2 Replies Latest reply on Dec 27, 2013 3:43 AM by Mahesh_JW
    Progress Bar not closing
    Mahesh_JW Level 1
      Hi All,
      I am running my scripts from "Adobe Scripts" it runs successfully, but the progress bar window not closing. I run four times. It appears four progress bar window.
      What can I do? Plz help...
      Thanks In Advance,
      Mahesh
        • 1. Re: Progress Bar not closing
          Mi_D Level 3
          Without see the code it's it difficulte where u missout so batter you post your code.
          testing i run one semple script it working fine
          #target indesign
          var loop = new Array (20);
          var w = new Window ('palette');
          w.pbar = w.add ('progressbar');
          w.pbar.preferredSize.width = 300;
          w.show();
          for (var i = 0; i < loop.length; i++){
          w.pbar.value = i+1;
          $.sleep(200)
          Mi_D
          • 2. Re: Progress Bar not closing
            Mahesh_JW Level 1
            Hi Mi_D,
            This is my Main Script in the following path:
            /Users/laser/Documents/Adobe Scripts/MainScript.jsx
            MainScript.jsx
            #target "indesign-7.0"
            var ScripPah = "/Users/laser/Documents/Adobe Scripts/Test/main_validation.jsx";
            var rep = app.doScript(File(ScripPah),1246973031);    //1246973031 - ScriptLanguage.JAVASCRIPT
            main_validation.jsx
            app.activate();
            app.scriptPreferences.version = 6.0;
            var myPrs = new Window('palette', 'X2I',{x:0, y:0, width:400, height:90});
            var prgsBar_FileName = myPrs.add('statictext',{x:10, y:10, width:390, height:15}, "");
            myPrs.active = true;
            myPrs.show();
            open Library
            myPrs.show();
            open Template
            myPrs.show();
            prgsBar_FileName = "ABC.indd"
            My Functions
            myPrs.close();
            when I double click my "MainScript.jsx" it runs in InDesign CS5 successfully but progress bar not closing once the script execution is completed.
            Please advice....
            Mahesh
