 0x7a1      priority 31
                Thread 0x860a8    priority 31
                Binary Images:
                       0x10cb9c000 -        0x10cb9eff7  UserEventAgent <E31D6E1C-C264-383B-9A08-9B68A0528F26> /usr/libexec/UserEventAgent
              Process:         usernoted [148]
              Path:            /usr/sbin/usernoted
              UID:             501
              Task size:       1130 pages (+3)
                Thread 0x678      DispatchQueue 1          priority 31
                10 ??? (usernoted + 7044) [0x10dd68b84]
                  10 ??? (usernoted + 7333) [0x10dd68ca5]
                Thread 0x6e7      DispatchQueue 2          priority 33
                Thread 0x8829e    priority 31
                Binary Images:
                       0x10dd67000 -        0x10dd93fff  usernoted <CFD8B311-2547-38CF-858C-5C9A514298A2> /usr/sbin/usernoted
              Process:         VDCAssistant [223]
              Path:            /System/Library/Frameworks/CoreMediaIO.framework/Resources/VDC.plugin/Contents/Resources/ VDCAssistant
              Parent:          launchd [1]
              UID:             0
              Task size:       1503 pages
                Thread 0xc0a      DispatchQueue 1          priority 31
                  10 ??? (VDCAssistant + 234242) [0x10f220302]
                Thread 0xc10      DispatchQueue 2          priority 33
                Thread 0xc0f      priority 31
                    10 ??? (VDCAssistant + 17082) [0x10f1eb2ba]
                Thread 0xc2e      priority 97
                    10 ??? (VDCAssistant + 16505) [0x10f1eb079]
                Thread 0xc7b      priority 97
                Binary Images:
                       0x10f1e7000 -        0x10f271ff7  VDCAssistant <F15E70EA-89D4-3DAB-AA20-D0CADEDFF6E9> /System/Library/Frameworks/CoreMediaIO.framework/Resources/VDC.plugin/Contents/Resources/ VDCAssistant
              Process:         warmd [38]
              Path:            /usr/libexec/warmd
              Parent:          launchd [1]
              UID:             -2
              Sudden Term:     Dirty
              Task size:       2226 pages
                Thread 0x31d      DispatchQueue 2          priority 23
                Thread 0x31e      DispatchQueue 7          priority 21
                Thread 0x323      priority 21
                Binary Images:
                       0x10b323000 -        0x10b33afff  warmd <572DD12B-86F1-39AA-9F72-2ED56AEC4450> /usr/libexec/warmd
              Process:         wdhelper [37]
              Path:            /usr/libexec/wdhelper
              Parent:          launchd [1]
              UID:             0
              Task size:       1158 pages
                Thread 0x289      DispatchQueue 1          priority 31
                  10 ??? (wdhelper + 8860) [0x102f3029c]
                Thread 0x2c6      DispatchQueue 2          priority 33
                Binary Images:
                       0x102f2e000 -        0x102f74ff7  wdhelper <1B179967-6E43-36EF-8C7D-BDB6BD7E3CA9> /usr/libexec/wdhelper
              Process:         WebProcess [206]
              Path:            /System/Library/StagedFrameworks/Safari/WebKit2.framework/WebProcess.app/Contents/MacOS/W ebProcess
              Parent:          Safari [204]
              UID:             501
              Task size:       129548 pages
              CPU Time:        0.006s
                Thread 0x9d4      DispatchQueue 1          priority 47         cpu time   0.006s
                  10 ??? (WebProcess + 3535) [0x10f4b5dcf]
                    10 int WebKit::ChildProcessMain<WebKit::WebProcess, WebKit::WebContentProcessMainDelegate>(int, char**) + 724 (WebKit2) [0x10f64ca92]
                                         *8 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                                         *2 hndl_mach_scall64 + 19 (mach_kernel) [0xffffff80002cf473]
                                           *2 ??? (mach_kernel + 681286) [0xffffff80002a6546]
                                             *2 mach_msg_overwrite_trap + 427 (mach_kernel) [0xffffff800021970b]
                                               *2 ipc_mqueue_receive + 59 (mach_kernel) [0xffffff800021310b]
                                                 *2 thread_block_reason + 275 (mach_kernel) [0xffffff800022db83]
                                                   *2 ??? (mach_kernel + 187921) [0xffffff800022de11]
                                                     *2 processor_idle + 237 (mach_kernel) [0xffffff800022f35d]
                                                       *2 machine_idle + 434 (mach_kernel) [0xffffff80002ba222]
                Thread 0x9de      DispatchQueue 2          priority 49
                Thread 0xa42      priority 47
                    10 WTF::wtfThreadEntryPoint(void*) + 15 (JavaScriptCore) [0x10f9555ef]
                      10 WebCore::ScrollingThread::initializeRunLoop() + 244 (WebCore) [0x10feb5034]
                Thread 0xa53      priority 63
