5 Replies Latest reply on Dec 28, 2013 5:53 AM by Scorpio17523
    GREP expression for last line followed by column break
    Scorpio17523 Level 1
      For all those reading this, thank you for taking the time to help. I'm a noob at GREP expressions and JavaScript so I appreciate all your time and help with this.
      I've written a JavaScript to help my company format some of our work quicker. We have pre-made templates with Character Styles all set up (Body, Header, BodyItalic) etc.
      My script works nearly perfectly for identifying patterns and applying the correct Character style.
      However my expressions don't work perfectly and any last line of text in the text box (linked), that has a column break, does not get formatted.
      This last line is always different depending on the document. So I can't put in constants. They are always variables.
      My current GREP expression is .+~M which in theory should find any character that repeats one or more times and is followed by a column break. The problem is, it only finds the last two characters on the line that are followed by a column break.
      e.g.
      Tribute would be TribuTE
      Eulogy would be EuloGY
      etc etc
      As you can see, they are not always the same words, and could even be a short sentence so I can't just tell it to look for certain words.
      I'm trying to work out why the GREP expression doesn't work. Maybe I'm using the wrong GREP symbols? I don't know, so any assistance would be much appreciated.
      Thank you in advance.
      Scorpio
        • 1. Re: GREP expression for last line followed by column break
          @Scorpio – just tested your GREP in the UI of InDesign CS5.5 v7.5.3 with Mac OSX 10.6.8.
          It worked as you tested. Found the last two characters before the column brake. I mean the first instance of that GREP in the document.
          And then in searching for the next instance, it crashed InDesign…
          That's strange…
          I'll retry and report later.
          Uwe
          • 2. Re: GREP expression for last line followed by column break
            Thanks. I find it quite puzzling, because if you just use the expression .+ it will apply the style to all text. Just by adding ~M to the end restricts it to the last two digits before the column break.
            In my tests, yes if you do it straight into InDesign, within the Paragraph Styles and GREP section, it can cause long freezes and crashes, but if you put it into a JavaScript, it works a lot better.
            • 3. Re: GREP expression for last line followed by column break
              Kai Rübsamen Adobe Community Professional
              This column-break thing seems bugy. I have no idea why only the last two characters are found. If I try to find a whole word with \w+ that does not work. I get also weird results if I try \b\w+~M. The good news is, that InDesign does not crash here.
              However: There is no GREP for search a specific line, so I would search for a columnbreak and then for the line that belongs to the current found:
              app.findGrepPreferences = app.changeGrepPreferences = null;
              app.findGrepPreferences.findWhat = "~M";
              var found = app.activeDocument.findGrep();
              if (found.length > 0) {
              for ( var i = 0; i < found.length; i++ ) {
                var curFound = found[i];
                var curLine = curFound.lines[0];
                curLine.fillColor = app.activeDocument.swatches[4];
              • 4. Re: GREP expression for last line followed by column break
                @Kai – your snippet seems to be a very good idea.
                It's working fine in my InDesign CS5.5.
                I tested a few GREP expressions in the UI of InDesign around ~M.
                One of the strange things is:
                If you just looking for ~M in a positive lookbehind like that:
                (?<=~M)
                you'll get also insertion points right behind paragraph returns or other frame break signs.
                And if you are looking for \r in a positive lookbehind:
                (?<=\r)
                you'll get also insertion points behind all frame breaks.
                Note:
                The unicode for column breaks, frame breaks and other breaks regaring frames and \r is the same:
                \x{d}
                If you copy/paste a frame break sign to the GREP input field of the GREP search/replace panel you'll get: \r
                Uwe
                • 5. Re: GREP expression for last line followed by column break
                  This worked perfectly, thank you so much!!
                  I obviously had to change it so it didn't change the text blue and apply my character style instead but it works just how I want it to.
                  Thank you, and everyone else for all your help.
                  Scorpio
