5 Replies Latest reply on Feb 1, 2014 4:25 PM by Colin Flashman
    Delete Text Frame out of page
    creativejoan0425 Level 1
      I want to delete text frame either is blank or have text that out of the page in all opened document, below script can delete all text frame in all opened document, but I want to keep the text frame inside the page, can anyone help me?
      var myDoc = app.documents.length;
      for (var k= myDoc -1; k >= 0; k--) {
      var myStories = app.documents[k].stories.everyItem().getElements();
      for (i = myStories.length - 1; i >= 0; i--){
          var myTextFrames = myStories[i].textContainers;
          for (j = myTextFrames.length - 1; j >= 0; j--)    {
                  myTextFrames[j].remove();
        • 1. Re: Delete Text Frame out of page
          Daniel Sterchi Level 3
          Hi creativejoan0425
          Give this script a try:
          It delets all Textframe which are totaly off a page
          It delets all empty Textframes
          Script works for multiple document and multiple pages.
          main();
          exit();
          function main() {
               var myDocs = app.documents.everyItem().getElements();
               for (var j = myDocs.length -1;  j >= 0; j--) {
                    var myTextFrames = myDocs[j].textFrames.everyItem().getElements();
                    for (var i = myTextFrames.length -1; i >= 0 ; i--) {
                          // is null, if the textfame is totaly off the pagae
                         if (myTextFrames[i].parentPage == null) myTextFrames[i].remove();
                         // deletes empty Textframe
                         else if (myTextFrames[i].contents == "") myTextFrames[i].remove();
                    } // for
                    myDocs[j].save() // Save the actual Document
                    myDocs[j].close()     // close the actual Document
               } // for
          } // main
          Kind Regard
          Dani (from Switzerland)
          • 2. Re: Delete Text Frame out of page
            Jump_Over Level 5
            creativejoan0425 wrote:
            ... that out of the page...
            If "out of page" means do not overlap with page bounds ==> textFrame.parentPage == null, so:
            var
                 mDoc = app.documents,
                 dLen = mDoc.length,
                 cDoc, cParent, cLen;
            while (dLen-->0) {
                 cDoc = mDoc[dLen];
                 cParent = cDoc.textFrames.everyItem().parentPage;
                 cLen = cParent.length;
                 while (cLen -->0)
                      if (cParent[cLen] == null)
                           cDoc.textFrames[cLen].remove();
            Jarek
            Message was edited by: Jump_Over :) yeap Dani, didnt see your post :)
            • 3. Re: Delete Text Frame out of page
              If i want to out of page + document bleed?
              從三星手機發送
              • 4. Re: Delete Text Frame out of page
                @creativejoan0425 – see the following blog post:
                Marc Autret
                Clean up your Pasteboard!
                http://www.indiscripts.com/post/2009/09/clean-up-your-pasteboard
                Uwe
                • 5. Re: Delete Text Frame out of page
                  Colin Flashman Adobe Community Professional
                  Be careful of any script that says it "deletes empty textframes". While a textframe may not contain any text, it may contain:
                  • a fill;
                  • a stroke;
                  • a text wrap feature;
                  • type on a path;
                  • be grouped to another object
                  • a link to an anchored object
                  • part of a multi-state object or a button
                  feathering my own nest, there is a script on my blog that is a collaboration of many authors that may help:
                  http://colecandoo.wordpress.com/2013/12/22/a-christmas-treat-empty-frame-remover-v1-0/
                  its purpose: delete empty text frames, that is all. It won't target any extra objects on the pasteboard such as pictures or graphics that aren't used... in fact it doesn't target the pasteboard at all, that's where Marc Autret's script is useful