                    10 __NSThread__main__ + 1345 (Foundation) [0x7fff8d251562]
                      10 +[NSURLConnection(Loader) _resourceLoadLoop:] + 356 (Foundation) [0x7fff8d1f3546]
                Thread 0xa55      priority 47
                      10 JSC::BlockAllocator::blockFreeingThreadMain() + 261 (JavaScriptCore) [0x10f95fd75]
                        10 __psynch_cvwait + 10 (libsystem_kernel.dylib) [0x7fff8a2540fa]
                Thread 0xa56      priority 47
                      10 JSC::GCThread::gcThreadMain() + 88 (JavaScriptCore) [0x10f960688]
                        10 JSC::GCThread::waitForNextPhase() + 119 (JavaScriptCore) [0x10f9607f7]
                Thread 0xa57      priority 47
                Thread 0xa58      priority 47
                Thread 0xa59      priority 47
                Thread 0xa5a      priority 47
                Thread 0xa5b      priority 47
                Thread 0xa60      priority 47
                Thread 0x17df     priority 47
                    10 listenOnDelegatePort + 403 (QTKit) [0x7fff8959d2e6]
                Thread 0x17e0     priority 47
                    10 listenOnNotificationPort + 371 (QTKit) [0x7fff8959d781]
                Thread 0x2a5c     priority 39
                    10 figThreadMain + 382 (CoreMedia) [0x7fff8f04d379]
                      10 FigThreadGlobalNetworkBufferingRunloop + 21 (CoreMedia) [0x7fff8f04b830]
                Thread 0x5c99     priority 52
                      10 ??? (MediaToolbox + 108177) [0x7fff8ceff691]
                        10 FigSemaphoreWaitRelative + 273 (CoreMedia) [0x7fff8f04cea8]
                Binary Images:
                       0x10f4b5000 -        0x10f4b5fff  com.apple.WebProcess 8537 (8537.73.11) <D30396A0-4C65-3F69-8386-BB594CEB5791> /System/Library/StagedFrameworks/Safari/WebKit2.framework/WebProcess.app/Contents/MacOS/W ebProcess
                       0x10f4f0000 -        0x10f768ff7  com.apple.WebKit2 8537 (8537.73.11) <29199245-7FE4-308F-B38B-AD019A7F9E39> /System/Library/StagedFrameworks/Safari/WebKit2.framework/WebKit2
                       0x10f94c000 -        0x10fcf1fff  com.apple.JavaScriptCore 8537 (8537.73.10) <70ECF2B6-F6A1-3975-8598-AC0A62207151> /System/Library/StagedFrameworks/Safari/JavaScriptCore.framework/JavaScriptCore
                       0x10fddf000 -        0x110ea6fff  com.apple.WebCore 8537 (8537.73.13) <D924D5C2-6819-3559-91B5-48FDF841BFA9> /System/Library/StagedFrameworks/Safari/WebCore.framework/WebCore
                    0x7fff89589000 -     0x7fff896faff7  com.apple.QTKit 7.7.1 (2599.41) <A645347D-3EEC-34A7-8051-A57AC60151EF> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                    0x7fff8cee5000 -     0x7fff8d19cff7  com.apple.MediaToolbox 1.0 (926.106) <57043584-98E7-375A-89AE-F46480AA5D97> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                    0x7fff8f02d000 -     0x7fff8f078fff  com.apple.CoreMedia 1.0 (926.106) <64467905-48DC-37F9-9F32-186768CF2640> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
              Process:         WindowServer [76]
              Path:            /System/Library/Frameworks/ApplicationServices.framework/Frameworks/CoreGraphics.framewor k/Resources/WindowServer
              Parent:          launchd [1]
              UID:             88
              Task size:       65904 pages
              CPU Time:        0.060s
                Thread 0x322      DispatchQueue 1          priority 51         cpu time   0.057s
                  10 main + 9 (WindowServer) [0x102adef41]
                    10 CGXServer + 1000 (CoreGraphics) [0x7fff957eea1e]
                      8 CGXRunOneServicesPass + 653 (CoreGraphics) [0x7fff957ee425]
                        8 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff8a252686]
                         *7 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                      2 CGXRunOneServicesPass + 609 (CoreGraphics) [0x7fff957ee3f9]
                        2 mach_msg_overwrite_trap + 10 (libsystem_kernel.dylib) [0x7fff8a252692]
                         *2 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                Thread 0x326      DispatchQueue 2          priority 33
                Thread 0x4d1      priority 63         cpu time   0.001s
                    10 eventThread + 379 (CoreGraphics) [0x7fff958a2883]
                Thread 0x693      priority 55         cpu time   0.001s
                Binary Images:
                       0x102ade000 -        0x102adefff  WindowServer <5A74D347-6B5F-34A1-BA48-4C1C18DD8AD9> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/CoreGraphics.framewor k/Resources/WindowServer
                    0x7fff9565d000 -     0x7fff95fed627  com.apple.CoreGraphics 1.600.0 <C085C074-7260-3C3D-90C6-A65D3CB2BD41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
              Process:         xpcd [184]
              Path:            /usr/libexec/xpcd
              Parent:          launchd [1]
              UID:             501
