1. Re: which the best skill to lower the contrast and saturation of a jpg cs6?
John_Picton Jan 1, 2014 9:28 AM (in response to Giovannivolontè)I would start by looking at Levels and Curves adjustment layers.
If you do a Google search for levels and curves tutorials you will get plenty.
Here is one to get you started. http://www.youtube.com/watch?v=XRo_5kC3GNE
Fact is that the best results are usually a combination of techniques (including the saturation and brightness / contrast adjustments).
BTW - in the main make sure you are using adjustment layers instead of adjusting the whole image as this is non-destructive.
Good luck
Cheers
John
2. Re: which the best skill to lower the contrast and saturation of a jpg cs6?
Trevor.Dennis Jan 1, 2014 1:35 PM (in response to Giovannivolontè)What version of Photoshop? (it makes a difference to what tools are available)
Do they look equally over saturated when viewed outside of Photoshop? It might be a colour space problem, for instance. A good rule of thumb is to upload one to a web sharing site, or even to this thread. What see on your web browser is going to be similar to how other people will see your images, screen calibration issues not withstanding.
3. Re: which the best skill to lower the contrast and saturation of a jpg cs6?
Noel Carboni Jan 1, 2014 2:58 PM (in response to Giovannivolontè)Personally I'd switch them to 16 bits/channel mode, then use Image - Adjust followed by several different tools, e.g., Hue/Saturation and Curves.
There are those who might prefer adjustment layers, for their ability to tweak a bit more later, and that's fine too. There are Hue/Saturation and Curves adjustment layers.
-Noel
4. Re: which the best skill to lower the contrast and saturation of a jpg cs6?
gator soup Jan 1, 2014 3:31 PM (in response to Giovannivolontè)i would first make sure you are applying the correct source profile
try Edit>AssignProfile: sRGB, AdobeRGB, ProphotoRGB, AppleRGB, MonitorRGB (five different profiles to try)
if any of those improve the color (and your monitor profile is good)...then Assign that profile and then, Edit>ConvertToProfile (probably sRGB is the safest...then Save As EMBEDD the ICC Profile)
then go to work on the color as recommended (check out Adjustment Layers)...
5. Re: which the best skill to lower the contrast and saturation of a jpg cs6?
Giovannivolontè Jan 3, 2014 12:21 AM (in response to John_Picton)thanks
i know how use levels and curves
these images comes from a camera ,set (sadly in jpg and not raw) and they have strong contrast and colors
6. Re: which the best skill to lower the contrast and saturation of a jpg cs6?
Giovannivolontè Jan 3, 2014 12:22 AM (in response to Trevor.Dennis)hi
cs6 64bit ,windows 7
why? does cc include more tools about fix images with too much cotrast and color
7. Re: which the best skill to lower the contrast and saturation of a jpg cs6?
Giovannivolontè Jan 3, 2014 12:24 AM (in response to gator soup)hi
thanks
i found this http://digital-photography-school.com/fixing-images-with-contrast-masks-in-photoshop
it helps a bit
i miss some good skil to reduce image taken in jpg with too much contrast and high saturation
8. Re: which the best skill to lower the contrast and saturation of a jpg cs6?
station_two Jan 3, 2014 2:43 AM (in response to Giovannivolontè)Among the gazillion ways to compensate for hypersaturation and excessive contrast, do not overlook a Vibrance adjustment layer.
9. Re: which the best skill to lower the contrast and saturation of a jpg cs6?
Giovannivolontè Jan 3, 2014 7:51 AM (in response to station_two)Among the gazillion
what's the meaning?
well i try every photoshop cs6 tools
the pictures are in this case portraits of women and and I'm reluctant to upload , because after i can't delete in forum
10. Re: which the best skill to lower the contrast and saturation of a jpg cs6?
Noel Carboni Jan 3, 2014 1:02 PM (in response to Giovannivolontè)"Gazillion" is a slang expression that generally translates to "many, many".
I more often say "bizillion" or "eleventy seven" myself.
-Noel
