1 Reply Latest reply on Dec 12, 2007 11:23 AM by ntsiii
    How do you get edited node label or attributes
    kiwibloke
      I have a tree that has editable="true"
      This enables me to edit the lable of a node in my tree.
      How do you get the new label value from a node that has just been edited? I want to return only this to my database along with the id of the node that was edited.
      I think this involves two things:
      1. How do you identify / interact with the node you have just edited? eg: Get it's id?
      2. How do you get the new attributes values for that node? eg: Get its label value?
      All help greatly appreciated!
        • 1. Re: How do you get edited node label or attributes
          ntsiii Level 3
          If you have edited the node, then it is selected, so you can get a reference to it using:
          myTree.selectedItem;
          How you access the properties depends on what the node item data type is. If xml, then use xml properties and methods like @label.
          tip, selectedItem is always an object. You should cast/convert it into the actual item datatype:
          var xmlNodeSelected:XML = XML(myTree.selectedItem);
          Tracy