              Task size:       2099 pages
                Thread 0x7be      DispatchQueue 2          priority 33
                Thread 0x7ce      DispatchQueue 7          priority 31
                Thread 0x880ea    priority 31
                Thread 0x880eb    priority 31
                Thread 0x880ec    priority 31
                Binary Images:
                       0x105e3a000 -        0x105e41ff7  xpcd <AC2D3F38-3A6F-3ADB-8DCD-6BD001EC88AE> /usr/libexec/xpcd
              Process:         xpcd [224]
              Parent:          launchd [1]
              UID:             202
              Task size:       1270 pages
                Thread 0xc1e      DispatchQueue 7          priority 31
                Thread 0xc1f      DispatchQueue 2          priority 33
                Binary Images:
                       0x10a5ef000 -        0x10a5f6ff7  xpcd <AC2D3F38-3A6F-3ADB-8DCD-6BD001EC88AE> /usr/libexec/xpcd
              Process:         kernel_task [0]
              Path:            kernel_task
              UID:             0
              Version:         Darwin Kernel Version 12.5.0: Sun Sep 29 13:33:47 PDT 2013; root:xnu-2050.48.12~1/RELEASE_X86_64
              Task size:       408397 pages (+266)
              CPU Time:        6.825s
                Thread 0x1        priority 92
              *10 vm_pageout_continue + 0 (mach_kernel) [0xffffff800027f4c0]
                Thread 0x2        priority 0          cpu time   0.792s
              *10 idle_thread + 0 (mach_kernel) [0xffffff800022f5f0]
                Thread 0x3        priority 95
              *10 ??? (mach_kernel + 175168) [0xffffff800022ac40]
                Thread 0x4        priority 80
              *9 ??? (mach_kernel + 238816) [0xffffff800023a4e0]
              *1 call_continuation + 23 (mach_kernel) [0xffffff80002b3257]
                Thread 0x5        priority 93
              *10 ??? (mach_kernel + 239456) [0xffffff800023a760]
                Thread 0x6        priority 94
              *10 ??? (mach_kernel + 253920) [0xffffff800023dfe0]
                Thread 0x7        priority 95
              *10 call_continuation + 23 (mach_kernel) [0xffffff80002b3257]
                 *10 mapping_replenish + 257 (mach_kernel) [0xffffff80002a50d1]
                   *10 thread_block_reason + 300 (mach_kernel) [0xffffff800022db9c]
                     *10 ??? (mach_kernel + 190673) [0xffffff800022e8d1]
                       *10 machine_switch_context + 366 (mach_kernel) [0xffffff80002b496e]
                Thread 0x8        priority 95
                 *10 ??? (mach_kernel + 274210) [0xffffff8000242f22]
                Thread 0x9        priority 81
              *10 IOWorkLoop::threadMain() + 0 (mach_kernel) [0xffffff800064fa20]
                Thread 0xb        priority 81
                Thread 0xd        priority 81
                Thread 0x1c       priority 81
                Thread 0x1e       priority 95
                 *10 AppleIntelCPUPowerManagement::free() + 21369 (AppleIntelCPUPowerManagement) [0xffffff7f823009ad]
                   *10 AppleIntelCPUPowerManagement::free() + 20211 (AppleIntelCPUPowerManagement) [0xffffff7f82300527]
                     *10 AppleIntelCPUPowerManagement::free() + 21575 (AppleIntelCPUPowerManagement) [0xffffff7f82300a7b]
                Thread 0x21       priority 0          cpu time   0.808s
                Thread 0x24       priority 0          cpu time   0.821s
                Thread 0x27       priority 0          cpu time   0.833s
                Thread 0x2a       priority 0          cpu time   0.882s
                 *10 idle_thread + 24 (mach_kernel) [0xffffff800022f608]
                   *10 processor_idle + 237 (mach_kernel) [0xffffff800022f35d]
                     *10 machine_idle + 434 (mach_kernel) [0xffffff80002ba222]
                Thread 0x2d       priority 0          cpu time   0.881s
                Thread 0x30       priority 0          cpu time   0.883s
                Thread 0x33       priority 0          cpu time   0.878s
              *9 call_continuation + 23 (mach_kernel) [0xffffff80002b3257]
                 *9 idle_thread + 24 (mach_kernel) [0xffffff800022f608]
                   *9 processor_idle + 237 (mach_kernel) [0xffffff800022f35d]
                     *9 machine_idle + 434 (mach_kernel) [0xffffff80002ba222]
              *1 idle_thread + 0 (mach_kernel) [0xffffff800022f5f0]
                Thread 0x38       priority 81
                Thread 0x74       priority 81
                Thread 0x75       priority 81         cpu time   0.004s
                Thread 0x76       priority 81
                Thread 0x81       priority 81         cpu time   0.001s
                Thread 0x8b       priority 81
                Thread 0x9b       priority 81
                Thread 0xb4       priority 81
                Thread 0xc6       priority 81
                Thread 0xcb       priority 97
                Thread 0xcc       priority 97
                Thread 0xd3       priority 81
