2 Replies Latest reply on Dec 21, 2013 2:03 AM by Laubender
    How to change the multiple Paragraph Style's options altogether?
    MacFisher
      Dear All,
      I now received my german colleague's Indesign template, and it's all in German language and there are some paragraph style options not applicable in APAC.
      i need to apply changes to specific options to all paragraph styles.(please see below screen shots)
      is there any quick way to apply specific change (for example, i want all of them disable Hyphenation) to all the paragraph styles?
      Thank you.
        • 1. Re: How to change the multiple Paragraph Style's options altogether?
          Grant H Level 4
          this solution depends on a few things:
          are the styles based on other styles?
          what are the global changes (eg. no hyphenation is one)
          • 2. Re: How to change the multiple Paragraph Style's options altogether?
            @MacFisher – I think you could do that only by scripting.
            Here an example with ExtendScript (JavaScript), that disables hyphenation for all* paragraph styles, be them in groups or not.
            *all, but the two basic ones, the one seen in the UI as "Basic Paragraph" and the one that implicitly is always there when a paragraph is set to "Break Link to Style".
            var d=app.documents[0];
            var allMyParagraphStyles = d.allParagraphStyles;
            //We loop through the paragraph styles.
            //The loop does not start with 0, because 0 and 1 denote
            //the two default, built in paragraph styles in every document
            for(var n=2;n<allMyParagraphStyles.length;n++){
                allMyParagraphStyles[n].hyphenation = false;
            The scope of that snippet is the document, that has the focus (is the active one) of all open documents.
            But some words of warning:
            Prepare to see some overset text in your document after running the script.
            So test always on a duplicate of your doc…
            Uwe
