2 Replies Latest reply on Dec 31, 2013 7:23 AM by LisaN
    pass query id into pop up window
    LisaN Level 1
      i want to be able to pass the id from the query into the popup window but not sure how to do it, would you please help me with this? - thanks
      code below (A) working fine with open the pop up detail page but din't know how to passs an id into detail page.
      <!----A--->
        <script>
      function openWin()
      window.open("detail.cfm","_blank","toolbar=yes, scrollbars=yes, resizable=yes, top=500, left=500, width=400, height=400");
      </script>
      <cfset foo = querynew('id_int,aNo_var,Renew,Cancel')>
         <cfloop query="getOrderHist">
            <cfset queryaddrow(foo)>
                  <cfset querysetcell(foo,'id_int',getOrderHist.id_int)>
                  <cfset querysetcell(foo,'aNo_var',getOrderHist.aNo_var)>
                          <cfset querysetcell(foo,'Renew','<a href="javascript: void(0);" onclick="openWin()">view</a>')>
         </cfloop>
      <!---B--->
      I try to call the page directly such as below but got an error for  "invalid character"
          <cfset querysetcell(foo,'Renew','<a href="javascript: void(0);" onclick="window.open("detail.cfm?id=#id#","_blank");>renew</a>')>
         </cfloop>
        • 1. Re: pass query id into pop up window
          duncancumming Level 3
          you have an 'openWin' function, but then you're trying to add inline JS to do the same thing.  I assume that later on you're looping over your 'foo' query outputting these links to renew.  In which case I'd want to simply pass either a URL or just the ID into the openWin function.  Much simpler than trying to add dynamic JS into a query cell.
          I'm slightly confused as well why you're creating a new query, foo, when you already have the query getOrderHist which seems to have everything you need.
          function openWin(id) {
              window.open("detail.cfm?id=" + id, "_blank","toolbar=yes, scrollbars=yes, resizable=yes, top=500, left=500, width=400, height=400");
          <cfoutput query="getOrderHist">
              aNo: #getOrderHist.aNo_var#<br>
              <a href="" onclick="openWin(#getOrderHist.id_int#); return false;">Renew</a><br>
          </cfoutput>
          • 2. Re: pass query id into pop up window
            LisaN Level 1
            worked, thanks millions