              *10 ??? (mach_kernel + 1004000) [0xffffff80002f51e0]
                Thread 0xd5       priority 81
              *10 ??? (mach_kernel + 3770816) [0xffffff80005989c0]
                Thread 0xd6       priority 81
              *10 ??? (mach_kernel + 3406336) [0xffffff800053fa00]
                Thread 0xd7       priority 81
              *10 ??? (mach_kernel + 3439952) [0xffffff8000547d50]
                Thread 0xd8       priority 81
                Thread 0xd9       priority 81
                Thread 0xda       priority 81
                Thread 0xdb       priority 81
                Thread 0xdc       priority 81
                 *10 ??? (mach_kernel + 1338269) [0xffffff8000346b9d]
                Thread 0xdd       priority 81
                Thread 0xde       priority 81
                Thread 0xdf       priority 81
              *10 ??? (mach_kernel + 3631840) [0xffffff8000576ae0]
                Thread 0xe1       priority 81
              *10 sockwall_gc_thread + 0 (ALF) [0xffffff7f8267eb71]
                Thread 0xe3       priority 81
                Thread 0xe5       priority 82         cpu time   0.006s
                Thread 0xe6       priority 82
                Thread 0xf1       priority 81
                 *10 ??? (mach_kernel + 3975036) [0xffffff80005ca77c]
                   *10 mach_msg_receive + 163 (mach_kernel) [0xffffff8000219503]
                     *10 ipc_mqueue_receive + 66 (mach_kernel) [0xffffff8000213112]
                Thread 0xf2       priority 92
              *10 ??? (mach_kernel + 548896) [0xffffff8000286020]
                Thread 0xf3       priority 31
              *10 ??? (mach_kernel + 520992) [0xffffff800027f320]
                Thread 0xf4       priority 31
              *10 ??? (mach_kernel + 521152) [0xffffff800027f3c0]
                Thread 0xf5       priority 92
              *10 ??? (mach_kernel + 480704) [0xffffff80002755c0]
                Thread 0x12c      priority 81
                 *10 ??? (mach_kernel + 3909994) [0xffffff80005ba96a]
                Thread 0x145      priority 81
                Thread 0x1b6      priority 81
                 *10 ??? (mach_kernel + 1338862) [0xffffff8000346dee]
                Thread 0x1b7      priority 82
                 *10 ??? (mach_kernel + 1327308) [0xffffff80003440cc]
                Thread 0x1b8      priority 82
                 *10 ??? (mach_kernel + 1328161) [0xffffff8000344421]
                Thread 0x1ba      priority 81
                 *10 ??? (mach_kernel + 1341101) [0xffffff80003476ad]
                Thread 0x1bb      priority 82
                Thread 0x1f7      priority 81
                Thread 0x1f8      priority 81
                Thread 0x1ff      priority 81
                Thread 0x200      priority 81
                Thread 0x201      priority 81
                Thread 0x203      priority 81
                Thread 0x209      priority 81
                Thread 0x20d      priority 81
                Thread 0x212      priority 81
                Thread 0x219      priority 81
                Thread 0x21f      priority 81
                Thread 0x223      priority 81
                Thread 0x227      priority 81
                Thread 0x228      priority 81
                Thread 0x22b      priority 81
                Thread 0x22c      priority 81
                Thread 0x250      priority 81
                Thread 0x261      priority 81
                Thread 0x265      priority 81
                Thread 0x266      priority 81
                Thread 0x26d      priority 95
                 *10 AppleIntelCPUPowerManagement::free() + 22001 (AppleIntelCPUPowerManagement) [0xffffff7f82300c25]
                Thread 0x26e      priority 95
                Thread 0x26f      priority 95
                Thread 0x270      priority 95
                Thread 0x271      priority 95
                Thread 0x272      priority 95
                Thread 0x273      priority 95
                Thread 0x284      priority 81
                Thread 0x2bb      priority 92
                Thread 0x3a9      priority 81
                Thread 0x3aa      priority 82
                 *10 ??? (mach_kernel + 1326966) [0xffffff8000343f76]
                Thread 0x445      priority 81         cpu time   0.001s
                Thread 0x49b      priority 81
                Thread 0x4a6      priority 81
                Thread 0x4b4      priority 81         cpu time   0.007s
                Thread 0x4c0      priority 81
                Thread 0xc54      priority 93         cpu time   0.003s
              *10 ??? (mach_kernel + 254384) [0xffffff800023e1b0]
                Thread 0xd8f      priority 93         cpu time   0.005s
              *9 ??? (mach_kernel + 254384) [0xffffff800023e1b0]
                 *1 ??? (mach_kernel + 255401) [0xffffff800023e5a9]
                   *1 thread_block_reason + 275 (mach_kernel) [0xffffff800022db83]
                     *1 ??? (mach_kernel + 187921) [0xffffff800022de11]
