2 Replies Latest reply on Dec 28, 2013 11:25 AM by JJMack
    help resizing
    Jerry Rupany
      I have to resize photos to 800x384 for my Ford Sync wallpaper. How do I do it and keep the picture from being distorted?
        • 1. Re: help resizing
          the_wine_snob Level 9
          If the Aspect Ratio, i.e. height:width does not match your desired Aspect Ratio, then a Crop, plus probably an Image Size adjustment, will be required so as to not distort the Image.
          Good luck, and hope that helps,
          • 2. Re: help resizing
            800x384 is a 25:12 landscape aspect ratio set the crop or rectangle to that aspect ratio select the composition you want crop it then use Image Size to resample it to 800x constrained.
