0 Replies Latest reply on Dec 31, 2013 3:23 AM by Mudasser
    Facebook GraphAPI_Web_1_8_1 not wokring using Adobe?
    Mudasser Level 1
      i did add the GraphAPI_Web_1_8_1 api in lib folder and then add the following code and then run the app but it never come to the handler once i click on init or click on friend list
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
          <fx:Script>
              <![CDATA[
                  /*import com.facebook.graph.Facebook;
                  import com.facebook.graph.controls.Distractor;
                  import com.facebook.graph.data.FacebookSession;
                  import com.facebook.graph.net.FacebookRequest;
                  import com.facebook.graph.utils.FacebookDataUtils;
                  import com.facebook.graph.net.FacebookRequest;*/
                  import mx.collections.ArrayCollection;
                  import mx.containers.ControlBar;
                  import mx.containers.Panel;
                  import mx.containers.VBox;
                  import mx.controls.Alert;
                  import mx.controls.Button;
                  import mx.controls.Label;
                  import mx.controls.Spacer;
                  import mx.controls.TextInput;
                  import mx.core.IFlexDisplayObject;
                  import mx.events.CloseEvent;
                  import mx.managers.PopUpManager;
                  protected function onApiCallFriends(response:Object, fail:Object):void
                      if (response)
                          var friends:Array = response as Array;
                          Alert.show(friends.length.toString());
                          for (var i:int = 0; i<friends.length; i++) { Alert.show(friends[i]); }
                      else{
                          Alert.show("Failed "+fail.error.message.toString());
                  protected function button1_clickHandler(event:MouseEvent):void
                      // TODO Auto-generated method stub
                      //Facebook.login(hhandleLogin);
                      if (Facebook.getSession()==null ||
                          Facebook.getSession().uid == null)
                      else
                          Facebook.logout(hhandleLogin);
                  protected function hhandleLogin(response:Object, fail:Object):void {
                      Alert.show("yes it comes in it");
                      if (!response)
                          return;
                      button1.label =response.user.username+ 'You are logged in.';
                      button1.enabled = false;
                      //loadFriends();
                  protected function btnInit_clickHandler(event:MouseEvent):void
                      removeEventListener(Event.ADDED_TO_STAGE, init);
                      Facebook.init('763846766955585', hhandleLogin, null, null);
                  protected function button2_clickHandler(event:MouseEvent):void
                      Alert.show("Hello");
                      var params:Object = new Object();
                      params["access_token"] = Facebook.getAuthResponse().accessToken;
                      Alert.show(params["access_token"].toString());
                      Facebook.api("me/friends",onApiCallFriends, params);
          </fx:Script>
          <s:Button id="button1" x="26" y="65" label="Login" click="button1_clickHandler(event)"/>
          <s:Button id="btnInit" x="26" y="26" label="Init" click="btnInit_clickHandler(event)"/>
          <s:Button x="26" y="110" label="Friend List" click="button2_clickHandler(event)"/>
      </s:Application>
      Kindly help me