                       *1 processor_idle + 237 (mach_kernel) [0xffffff800022f35d]
                         *1 machine_idle + 434 (mach_kernel) [0xffffff80002ba222]
                Thread 0x2e00c    priority 93         cpu time   0.004s
                Thread 0x319aa    priority 93         cpu time   0.008s
                Binary Images:
              *0xffffff7f822fa000 - 0xffffff7f8231afff  com.apple.driver.AppleIntelCPUPowerManagement 214.0.0 (214.0.0) <C154A79F-841E-39ED-A28D-CD20975E352D> /System/Library/Extensions/AppleIntelCPUPowerManagement.kext/Contents/MacOS/AppleIntelCPU PowerManagement
              *0xffffff7f82679000 - 0xffffff7f8267ffff  com.apple.nke.applicationfirewall 4.0.39 (4.0.39) <98AC313B-9E39-3526-B28C-27666C2E1E4A> /System/Library/Extensions/ALF.kext/Contents/MacOS/ALF
                Kextstat:
              Index Refs Address            Size       Wired      Name (Version) <Linked Against>
                  1   76 0xffffff7f80757000 0x686c     0x686c     com.apple.kpi.bsd (12.5.0)
                  2    6 0xffffff7f80742000 0x46c      0x46c      com.apple.kpi.dsep (12.5.0)
                  3  109 0xffffff7f80761000 0x1b7ec    0x1b7ec    com.apple.kpi.iokit (12.5.0)
                  4  113 0xffffff7f8074d000 0x99f8     0x99f8     com.apple.kpi.libkern (12.5.0)
                  5   98 0xffffff7f80743000 0x88c      0x88c      com.apple.kpi.mach (12.5.0)
                  6   41 0xffffff7f80744000 0x502c     0x502c     com.apple.kpi.private (12.5.0)
                  7   60 0xffffff7f8074a000 0x23cc     0x23cc     com.apple.kpi.unsupported (12.5.0)
                  8    0 0xffffff7f81bbb000 0x41000    0x41000    com.apple.kec.corecrypto (1.0) <7 6 5 4 3 1>
                  9   25 0xffffff7f8139d000 0x9000     0x9000     com.apple.iokit.IOACPIFamily (1.4) <7 6 4 3>
                 10   38 0xffffff7f8088e000 0x29000    0x29000    com.apple.iokit.IOPCIFamily (2.8) <7 6 5 4 3>
                 11    2 0xffffff7f82608000 0x5a000    0x5a000    com.apple.driver.AppleACPIPlatform (1.8) <10 9 7 6 5 4 3 1>
                 12    1 0xffffff7f810f8000 0xe000     0xe000     com.apple.driver.AppleKeyStore (28.21) <7 6 5 4 3 1>
                 13    4 0xffffff7f8077d000 0x25000    0x25000    com.apple.iokit.IOStorageFamily (1.8) <7 6 5 4 3 1>
                 14    0 0xffffff7f81449000 0x19000    0x19000    com.apple.driver.DiskImages (345) <13 7 6 5 4 3 1>
                 15    0 0xffffff7f822fa000 0x2e000    0x2e000    com.apple.driver.AppleIntelCPUPowerManagement (214.0.0) <7 6 5 4 3 1>
                 16    0 0xffffff7f8075e000 0x3000     0x3000     com.apple.security.TMSafetyNet (7) <7 6 5 4 2 1>
                 17    2 0xffffff7f80830000 0x4000     0x4000     com.apple.kext.AppleMatch (1.0.0d1) <4 1>
                 18    1 0xffffff7f80834000 0x11000    0x11000    com.apple.security.sandbox (220.3) <17 7 6 5 4 3 2 1>
                 19    0 0xffffff7f80845000 0x6000     0x6000     com.apple.security.quarantine (2.1) <18 17 7 6 5 4 2 1>
                 20    0 0xffffff7f82679000 0x8000     0x8000     com.apple.nke.applicationfirewall (4.0.39) <7 6 5 4 3 1>
                 21    0 0xffffff7f822f5000 0x3000     0x3000     com.apple.driver.AppleIntelCPUPowerManagementClient (214.0.0) <7 6 5 4 3 1>
                 22    0 0xffffff7f825dc000 0x3000     0x3000     com.apple.driver.AppleAPIC (1.7) <4 3>
                 23    3 0xffffff7f8132e000 0x4000     0x4000     com.apple.iokit.IOSMBusFamily (1.1) <5 4 3>
                 24    0 0xffffff7f82668000 0x7000     0x7000     com.apple.driver.AppleACPIEC (1.8) <23 11 9 5 4 3>
                 25    0 0xffffff7f820bf000 0x4000     0x4000     com.apple.driver.AppleSMBIOS (1.9) <7 4 3>
                 26    0 0xffffff7f82353000 0x3000     0x3000     com.apple.driver.AppleHPET (1.8) <9 7 5 4 3>
                 27    0 0xffffff7f820eb000 0x8000     0x8000     com.apple.driver.AppleRTC (1.5) <9 5 4 3 1>
                 28   12 0xffffff7f81106000 0x6d000    0x6d000    com.apple.iokit.IOHIDFamily (1.8.1) <12 7 6 5 4 3 2 1>
                 29    0 0xffffff7f82672000 0x4000     0x4000     com.apple.driver.AppleACPIButtons (1.8) <28 11 9 7 6 5 4 3 1>
                 30    1 0xffffff7f825af000 0x5000     0x5000     com.apple.driver.AppleEFIRuntime (2.0) <7 6 5 4 3>
                 31    0 0xffffff7f820c5000 0x8000     0x8000     com.apple.driver.AppleSmartBatteryManager (161.0.0) <23 9 5 4 3 1>
                 32    0 0xffffff7f825b4000 0xa000     0xa000     com.apple.driver.AppleEFINVRAM (2.0) <30 7 6 5 4 3>
                 33   16 0xffffff7f81077000 0x5e000    0x5e000    com.apple.iokit.IOUSBFamily (635.4.0) <10 7 5 4 3 1>
                 34    0 0xffffff7f81196000 0x1d000    0x1d000    com.apple.driver.AppleUSBXHCI (635.4.0) <33 10 7 5 4 3 1>
                 35    0 0xffffff7f81210000 0x18000    0x18000    com.apple.driver.AppleUSBEHCI (621.4.6) <33 10 7 5 4 3 1>
                 36    2 0xffffff7f8162d000 0x16000    0x16000    com.apple.iokit.IOAHCIFamily (2.5.1) <5 4 3 1>
