1 Reply Latest reply on Jan 2, 2014 12:03 PM by sjpt
    Erasing my computer authorization may lose my DRM books?
    Donec
      I am trying to re-activate my computer with an Adobe ID using ADE but the dialogue box says I may not be able to read DRM protected books in your library.   I am using Ctrl+Shift+D.   How do I re-activate without losing my recently purchased and unread books?   I am using a Kobo Aura HD that I have just purchased for Chrismas..
        • 1. Re: Erasing my computer authorization may lose my DRM books?
          sjpt Level 4
          Have you already downloaded and opened some DRM bools to ADE before activating it with your Adobe ID?
          If so, slight problem:  read the below, and don't activate it until you have decided what you want to do.
          This is a vicious trap that Adobe lays for unsuspecting customers.
          They do give very mild warnings, but not nearly strong enough.
          When you register 'without ID', ADE creates an anonymous/implicit ID with limited powers (eg can't be used to share with other devices).
          Whenever you first load a DRM book, that copy of the book is associated with whatever ID the computer is registered to at the time.
          Any book you load while this anonymous ID is active gets associated with that ID, and can't be read on any other device.
          When you properly register your computer with a real ID, that old anonymous ID is lost.
          Now you don't have any devices that can read the book.
          The only way I know round this is to use a DRM stripper such as epubee BEFORE you deauthorize the device.
          I do NOT advocate using such code to get around the valid limitations placed on a DRM book.
          However, where the problem arises only because of the ineptness of Adobe's ADEPT DRM infrastructure and its implementation,
          such a measure is totally justifiable.
