6 Replies Latest reply on Dec 27, 2013 10:00 AM by SPAM
    DATA MERGE SLOW
    SPAM
      I'm running Windows 7, plenty of RAM, InDesign CS6, Excel 2007
      Data Merge from Excel spread is very very slow above 100 records.
      Turned off preflight and report generation to see if that helped..not resolved I'm afraid.
      The merge works well with 100 records...
      Any suggestions, as to what to try next
      dave
        • 1. Re: DATA MERGE SLOW
          MW Design Level 5
          How long is a piece of string?
          Hard to answer you. I have no idea of how much text is involved in individual records or actual fields. It takes but a minute here to merge a tab delimited file of 500+ records that ends up producing an 80 page merge file.
          What file format are you merging? Is it the actual placing of an Excel file or merging a delimited type of file?
          • 2. Re: DATA MERGE SLOW
            SPAM Level 1
            its almost 7000 records, with approximately 70 individual placeholders per
            final page, and the placeholders are located within an excel csv file, so I
            am  merging a delimited file.
            rgds
            dave
            In a message dated 12/27/2013 11:32:54 A.M. Eastern Standard Time,
            forums_noreply@adobe.com writes:
            Re:  DATA MERGE SLOW
            created by MW Design (http://forums.adobe.com/people/MW+Design)  in
            InDesign - View the full  discussion
            (http://forums.adobe.com/message/5959682#5959682)
            • 3. Re: DATA MERGE SLOW
              Try saving and using a tab-delimited version.
              Seventy fields is a lot of data, though...
              • 4. Re: DATA MERGE SLOW
                And a lot of RAM is really meaningless. ID CS6 is a 32-bit program, so can only address a bit less than 4 gb.
                • 5. Re: DATA MERGE SLOW
                  MW Design Level 5
                  You may have better success in splitting up the merge into say 3 separate pieces. You can make these 3 merge files from your CSV (and I would use tab delimited as well). Then, with your master merge file, merge one and save the file, then close it. In your master merge file, load #2. Merge it, save and close it. Same with #3.
                  Then open #1, place #2 at the end, place #3 at #2's end.
                  Your file has a lot of fields, a lot of records. I would try the above.
                  • 6. Re: DATA MERGE SLOW
                    SPAM Level 1
                    I'm producing a census form with household occupants names and details hence the number of placeholders...tab delimiting does not fix the issue...cutting down on the number of palceholders doew...gonna have to rethink how i do this...
                    thanks for the help
                    dave