                 37    0 0xffffff7f825e1000 0x1a000    0x1a000    com.apple.driver.AppleAHCIPort (2.6.6) <36 10 5 4 3 1>
                 38    0 0xffffff7f810f5000 0x3000     0x3000     com.apple.iokit.IOUSBUserClient (630.4.4) <33 7 5 4 3 1>
                 39    6 0xffffff7f81038000 0x2b000    0x2b000    com.apple.iokit.IONetworkingFamily (3.0) <7 6 5 4 3 1>
                 40    1 0xffffff7f81677000 0x68000    0x68000    com.apple.iokit.IO80211Family (530.5) <39 7 6 5 4 3 1>
                 41    0 0xffffff7f816e6000 0x1f9000   0x1f9000   com.apple.driver.AirPort.Brcm4331 (615.20.17) <40 39 10 7 5 4 3 1>
                 42    0 0xffffff7f81653000 0x17000    0x17000    com.apple.iokit.IOAHCIBlockStorage (2.3.5) <36 13 6 5 4 3 1>
                 43    1 0xffffff7f81407000 0x7000     0x7000     com.apple.iokit.IOEthernetAVBController (1.0.2b1) <39 5 4 3 1>
                 44    0 0xffffff7f8140e000 0x38000    0x38000    com.apple.iokit.AppleBCM5701Ethernet (3.6.2b4) <43 39 10 9 5 4 3 1>
                 45    0 0xffffff7f820d2000 0x12000    0x12000    com.apple.driver.AppleSDXC (1.4.3) <13 10 5 4 3 1>
                 46    0 0xffffff7f811f4000 0x15000    0x15000    com.apple.driver.AppleUSBHub (635.4.0) <33 5 4 3 1>
                 47    0 0xffffff7f81ef4000 0x3000     0x3000     com.apple.driver.XsanFilter (404) <13 5 4 3 1>
                 48    6 0xffffff7f81245000 0xbb000    0xbb000    com.apple.iokit.IOThunderboltFamily (2.7.7) <5 4 3 1>
                 49    0 0xffffff7f81ffd000 0x16000    0x16000    com.apple.driver.AppleThunderboltNHI (1.9.2) <48 10 9 5 4 3 1>
                 50    2 0xffffff7f80f79000 0x73000    0x73000    com.apple.iokit.IOFireWireFamily (4.5.5) <5 4 3 1>
                 51    0 0xffffff7f814a4000 0x27000    0x27000    com.apple.driver.AppleFWOHCI (4.9.9) <50 10 7 6 5 4 3 1>
                 53    0 0xffffff7f81c0b000 0x9000     0x9000     com.apple.BootCache (34) <7 6 5 4 3 1>
                 54    0 0xffffff7f825a0000 0x4000     0x4000     com.apple.AppleFSCompression.AppleFSCompressionTypeZlib (1.0.0d1) <6 4 3 2 1>
                 55    0 0xffffff7f825a6000 0x3000     0x3000     com.apple.AppleFSCompression.AppleFSCompressionTypeDataless (1.0.0d1) <7 6 4 3 2 1>
                 57    1 0xffffff7f8118f000 0x7000     0x7000     com.apple.driver.AppleUSBComposite (621.4.0) <33 4 3 1>
                 58    0 0xffffff7f811ed000 0x7000     0x7000     com.apple.driver.AppleUSBMergeNub (621.4.6) <57 33 4 3 1>
                 59    1 0xffffff7f81fef000 0x5000     0x5000     com.apple.driver.AppleThunderboltPCIDownAdapter (1.3.2) <48 10 5 4 3>
                 60    2 0xffffff7f82017000 0x9000     0x9000     com.apple.driver.AppleThunderboltDPAdapterFamily (2.5.0) <48 10 9 5 4 3>
                 61    1 0xffffff7f82020000 0x6000     0x6000     com.apple.driver.AppleThunderboltDPInAdapter (2.5.0) <60 48 10 9 5 4 3>
                 62    0 0xffffff7f82026000 0xb000     0xb000     com.apple.driver.AppleThunderboltDPOutAdapter (2.5.0) <61 60 48 10 9 5 4 3>
                 63    0 0xffffff7f81ff4000 0x9000     0x9000     com.apple.driver.AppleThunderboltPCIUpAdapter (1.3.2) <59 48 10 5 4 3>
                 64    5 0xffffff7f81186000 0x9000     0x9000     com.apple.iokit.IOUSBHIDDriver (623.4.0) <33 28 5 4 3 1>
                 65    0 0xffffff7f81f28000 0x4000     0x4000     com.apple.driver.AppleUSBTCKeyboard (237.1) <64 33 28 7 6 5 4 3 1>
                 67    0 0xffffff7f81f33000 0x13000    0x13000    com.apple.driver.AppleUSBMultitouch (237.3) <64 33 28 6 5 4 3 1>
                 68    0 0xffffff7f81f2e000 0x3000     0x3000     com.apple.driver.AppleUSBTCButtons (237.1) <64 33 28 7 6 5 4 3 1>
                 69    1 0xffffff7f81fb9000 0x7000     0x7000     com.apple.driver.AppleHIDKeyboard (170.2.4) <28 4 3>
                 70    0 0xffffff7f82366000 0x4000     0x4000     com.apple.driver.AppleUSBHIDKeyboard (170.2.4) <69 64 28 4 3>
                 71   17 0xffffff7f808d1000 0x38000    0x38000    com.apple.iokit.IOGraphicsFamily (2.3.7) <10 7 5 4 3>
                 72    2 0xffffff7f820ae000 0xe000     0xe000     com.apple.driver.AppleSMBusController (1.0.11d1) <23 10 9 5 4 3>
                 73    0 0xffffff7f82155000 0xd000     0xd000     com.apple.driver.AppleMCCSControl (1.1.11) <72 71 10 9 7 5 4 3 1>
                 74   10 0xffffff7f80914000 0x12000    0x12000    com.apple.iokit.IONDRVSupport (2.3.7) <71 10 7 5 4 3>
                 75    1 0xffffff7f82580000 0x5000     0x5000     com.apple.driver.AppleBacklightExpert (1.0.4) <74 71 10 5 4 3>
                 77    2 0xffffff7f8256c000 0x3000     0x3000     com.apple.driver.AppleGraphicsControl (3.4.5) <74 71 10 9 7 5 4 3 1>
                 78    0 0xffffff7f82585000 0x13000    0x13000    com.apple.driver.AppleMuxControl (3.4.5) <77 75 74 71 10 9 7 6 5 4 3 1>
                 79    0 0xffffff7f820ab000 0x2000     0x2000     com.apple.driver.AppleSMBusPCI (1.0.11d1) <10 5 4 3>
