4 Replies Latest reply on Dec 19, 2013 8:58 AM by try67
    Stamp not working in Reader
    JuanMiguel
      Hello,
      Please, help me find what I'm doing wrong.
      I have done a dynamic stamp that displays a dialog to collect data from several input fields and then fills the stamp's template with the info collected.
      The thing is that the stamp works fine in Acrobat 9 Standard, but when I apply the stamp with Acrobat reader XI the dialog prompts requesting the input fields but the template is not filled. I mean, all "fields" in the picture remain blank.
      In the Adobe Reader Java Console I get this erro when apliying the stamp.
      Exception in line 192 of function top_level, script 0
      InvalidGetError: Get not possible, invalid or unknown.
      Doc.layout:192:App Promocion:Calculate
      This is the code of the stamp:
      var dlgDatos = {
      vpromocion: "",
      vpartida1: "",
      vpartida2: "",
      vpartida3: "",
      vpartida4: "",
      vpartida5: "",
      vpartida6: "",
      vporciento1: "",
      vporciento2: "",
      vporciento3: "",
      vporciento4: "",
      vporciento5: "",
      vporciento6: "",
      vobservaciones: "",
      commit:function (dialog)
      { // called when OK pressed
          var results = dialog.store();
                this.vpromocion = results["prom"];
                this.vpartida1 = results["par1"];
                this.vpartida2 = results["par2"];
                this.vpartida3 = results["par3"];
                this.vpartida4 = results["par4"];
                this.vpartida5 = results["par5"];
                this.vpartida6 = results["par6"];
                this.vporciento1 = results["por1"];
                this.vporciento2 = results["por2"];
                this.vporciento3 = results["por3"];
                this.vporciento4 = results["por4"];
                this.vporciento5 = results["por5"];
                this.vporciento6 = results["por6"];
                this.vobservaciones = results["obse"];
        description:
          name: "Stamp Information",  // Dialog box title
          elements:
                {type: "view",
                  elements:
                  type: "static_text",
                  item_id: "prom",
                  type: "edit_text",
                  width: 180
            {type: "view",
              elements:
                {type: "view",
                  align_children: "align_row",
                  elements:
                    width: 120,
                    width: 120,
                 {type: "view",
                  elements:[
                {item_id: "par1",
                  type: "edit_text",
                  width: 120},
                {item_id: "por1",
                  type: "edit_text",
                  width: 120},
                 {type: "view",
                  elements:[
                {item_id: "par2",
                  type: "edit_text",
                  width: 120},
                {item_id: "por2",
                  type: "edit_text",
                  width: 120},
                 {type: "view",
                  elements:[
                {item_id: "par3",
                  type: "edit_text",
                  width: 120},
                {item_id: "por3",
                  type: "edit_text",
                  width: 120},
                 {type: "view",
                  elements:[
                {item_id: "par4",
                  type: "edit_text",
                  width: 120},
                {item_id: "por4",
                  type: "edit_text",
                  width: 120},
                 {type: "view",
                  elements:[
                {item_id: "par5",
                  type: "edit_text",
                  width: 120},
                {item_id: "por5",
                  type: "edit_text",
                  width: 120},
                 {type: "view",
                  elements:[
                {item_id: "par6",
                  type: "edit_text",
                  width: 120},
                {item_id: "por6",
                  type: "edit_text",
                  width: 120},
                {item_id: "obse",
                  type: "edit_text",
                    multiline:true,
                    height:60,
                  width: 250},
                {type: "ok_cancel",
                  ok_name: "Aceptar",
                  cancel_name: "Cancelar"
      if(event.source.forReal && (event.source.stampName == "#Nn99tcN5Jn2Kqw75dj2kzB"))
        if ("ok" == app.execDialog(dlgDatos))
          var cMsg = dlgDatos.vpromocion;
          event.source.source.info.exhibit = dlgDatos.vpromocion;
          event.value = cMsg
                this.getField("Partida1").value = dlgDatos.vpartida1;
                this.getField("Porciento1").value = dlgDatos.vporciento1;
                this.getField("Partida2").value = dlgDatos.vpartida2;
                this.getField("Porciento2").value = dlgDatos.vporciento2;
                this.getField("Partida3").value = dlgDatos.vpartida3;
                this.getField("Porciento3").value = dlgDatos.vporciento3;
                this.getField("Partida4").value = dlgDatos.vpartida4;
                this.getField("Porciento4").value = dlgDatos.vporciento4;
                this.getField("Partida5").value = dlgDatos.vpartida5;
                this.getField("Porciento5").value = dlgDatos.vporciento5;
                this.getField("Partida6").value = dlgDatos.vpartida6;
                this.getField("Porciento6").value = dlgDatos.vporciento6;
                this.getField("Observaciones").value = dlgDatos.vobservaciones;
      Thank you.
