1 Reply Latest reply on Dec 19, 2013 8:12 AM by Josh_Corey
    Existing PDF's
      How do I add text boxes to an already existing PDF?
        • 1. Re: Existing PDF's
          Josh_Corey Adobe Employee
          The Import PDF feature allows you to import an existing PDF into FormsCentral to use FormsCentral to collect and manage responses, it does not provide a web version of the form or enable you to make any changes to the form.
          If you need to add additional fields you should use Adobe Acrobat to edit the form prior to importing into FormsCentral.
          This FAQ talks about the Import PDF feature: http://forums.adobe.com/docs/DOC-2654