                 80    0 0xffffff7f82280000 0x61000    0x61000    com.apple.driver.AppleIntelFramebufferCapri (8.1.6) <71 10 9 7 6 5 4 3 1>
                 81    0 0xffffff7f8237f000 0x16000    0x16000    com.apple.driver.AppleMikeyDriver (2.4.7fc4) <72 9 5 4 3 1>
                 82    5 0xffffff7f813a6000 0xa000     0xa000     com.apple.driver.IOPlatformPluginFamily (5.4.1d13) <9 7 6 5 4 3>
                 83    4 0xffffff7f813b0000 0xf000     0xf000     com.apple.driver.AppleSMC (3.1.5d4) <9 7 5 4 3>
                 84    1 0xffffff7f813c1000 0xe000     0xe000     com.apple.driver.X86PlatformPlugin (1.0.0) <83 82 33 9 7 6 5 4 3 1>
                 87    0 0xffffff7f8256f000 0xc000     0xc000     com.apple.driver.ApplePolicyControl (3.4.5) <77 74 71 10 9 7 5 4 3 1>
                 88    0 0xffffff7f81ad2000 0x5000     0x5000     com.apple.Dont_Steal_Mac_OS_X (7.0.0) <83 7 4 3 1>
                 89    2 0xffffff7f814ff000 0x9a000    0x9a000    com.apple.iokit.IOBluetoothFamily (4.1.7f2) <33 7 5 4 3 1>
                 90    0 0xffffff7f8131a000 0x12000    0x12000    com.apple.iokit.IOSurface (86.0.4) <7 5 4 3 1>
                 91    0 0xffffff7f8106a000 0x7000     0x7000     com.apple.iokit.IOUserEthernet (1.0.0d1) <39 6 5 4 3 1>
                 92    0 0xffffff7f8218c000 0x3000     0x3000     com.apple.driver.AppleLPC (1.6.3) <82 10 5 4 3>
                 93    0 0xffffff7f81494000 0xe000     0xe000     com.apple.iokit.IOFireWireIP (2.2.5) <50 39 5 4 3 1>
                 94    1 0xffffff7f815d3000 0x1b000    0x1b000    com.apple.iokit.IOBluetoothHostControllerUSBTransport (4.1.7f2) <33 10 9 7 5 4 3 1>
                 95    0 0xffffff7f815ee000 0x8000     0x8000     com.apple.iokit.BroadcomBluetoothHostControllerUSBTransport (4.1.7f4) <94 33 10 9 7 5 4 3>
                 96    2 0xffffff7f81c21000 0xe000     0xe000     com.apple.kext.OSvKernDSPLib (1.12) <5 4>
                 97    4 0xffffff7f81c2f000 0x2f000    0x2f000    com.apple.iokit.IOAudioFamily (1.9.2fc7) <96 5 4 3 1>
                 98    0 0xffffff7f81f4e000 0x41000    0x41000    com.apple.driver.AppleUSBAudio (2.9.3f3) <97 33 5 4 3>
                 99    2 0xffffff7f82370000 0xc000     0xc000     com.apple.iokit.IOHDAFamily (2.4.7fc4) <5 4 3 1>
                100    1 0xffffff7f823a7000 0x19000    0x19000    com.apple.driver.AppleHDAController (2.4.7fc4) <99 71 10 7 6 5 4 3 1>
                102    0 0xffffff7f820a3000 0x5000     0x5000     com.apple.driver.AppleSMCLMU (2.0.3d0) <83 71 5 4 3>
                104    0 0xffffff7f813d7000 0x3000     0x3000     com.apple.driver.AppleSMCPDRC (1.0.0) <82 10 6 4 3>
                106    1 0xffffff7f821c1000 0x4b000    0x4b000    com.apple.iokit.IOAcceleratorFamily (74.15) <74 71 10 7 5 4 3 1>
                107    0 0xffffff7f82217000 0x49000    0x49000    com.apple.driver.AppleIntelHD4000Graphics (8.1.6) <106 74 71 10 7 5 4 3 1>
                108    0 0xffffff7f81f49000 0x3000     0x3000     com.apple.driver.AppleUSBDisplays (357) <64 33 28 5 4 3>
                109    2 0xffffff7f80928000 0x2a3000   0x2a3000   com.apple.NVDAResman (8.1.6) <74 71 10 5 4 3 1>
                110    0 0xffffff7f80bd6000 0x330000   0x330000   com.apple.nvidia.gk100hal (8.1.6) <109 10 4 3>
                111    0 0xffffff7f819b4000 0xce000    0xce000    com.apple.GeForce (8.1.6) <109 74 71 10 7 6 5 4 3 1>
                112    0 0xffffff7f81f95000 0x5000     0x5000     com.apple.driver.AppleUpstreamUserClient (3.5.12) <71 10 9 7 5 4 3 1>
                113    1 0xffffff7f823c0000 0xba000    0xba000    com.apple.driver.DspFuncLib (2.4.7fc4) <97 96 6 5 4 3 1>
                114    0 0xffffff7f82483000 0x8b000    0x8b000    com.apple.driver.AppleHDA (2.4.7fc4) <113 100 99 97 74 71 6 5 4 3 1>
                115    0 0xffffff7f8214a000 0x3000     0x3000     com.apple.driver.AppleMikeyHIDDriver (124) <28 7 4 3 1>
                117    0 0xffffff7f813cf000 0x6000     0x6000     com.apple.driver.X86PlatformShim (1.0.0) <84 83 82 7 4 3>
                118    0 0xffffff7f82143000 0x4000     0x4000     com.apple.driver.ApplePlatformEnabler (2.0.7d2) <7 5 4 3>
                119    0 0xffffff7f82552000 0x12000    0x12000    com.apple.driver.AGPM (100.13.12) <82 74 71 10 5 4 3>
                120    0 0xffffff7f8084c000 0x2b000    0x2b000    com.apple.iokit.IOSCSIArchitectureModelFamily (3.5.6) <5 4 3 1>
                121    2 0xffffff7f807f3000 0x5000     0x5000     com.apple.kext.triggers (1.0) <7 6 5 4 3 1>
                122    0 0xffffff7f81c16000 0x9000     0x9000     com.apple.filesystems.autofs (3.0) <121 7 6 5 4 3 1>
                123    1 0xffffff7f81337000 0xe000     0xe000     com.apple.iokit.IOSerialFamily (10.0.6) <7 6 5 4 3 1>
                124    0 0xffffff7f815bf000 0xa000     0xa000     com.apple.iokit.IOBluetoothSerialManager (4.1.7f2) <123 7 5 4 3 1>
                125    0 0xffffff7f81c66000 0x5000     0x5000     com.apple.driver.AudioAUUC (1.60) <97 71 10 9 7 5 4 3 1>
