• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
trying to secure code from sql injection
New Here ,
Dec 12, 2007 Dec 12, 2007
ok so someone is able to add tables into my database. I know i have a whole. I have been correcting all data updates and inserts example
<cfqueryparam CFSQLType = "CF_SQL_VARCHAR" value="#chars#">
<cfqueryparam value="#numbs#">
bow how can i secure a text field
example data for my text field being added
'#Replace("#TextData#", Chr(10), "<br>", "ALL")#'
is there a way to also use fqueryparam on this?
I am also getting errors why trying to use this on the date
this was my date input before
#CreateODBCDateTime(Event_SDate)#
this was after
<cfqueryparam CFSQLType = "CF_SQL_DATE" value="#CreateODBCDateTime(Event_SDate)#">
i get this message
ODBC Error Code = S1C00 (Driver not capable)
I am using MS windows 2008 and MS SQL server 2000
TOPICS
Advanced techniques
Views
743
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Yes, a text area is nothing special to a database. It is just text
being stored into a text field and a text version of <cfqueryparam....>
will preform it's parameterization magic on it. This will prevent all
forms of SQL injection.
The trick is that by telling the DBMS that a value is a parameter the
database does not even look at it as SQL code but only as text and will
just happily store it into the database.
Without <cfqueryparam...>, all the text is SQL and any variables that
contain SQL code is include in the overall SQL statement and run by the
database.
Votes
Translate
Translate
Report
Report
New Here ,
anyway you can give me a quick example of how i would then add
or
into a database while securing it from hacks?
Votes
Translate
Translate
Report
Report
New Here ,
oh wait i just tried this and it worked for the long text
<CFSET Event_Description = "#Replace("#longtext#", Chr(10), "<br>", "ALL")#">
<cfqueryparam CFSQLType = "CF_SQL_VARCHAR" value="#longtext#">
and it worked so now i am just confused on how to get this one into the database saftly
Votes
Translate
Translate
Report
Report
LEGEND ,
> or
<cfqueryparam value='#Replace("#TextData#", Chr(10), "<br>", "ALL")#'
CFSQLType='CF_SQL_VARCHAR'>
AND
<cfqueryparam value='#CreateODBCDateTime(Event_SDate)#;
CFSQLType='cf_sql_timestamp'>
Be aware that there are 'cf_sql_time' and 'cf_sql_date' options as well
depending on exactly what data you want to put into the database.
Votes
Translate
Translate
Report
Report
New Here ,
that worked very good. Thanks so much 🙂
Votes
Translate
Translate
Report
Report
Participant ,
Funny been working on exactly the same thing today,... specifically for script injection/remote command execution....
here is what I did:
1] Called from the application.cfm
<cfinclude template="#application.ServerRoot#/cfmx/sanitize.cfm">
<!--- xss protection/input sanitisation --->
<cfscript>sanitize();</cfscript>
2] the function.
<cfscript>
function sanitize() {
// This function detects and prevents sql/script injection type attacks and remote command execution
// we just need to clean up the regex statements
attack = 0;
email = '';
if (IsDefined('form')) {
for (key in form) {
if (ReFindNoCase('<script',form[key],'1','false') gt 0 ){attack=1;email = email&"<br />FORM STRING FOUND";}
if (ReFindNoCase('script',cgi.QUERY_STRING,'1','false') gt 0 ){attack=1;email = email&"<br />ILLEGAL URL STRING FOUND";}
if (attack eq 1) {
//populate vars
email = email&"<br />";
email = email&"<br />cgi.http_referer = "&cgi.http_referer;
email = email&"<br />cgi.http_user_agent = "&cgi.http_user_agent;
email = email&"<br />cgi.path_info = "&cgi.path_info;
email = email&"<br />cgi.path_translated = "&cgi.path_translated;
email = email&"<br />cgi.query_string = "&cgi.query_string;
email = email&"<br />cgi.remote_Addr = "&cgi.remote_Addr;
email = email&"<br />cgi.remote_host = "&cgi.remote_host;
email = email&"<br />cgi.remote_user = "&cgi.remote_user;
email = email&"<br />cgi.request_method = "&cgi.request_method;
//send mail
cfmail("application.adminmail","A possible web attack has been detected",email,"html");
//getPageContext().forward("/denied.cfm");
cflocation("/denied.htm","no");
</cfscript>
- yep, it's not finished, the regex's need to be written....
and yep every form, every request parses through = ++ overhead,...
but it works..
and it should be easy to add some rewrite rules to form values:
REReplaceNoCase(tmp, "(</?(APPLET|EMBED|FRAME|FRAMESET|IFRAME|ILAYER|LAYER|META|OBJECT|PARAM|SERVER)[^>]*>)", "", "ALL");
-regards
-sean
Votes
Translate
Translate
Report
Report
Explorer ,
Mar 21, 2008 Mar 21, 2008
check udf
Votes
Translate
Translate
Report
Report
Explorer ,
there is UDF for striptext
Votes
Translate
Translate
Report
Report
Contributor ,
LATEST
You can find different resources here:
http://www.cflib.org/library.cfm?ID=1
Votes
Translate
Translate
Report
Report
Resources
Documentation
