14 Replies Latest reply on Jan 1, 2014 2:19 PM by Steve Grisetti
    Project settings iPhone 5
    esmeeschram
      I made my films with an iPhone 5 and edit in PE10. Which project settings (PAL) can I use the best?
        • 1. Re: Project settings iPhone 5
          Open a sample of your video in G Spot or MediaInfo and post the resolution, frame rate and audio and video codecs that it lists.
          http://www.headbands.com/gspot/
          Also, be sure your computer includes the latest version of Quicktime from Apple, per the program's requirements.
          • 2. Re: Project settings iPhone 5
            esmeeschram Level 1
            I can't open G Spot. Is there another way?
            • 3. Re: Project settings iPhone 5
              the_wine_snob Level 9
              Not sure why G-Spot is not working for you, but Steve's other suggestion is MediaInfo: http://sourceforge.net/projects/mediainfo/
              Just make sure that you watch the installation process, so that it does not install any browser toolbars, or other "stuff."
              Also, many phone cameras shoot variable FPS, and that can cause issues too.
              • 4. Re: Project settings iPhone 5
                A.T. Romano Level 7
                esmeeschram
                Although a gspot or MediaInfo video audio properties readout would be supplemental and confirmatory, we probably have all the information needed by Googling for the video audio properties of the iPhone 5 (Apple) camera.
                http://support.apple.com/kb/SP655
                I am 99.999999% certain that you have H.264 video compression, AAC audio, and either a .mov or .mp4 file extension. The important part of the information is the 1080p and a variable frame rate (not sure if the stated frame rate is 30 or 25.).
                But, the following would be my answer to your question....
                If you have H.264.mov or H.264.mp4 @ stated 25 progressive frames per second, then the Premiere Elements 10 project preset should be
                PAL
                DSLR
                1080p
                DSLR 1080p25
                If you have H.264.mov or H.264.mp4 @ stated 30 progressive frames per second, then the Premiere Elements 10 project preset
                should be
                NTSC
                DSLR
                1080p
                DSLR 1080p30
                Render the Timeline, if necessary, once you drag the file to the Timeline. (If you have the correct project preset, no rendering possible or available because you already have the best preview.) If you encounter out of sync audio using the correct project preset, then you will forced to explore taking the iPhone video through QuickTime Pro or Handbrake to achieve a non variable frame rate before importing the file into Premiere Elements 10.
                I have looked at iPhone 5 video in Premiere Elements with the appropriate project preset, and it has worked fine.
                Please review and let us know if any of the information above worked for you.
                Please do not hesitate to ask if you need clarification on anything that I have written.
                Thanks.
                ATR
                Add On...I am using the modifier "stated frame rate" to distinguish it from the minimum and maximu frame rates that would be shown along with the "stated frame rate".
                • 5. Re: Project settings iPhone 5
                  esmeeschram Level 1
                  Thanks for all your answers. When I import the media files (photo and video), by some videos I got: The importer reported a generic error.
                  I can import some videos, but by others I can't
                  Do you know why some of the videos I can't import?
                  • 6. Re: Project settings iPhone 5
                    If you'd post your MediaInfo data, we'd be able to give you specific answers.
                    But ATR is right. The DSLR 24p video project presets will work for most iPod/iPad/iPhone video (assuming you've got the latest version of Quicktime installed on your computer and you're opening MOV files). Though it's hard to say which specific project preset you need without your video data.
                    • 7. Re: Project settings iPhone 5
                      A.T. Romano Level 7
                      esmeeschram
                      Thanks for the reply.
                      If the video has the MXF format, that is a problem for Premiere Elements. So, to answer your question
                      then we need to know...
                      a. are you dealing with MXF format in any of the videos.
                      b. are the failures only in the footage from the Canon....if some of the Canon footage imports while some does not, is all the footage shot at the same Canon setting?
                      c. are any of the failures to import involved with the cell phone footage?
                      The key is to select the project preset that matches the properties of the source media. Have you been doing that? And, if you have mixed formats, which project preset have you been favoring as the choice?
                      ATR
                      • 8. Re: Project settings iPhone 5
                        A.T. Romano Level 7
                        esmeeschram
                        I did not see SG's post until after I had posted mine.
                        He brings up an excellent point with regard to the question that you asked me.
                        Do you have the latest version of QuickTime installed on your computer along with Premiere Elements? That is not going to change the MXF situation if it exists, but it will others formats.
                        More later.
