1 Reply Latest reply: Dec 20, 2013 9:23 AM by Laubender RSS
    Adding spaces to inDesign Data Merges
    CarthagoDelendaEst Community Member
      I'm looking for a solution to a problem which I run into all the time while doing data merges.
      I know that you can not include a space in a line if you want inDesign to remove blank lines.  Sometimes, though, I want to add a space IF there is text in one of the fields.
      An example:
      <<Address 1>><<comma>><<Address 2>>
      I've added a field in the CSV file which will add a comma if there is data in the Address 2 field.  The CSV file, though, won't save a space as an option to add.  I would like to not have to go through the entire 200 pages of final merged document to check for this space.
      I tried adjusting kerning in the pre-merge file, and it looks like it will work, until I click the preview button, at which time the kerning resets to normal.
      Is there a solution for adding spaces only if there is data in the Address 2 and comma fields?