                126    1 0xffffff7f81f9e000 0x17000    0x17000    com.apple.driver.AppleMultitouchDriver (237.4) <28 5 4 3 1>
                127    1 0xffffff7f815a8000 0x12000    0x12000    com.apple.driver.IOBluetoothHIDDriver (4.1.7f2) <89 28 5 4 3>
                128    0 0xffffff7f825be000 0xe000     0xe000     com.apple.driver.AppleBluetoothMultitouch (75.19) <127 126 89 28 5 4 3>
                129    0 0xffffff7f8232b000 0x5000     0x5000     com.apple.driver.AppleHWSensor (1.9.5d0) <5 4 3>
                131    0 0xffffff7f807f8000 0x33000    0x33000    com.apple.filesystems.smbfs (1.8.4) <121 7 6 5 4 3 1>
              Model: MacBookPro10,1, BootROM MBP101.00EE.B03, 4 processors, Intel Core i7, 2.4 GHz, 16 GB, SMC 2.3f36
              Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In, 512 MB
              Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 1024 MB
              Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434314753364D465238432D50422020
              Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434314753364D465238432D50422020
              AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xEF), Broadcom BCM43xx 1.0 (5.106.98.100.17)
              Bluetooth: Version 4.1.7f2 12718, 3 service, 21 devices, 3 incoming serial ports
              Network Service: Wi-Fi, AirPort, en0
              Network Service: Display Ethernet, Ethernet, en2
              PCI Card: pci11c1,5901, sppci_ieee1394openhci, Thunderbolt@16,0,0
              PCI Card: Apple 57761-B0, sppci_ethernet, Thunderbolt@15,0,0
              PCI Card: pci12d8,400e, sppci_usbopenhost, Thunderbolt@12,0,0
              PCI Card: pci12d8,400e, sppci_usbopenhost, Thunderbolt@12,0,1
              PCI Card: pci12d8,400f, USB Enhanced Host Controller, Thunderbolt@12,0,2
              Serial ATA Device: APPLE SSD SD512E, 500.28 GB
              USB Device: hub_device, 0x8087  (Intel Corporation), 0x0024, 0x1a100000 / 2
              USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8510, 0x1a110000 / 3
              USB Device: hub_device, 0x8087  (Intel Corporation), 0x0024, 0x1d100000 / 2
              USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0x1d110000 / 6
              USB Device: Apple Keyboard, apple_vendor_id, 0x024f, 0x1d112000 / 10
              USB Device: hub_device, 0x0424  (SMSC), 0x2512, 0x1d180000 / 3
              USB Device: BRCM20702 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x1d181000 / 5
              USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8286, 0x1d181300 / 9
              USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0262, 0x1d182000 / 4
              USB Device: hub_device, apple_vendor_id, 0x9127, 0x40100000 / 2
              USB Device: iPhone, apple_vendor_id, 0x12a0, 0x40130000 / 6
              USB Device: FaceTime HD Camera (Display), apple_vendor_id, 0x1112, 0x40150000 / 5
              USB Device: Apple Thunderbolt Display, apple_vendor_id, 0x9227, 0x40170000 / 4
              USB Device: Display Audio, apple_vendor_id, 0x1107, 0x40140000 / 3
              • 4. Re: How can I get Adobe Edge Animate to not hang after every mouse click?
                heathrowe Most Valuable Participant
                On the notion of firewall, I thought I would share a recent experience.
                I am trialing AVG Internet Security and its firewall is set to 'Automatic'. Meaning no warnings are provided to the end user.
                When I ran Ea the application would open, but it would freeze at the splash screen/ home screen and I could not proceed.
                Solution was to to change the AVG Firewall option to 'Interactive', so anytime a request is trigger you tell it 'it is ok /Allow'. In the case of AE the next time I ran it, I got the the interactive dialog, allowed it, and all was well, and still is from then onward.
                Hope this helps someone.
                Darrell
                • 5. Re: How can I get Adobe Edge Animate to not hang after every mouse click?
                  xbizkoot Level 1
                  Thank you for the input. I will look into this and see if it helps.
                  Any ideas why it only happens to EA and not any other of my CC apps? \
                  • 6. Re: How can I get Adobe Edge Animate to not hang after every mouse click?
                    Sure thing.
                    Ea sends communication packets to its own 'server' port, other Adobe applications don't do this. Thats why a Firewall will interfere with the application, until you 'tell it' to allow it access.
                    Darrell
                    • 7. Re: How can I get Adobe Edge Animate to not hang after every mouse click?
                      xbizkoot Level 1
                      Thanks for sharing your knowledge.
                      Unfortunately, I dont have access to my firewire settings at work, and my IT guy is in the building/reachable rarely. I will piddle and see where i can get before I give up out of frustration.