                        ATR
                        • 9. Re: Project settings iPhone 5
                          esmeeschram Level 1
                          I got this back from MediaInfo:
                          Algemeen
                          Complete name                            : G:\Montage\Londen 2013\Bestanden iPhone\IMG_0022.MOV
                          Format                                   : MPEG-4
                          Format profile                           : QuickTime
                          Codec ID                                 : qt
                          File size                                : 30,5 MiB
                          Duration                                 : 24s 368ms
                          Overall bit rate                         : 10,5 Mbps
                          Recorded date                            : 2013-12-21T16:07:33+0100
                          Encoded date                             : UTC 2013-12-21 15:07:33
                          Tagged date                              : UTC 2014-01-01 16:30:51
                          Writing application                      : 7.0.4
                          Writing library                          : Apple QuickTime
                          Model                                    : iPhone 5
                          ©xyz                                     : +51.5078-000.0741-004.209/
                          Make                                     : Apple
                          Video
                          Format                                   : AVC
                          Format/Info                              : Advanced Video Codec
                          Format profile                           : Baseline@L3.1
                          Format settings, CABAC                   : Nee
                          Format settings, ReFrames                : 1 frame
                          Format settings, GOP                     : M=1, N=30
                          Codec ID                                 : avc1
                          Codec ID/Info                            : Advanced Video Coding
                          Source duration                          : 24s 390ms
                          Bit rate                                 : 10,4 Mbps
                          Width                                    : 1 280 pixels
                          Height                                   : 720 pixels
                          Display aspect ratio                     : 16:9
                          Rotation                                 : 180°
                          Frame rate mode                          : Variabel
                          Frame rate                               : 29,970 fps
                          Minimum frame rate                       : 28,571 fps
                          Maximum frame rate                       : 30,000 fps
                          Color space                              : YUV
                          Chroma subsampling                       : 4:2:0
                          Bit depth                                : 8 bits
                          Scan type                                : Progressief
                          Bits/(Pixel*Frame)                       : 0.377
                          Stream size                              : 30,3 MiB (99%)
                          Source stream size                       : 30,3 MiB (99%)
                          Title                                    : Core Media Video
                          Tagged date                              : UTC 2013-12-21 15:07:45
                          colour_primaries                         : BT.709
                          transfer_characteristics                 : BT.709
                          matrix_coefficients                      : BT.709
                          Audio
                          Format                                   : AAC
                          Format/Info                              : Advanced Audio Codec
                          Format profile                           : LC
                          Codec ID                                 : 40
                          Duration                                 : 24s 367ms
                          Source duration                          : 24s 404ms
                          Bit rate mode                            : Constant
                          Bit rate                                 : 64,0 Kbps
                          Channel(s)                               : 1 kanaal
                          Channel positions                        : Front: C
                          Sampling rate                            : 44,1 KHz
                          Stream size                              : 187 KiB (1%)
                          Source stream size                       : 187 KiB (1%)
                          Title                                    : Core Media Audio
                          • 10. Re: Project settings iPhone 5
                            esmeeschram Level 1
                            This is the information from the movie clip I can't open in Adobe Premiere Elements. Or do you want the information from a file I can open?
                            • 11. Re: Project settings iPhone 5
                              That additional info might be useful too.
                              I see that in the problematic file(s), the FPS (Frames Per Second) is Variable, and that can cause issues. I would anticipate that the files, which do not cause an issue, the FPS will be fixed, say 30 FPS.
                              Good luck, and please let us know a bit more.
                              • 12. Re: Project settings iPhone 5
                                esmeeschram Level 1
                                And is it possible to get the problematic files which are variable transfer/convert to a fixed FPS?
                                • 13. Re: Project settings iPhone 5
                                  esmeeschram Level 1
                                  I also put a video clip which is working in MediaInfo and got this data:
                                  General
                                  Complete name                            : G:\Montage\Londen 2013\Bestanden iPhone\IMG_0003.MOV
                                  Format                                   : MPEG-4
                                  Codec ID                                 : qt
                                  File size                                : 39.1 MiB
                                  Duration                                 : 22s 442ms
                                  Overall bit rate                         : 14.6 Mbps
                                  Recorded date                            : 2013-12-21T15:34:56+0100
                                  Encoded date                             : UTC 2013-12-21 14:34:57
                                  Tagged date                              : UTC 2014-01-01 16:30:47
                                  Model                                    : iPhone 5
                                  ©xyz                                     : +51.5076-000.0781+000.146/
                                  Make                                     : Apple
                                  Video
                                  Format                                   : AVC
                                  Format profile                           : High@L4.1
                                  Format settings, CABAC                   : Yes
                                  Codec ID                                 : avc1
                                  Source duration                          : 22s 453ms
                                  Bit rate                                 : 14.5 Mbps
                                  Width                                    : 1 920 pixels
                                  Height                                   : 1 080 pixels
                                  Frame rate mode                          : Variable
                                  Frame rate                               : 29.970 fps
                                  Minimum frame rate                       : 28.571 fps
                                  Maximum frame rate                       : 30.000 fps
                                  Color space                              : YUV
                                  Bit depth                                : 8 bits
                                  Scan type                                : Progressive
                                  Bits/(Pixel*Frame)                       : 0.234
                                  Stream size                              : 38.9 MiB (99%)
                                  Source stream size                       : 38.9 MiB (99%)
                                  Tagged date                              : UTC 2013-12-21 14:35:09
                                  Color primaries                          : BT.709
                                  Transfer characteristics                 : BT.709
                                  Matrix coefficients                      : BT.709
                                  Audio
                                  Format                                   : AAC
                                  Format profile                           : LC
                                  Codec ID                                 : 40
                                  Duration                                 : 22s 440ms
                                  Source duration                          : 22s 477ms
                                  Bit rate                                 : 64.0 Kbps
                                  Channel(s)                               : 1 channel
                                  Sampling rate                            : 44.1 KHz
                                  Compression mode                         : Lossy
                                  Stream size                              : 172 KiB (0%)
                                  Source stream size                       : 173 KiB (0%)
                                  Also VARIABLE?
                                  • 14. Re: Project settings iPhone 5
                                    Assuming you've got the latest version of Quicktime installed on your computer (you still haven't said), you should be able to work with this video is you start a project with these project settings:
                                    DSLR/720p/DSLR 720p24
