1 Reply Latest reply on Dec 25, 2013 1:11 AM by Mylenium
    CC Snowfall problem.
      Hi, I was watching the looping partical system located here: http://library.creativecow.net/articles/rabinowitz_aharon/CC_Looping_Particles/video-tutor ial
      I want to create a cc snowfall loop and it should be possible as he said in the video but the CC snowfall effect doesnt have a birth rate as he used CC partical systems II
      Does anyone know how to make a snowfall loop or find the CC snowfall birth rate?
      Thanks in advance!
        • 1. Re: CC Snowfall problem.
          No, it's not working this way. The whole point is for each point in time the snow distribution to be unique. You have to use the old technique and cross-fade two instances of a pre-comp with the effect halfway through and then use the resulting comp as a layer in your main comp. This works universally for any stuff that needs to be looped and repeated.
