0 Replies Latest reply on Dec 26, 2013 11:03 AM by ForumPremiereElementsXYZ
    Premiere chashes all the time: audiofilters.dll
      my premiere elements project crashes all the time.
        Problemereignisname:APPCRASH
        Anwendungsname:Adobe Premiere Elements.exe
        Anwendungsversion:11.0.0.0
        Anwendungszeitstempel:505bdbca
        Fehlermodulname:AudioFilters.dll
        Fehlermodulversion:6.0.0.0
        Fehlermodulzeitstempel:505badfd
        Ausnahmecode:c0000005
        Ausnahmeoffset:0001875c
        Betriebsystemversion:6.0.6002.2.2.0.768.3
        Gebietsschema-ID:1031
        Zusatzinformation 1:fd00
        Zusatzinformation 2:ea6f5fe8924aaa756324d57f87834160
        Zusatzinformation 3:fd00
        Zusatzinformation 4:ea6f5fe8924aaa756324d57f87834160
      I run it on a Vista 64bit OS. The project consists of files of two different formates. Here are some examples I've extracted from MediaInfo:
      CompleteName                     : Z:\Video\2013\Australien\filmschnitt\Heimflug.avi
      Format                           : AVI
      Format/Info                      : Audio Video Interleave
      FileSize/String                  : 623 MiB
      Duration/String                  : 8s 400ms
      OverallBitRate/String            : 622 Mbps
      Video
      ID/String                        : 0
      Format                           : YUV
      CodecID                          : IYUV
      CodecID/Info                     : Intel Indeo iYUV 4:2:0
      Width/String                     : 1 920 pixels
      Height/String                    : 1 080 pixels
      DisplayAspectRatio/String        : 16:9
      FrameRate/String                 : 25.000 fps
      ColorSpace                       : YUV
      Compression_Mode/String          : Lossless
      Bits-(Pixel*Frame)               : 12.000
      StreamSize/String                : 623 MiB (100%)
      ID/String                        : 1 (0x1)
      CompleteName                     : Z:\Video\2013\Australien\10-20-2013_171341.m2ts
      Format                           : BDAV
      Format/Info                      : Blu-ray Video
      FileSize/String                  : 155 MiB
      Duration/String                  : 59s 998ms
      OverallBitRate_Mode/String       : VBR
      OverallBitRate/String            : 21.6 Mbps
      OverallBitRate_Maximum/String    : 24.0 Mbps
      Video
      ID/String                        : 4113 (0x1011)
      MenuID/String                    : 1 (0x1)
      Format                           : AVC
      Format/Info                      : Advanced Video Codec
      Format_Profile                   : High@L4.0
      Format_Settings_CABAC/String     : Yes
      Format_Settings_RefFrames/String : 2 frame2
      Format_Settings_GOP              : M=3, N=12
      CodecID                          : 27
      Duration/String                  : 59s 440ms
      BitRate/String                   : 20.4 Mbps
      BitRate_Maximum/String           : 21.6 Mbps
      Width/String                     : 1920 pixel3
      Height/String                    : 1080 pixel3
      FrameRate/String                 : 25.000 fps3
      ColorSpace                       : YUV
      ChromaSubsampling                : 4:2:0
      BitDepth/String                  : 8 bit3
      ScanType/String                  : Interlaced
      ScanOrder/String                 : TFF
      Bits-(Pixel*Frame)               : 0.393
      StreamSize/String                : 144 MiB (93%)
      Audio
      ID/String                        : 4352 (0x1100)
      Format                           : AC-3
      Format/Info                      : Audio Coding 3
      Format_Settings_ModeExtension    : CM (complete main)
      Format_Settings_Endianness       : Big
      CodecID                          : 129
      Duration/String                  : 59s 520ms
      BitRate_Mode/String              : CBR
      BitRate/String                   : 384 Kbps
      Channel(s)/String                : 6 channel3
      ChannelPositions                 : Front: L C R, Side: L R, LFE
      SamplingRate/String              : 48.0 KHz
      BitDepth/String                  : 16 bit3
      Compression_Mode/String          : Lossy
      Video_Delay/String               : -80ms
      StreamSize/String                : 2.72 MiB (2%)
      Text
      ID/String                        : 4608 (0x1200)
      Format                           : PGS
      CodecID                          : 144
      Duration/String                  : 58s 976ms
      The crash appeared since I've introduced a fade out of audio and video on a m2ts-file.
      What could I do?
