3 Replies Latest reply on Dec 18, 2007 8:19 AM by Zolotoj
    HTTPService
    Zolotoj Level 3
      I can't get it work from both development environment and the Internet.
      If I use full virtual paths to my ASP pages that return data it works fine from the development but does not from the Internet and I am using crossdomain file. Then if I use relative (with ../../) notations it works from the Internet but from the development no data is shown. Any idea how to get both environments working?
        • 1. Re: HTTPService
          Gregory Lafrance Level 6
          Loading local assets
          In some cases, your SWF file might load assets that reside on the client's local file system. This typically happens when the Flex application is embedded on the client device and loaded from a network. If the application is allowed to access local assets, it cannot access network assets.
          To ensure that a Flex application can access assets in the local sandbox, the application must be in the local-with-filesystem or local-trusted sandbox. To ensure this, you set the use-network compiler option to false when you compile the application. The default value of this option is true.
          When you load another SWF file that is in the local file system into your application with a class such as SWFLoader, and you want to call methods or access properties of that SWF file, you do not need to explicitly enable cross-scripting.
          If the SWF files are in different sandboxes (for example, you loaded the main SWF file into the local-with-network sandbox, but loaded the asset SWF file from the network), you cannot cross-script because they are in different sandboxes. Remote SWF files cannot load local SWF files, and vice versa.
          • 2. Re: HTTPService
            ntsiii Level 3
            I advise using full urls. If a full url does not work. it is a crossdomain issue.
            If you want to be able to point to different urls without re-compiling, pass the url into the app from the html wrapper using flashvars.
            Tracy
            • 3. Re: HTTPService
              Zolotoj Level 3
              I am testing it again and it does work fine on my XP box. I did not on my Server 2008. Will try again. Thanks
