6 Replies Latest reply on Dec 26, 2013 10:14 PM by A.T. Romano
    Load .MOV into adobe première éléments
    Patrick Bourret
      Please someone help me to Load .MOV into adobe première éléments 10?
      Everything should work , new windows computer , new caméra
      Olympus tg1, i Hans QuickTime Pro 7 open on the side !!!
        • 1. Re: Load .MOV into adobe première éléments
          What is inside that MOV wrapper?
          Codec & Format information, with 2 links inside to read -read both links in reply #1 http://forums.adobe.com/thread/1270588
          Report back with the codec details of your file, use the programs below... A screen shot works well to SHOW people what you are doing
          http://forums.adobe.com/thread/592070?tstart=30 for screen shot instructions
          For PC http://mediainfo.sourceforge.net/en or http://www.headbands.com/gspot/
          • 2. Re: Load .MOV into adobe première éléments
            A.T. Romano Level 7
            Patrick Bourret
            First thing we need to do is to know the properties of what is being imported, so that we can set the project preset beforehand.
            From what I have read of your camera, I think that you have H.264.mov 1920 x 1080 @ 30 (maybe 29.97) progressive frames per second.
            If that is the case,
            1. You need to have the latest version of QuickTime installed on your computer
            http://www.apple.com/quicktime/download/
            I have never taken the time to determine if QuickTime Pro is necessarily a substitute for that requirement.
            2. Transfer the video from your camera to the computer hard drive.
            3. Set the Premiere Elements 10 project preset for (assuming PAL for now)
            PAL
            DSLR
            1080p
            DSLR 1080p25
            4. Import your video from its hard drive save location into Premiere Elements 10 project, using the program's Get Media/Files and Folders.
            Have you done all that and not been successful in doing so?
            If problems, then please supply more details
            a. How you are importing your video into Premiere Elements
            b. Define what is not working and any error message(s) associated with the issues.
            Thank you.
            ATR
            Add On....What video card is your computer using?
            Add On...Correction made after original post...frame rate should have been written as 25 progressive frames per second and has been corrected to that.
            • 3. Re: Load .MOV into adobe première éléments
              A.T. Romano Level 7
              John T. Smith
              The Olympus TG1 is using H.264 video compression with the .mov file extension (wrapper format).
              That information can be found online in multiple places.
              ATR
              • 4. Re: Load .MOV into adobe première éléments
                Patrick Bourret Level 1
                thank you very much for the time you give me.
                the video is in the program. i can hear the sound but the image is all green? do you know why?
                • 5. Re: Load .MOV into adobe première éléments
                  A.T. Romano Level 7
                  Patrick Bourret
                  I will try to find a sample from your brand/model camera from online source in order to test the sample in my Premiere Elements 10 to see if I get the green video. I would not expect that of what is described as H.264.mov. I am not sure if we can invoke some sort of Olympus proprietary video codec here.
                  If I cannot find a sample online, would you be able to provide a download of a sample via a link here?
                  You might want to download and install the free codec utility named gspot in order to get a readout for Video and Audio/Codec, Name, and Status.
                  http://www.headbands.com/gspot/v26x/quick_start.html
                  More tomorrow morning.
                  Thank you for the follow ups.
                  ATR
                  • 6. Re: Load .MOV into adobe première éléments
                    A.T. Romano Level 7
                    Patrick Bourret
                    I found a sample video from your brand model camera and have tested it in my Premiere Elements 10 on Windows 7 64 bit.
                    The sample that I test
                    AVCHD video compression
                    .swot audio compression
                    .mov file extension wrapper format
                    1920 x 1080 @ 29.97 progressive frames per second
                    I set the Premiere Elements 10 project preset =
                    NTSC
                    DSLR
                    1080p
                    DSLR 1080p30 @ 29.97
                    I imported the video (saved to my computer desktop) into the project via the program's Get Media/Files and folders. What I imported had the gspot readout out as show in the following screenshot
                    This video on the Timeline displayed with perfect video and audio at play back in the Edit Mode monitor. No green video.
                    Since you are using Premiere Elements 10, I believe that we need to focus on the video card, especially if your video card is from NVIDIA. If so, the answer may be to roll back the video card driver version rather than to assure that you have the latest video card version. Please check out the following
                    http://forums.adobe.com/thread/1317675
                    We will discuss this further in the morning.
                    Thank you for all the helpful information supplied.
                    ATR
                    Add On...I am not sure if there is any merit in replacing QuickTime Pro with the "regular" QuickTime latest version.
