I don't know if I have inadvertently changed a setting somewhere but in my preferences dialogue box when I select a group heading on the left (EG General, Interface etc.) the setting turns dark but the lettering also stays dark making the group heading unreadable. I assume it is supposed to show the text as an inverted colour.
To be honest this isn't a big issue - my (minor) concern is that this will be happening in other panels that I haven't noticed yet that might cause bigger problems.
BTW - Windows and Photoshop CC.
Cheers
John
Is this only with Photoshop John? It sound slike you might have changed the Windows interface theme.
I have only noticed this in Photoshop (and only in that panel as well). That is not to say that it isn't a Windows theme problem - I will check to make sure that I haven't left an old theme running. I work with a lot of visually impaired clients so often try out High Contrast themes. I will report back. Thanks for the suggestion.
Cheers
John
OK I re-set my theme to a standard Windows 7 theme and I can now see the text in the panel I mentioned.
I guess that we are all somewhere on the learning curve - I am just striving to be a bit further along than I am now!
Thanks for your help.
Cheers
John
