2 Replies Latest reply on Jan 2, 2014 10:02 AM by polyxo
    is this doable per action or would one need to script this?
    polyxo Level 1
      Hi All,
      I would like to automate some simple I/E- operations and thought that macro recording (actions) in this case should
      suffice. But to my great surprise a lot of standard operations available from the menus are ignored by the recorder.
      One for instance can open a dwg-file through an action and also run Select All but there seems no way to record
      Object/Artboards/Fit to selected Artwork bounds. Is this observation correct so far or am I just doing something wrong here?
      Apart from that I would need a way to "super-expand" selected items temporarily - so that appearances and groups are
      flattened. The outcome should be exported to .dwg - then all flatten-operations should get rolled back.
      Again I naively assumed that one could simple include some Undo's into an action - but I had to realize that already
      "expand appearance"doesn't record.  Is it correct that one can not do such by Macro but rather needed to script?
