Hi
I followed this guide to create a search and search reslut page: http://helpx.adobe.com/business-catalyst/partner/add-search-form.html
So I created two pages, one with the search box with following code as suggested on tutorial:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<!-- BC_OBNW -->
<head>
<title>searchx</title>
<link href="/StyleSheets/ModuleStyleSheets.css" type="text/css" rel="StyleSheet" />
<script type="text/javascript">var jslang='SV';</script>
</head>
<body>
<div>
<form name="catsearchform97834" method="post" action="/Default.aspx?SiteSearchID=2556&PageID=/search-results.html">
<div class="search-box"><input class="cat_textbox_small" type="text" name="CAT_Search" id="CAT_Search" /><input class="cat_button" type="submit" value="Search" /></div>
</form>
<br />
</div>
</body>
</html>
And the serarch page caled search-results.html with following code as suggested in the tutorial:
<!DOCTYPE html>
<html>
<head>
<title>search-results</title>
<meta name="description" />
</head>
<body>
{module_searchresults}
</body>
</html>
But I am getting the "Page Not Found" error. Both the pages are in the siteroot..
I have replaced PageID={module_oid} with PageID=/search-results.html.
Can someone help me what mistake I might have done?
It is a common mistake and one I have made several times.
Change this:
to
An example search action would be:
action="/Default.aspx?SiteSearchID=1234&ID=/search-results.html"
The KB says the following:
Replace the PageID={module_oid} parameter with the path and filename of your results page. Note that PageID becomes just ID in this case.
It is simple to overlook and can be confusing as first.
Thanks Lynda, that worked ofcorse Thats what happens when you try to solve something late at night
Merry Christmas
-Sohail
