1 Reply Latest reply on Dec 21, 2013 7:09 AM by Steve Grisetti
    experimental GPU-accelerated H264-encoder plugin for NVidia Kepler GPU
    nvenc4everyone Level 1
      A few months ago, I posted an experimental third-party exporter for Premiere CS6.  The plugin uses the hardware-video encoder (NVENC) of the NVidia Kepler GPU (GTX650 and better.)  At the time, NVENC encoding-speed in Premiere Elements 11 was poor; it was almost no faster than Premiere's built-in Mainconcept H264 encoder (which uses pure software encoding.)
      With Elements 12, under ideal conditions NVENC encoding speed almost matches Premiere Pro CS6.  For doing a *straight* re-encode of a 1920x1080p24 source H264-video (no effects, no resizing, etc.), NVENC is roughly 3x-4x faster than Mainconcept. Of course, CS6 has the hardware-accelerated MPE video-renderer whereas Elements 12 doesn't, so CS6 is still much faster if you do a lot of video effects and manipulation.)
      Requirements:
      Adobe Premiere Elements 12 (Windows)
      NVidia Geforce Kepler GPU (GTX650 and above, should work with cards that support "ShadowPlay")
      NVidia Geforce drivers from December 2013 (or newer)
      Installation:
      nvenc_export is experimental, unsupported software: you should not install it unless you are comfortable with working with third-party plugins.  (There's no installer package, you have to manually copy files to your Premiere installation-path as Administrator.)
      Installation-tutorial:
      You really should read the included readme file.  But I also tried my best to make a tutorial-video on the installation procedure.  Watch it here: http://youtu.be/wPrcQ133YE0
      Download link is in this discussion thread: http://forums.adobe.com/message/5912769#5912769
      (Make sure to download version 1.06 or later)
