1 Reply Latest reply on Dec 26, 2013 1:56 PM by LarryKingLive
    How to make two text fields flow together
    LarryKingLive
      I have a subform and created two text fields side-by-side (Western Text flow) that I want to expand together, even when one of the two has more data content entred than the other, so that the other field without as much data content flows the same length. This way it keeps the layout the same all the way through into new pages if needed. Any ideas?
        • 1. Re: How to make two text fields flow together
          LarryKingLive Level 1
          This must be the day after Christmas or something Crazy people like me are still working. Okay -- I figured it out. Add a table with a single row and two columns, then insert a text field in each one, making it side-by-side. The trick is to make sure it is within the subform, and you must select the row and make sure to check "Allow Page Breaks within Content" on that row, because it isn't a default. It works. Thanks (to myself!).
