3 Replies Latest reply on Jan 3, 2014 7:23 AM by Peter Spier
    Unable to open ID CS 5
    addy1cat
      First, crashed when opening an existing document
      Second, crashes everytime try to open CS 5
      Did an uninstall. Went to cloud and did a new install. Same problem.
      Tried to download CC version, even though I don't want to change to newer version. and would not complete the download.
      Must have something going on that I can't see.
        • 1. Re: Unable to open ID CS 5
          Sounds like the recovery data is corrupt. Find and empty the InDesign Recovery folder (see Replace Your Preferences) for where to look fo the default location -- it's normally in the same folder withthe InDesign Defaults file and it will be hidden in most recent OS versions.
          • 2. Re: Unable to open ID CS 5
            addy1cat Level 1
            I can't find these files. I believe it is because I did an UNINSTALL and then INSTALL. Unless I am looking in the wrong place.
            I do have a CS4 active version still on my computer, but of course, it won't open my newer files.
            What I found in LIbrary is a folder named Adobe InDesign. In that folder is a folder are 4 folders: Version 5.0, Version 6.0, Version 7.5 and Version 9.0 and this one is empty.
            These folders have "InDesign Defaults" but don't have "SavedData".
            Suggestions?
            • 3. Re: Unable to open ID CS 5
              You're in the wrong folder. Look at the paths carefully. There are two folders involved, and the paths look similar if you are not paying close attention.
