• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Non-OS Volume detected
Guest
Jan 02, 2014 Jan 02, 2014
Attempting to install latest flash on Mac OS X 10.6.8 fails, appending the following two lines to /var/log/install.log:
... installer[366]: JS: Flash Player Install: Performing volume check for /
... installer[366]: JS: Flash Player Install: Error: Non-OS Volume detected.
Also tried uninstall, which succeeds, but behavior on install is unchanged.
There is nothing unusual about the root partition (which is the only partition);
no dual-boot or other funkiness.
wazzup?
/phj
Views
695
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Jan 03, 2014 Jan 03, 2014
Are you installing from the installer or the Flash Player.pkg inside the installer?
Votes
Translate
Translate
Report
Report
Guest
I'm running 'Install Adobe Flash Player.app' located at the top level
of the Flash Player volume mounted by running the downloaded dmg.
/phj
Votes
Translate
Translate
Report
Report
LEGEND ,
Jan 04, 2014 Jan 04, 2014
Try right clicking the installer and "Show package contents"
Then double click the Adobe Flash Player.pkg inside Contents/Resources folder
Votes
Translate
Translate
Report
Report
Guest
Behavior is unchanged (except that it puts up a shell window to run the
command).
/phj
Votes
Translate
Translate
Report
Report
LEGEND ,
What format is your Mac HD?
(This is starting to look like a "Case Sensitive" problem)
Votes
Translate
Translate
Report
Report
Guest
LATEST
   File System:          Journaled HFS+
   Type:                 hfs
   Name:                 Mac OS Extended (Journaled)
   Journal:              Journal size 24576 KB at offset 0x114d3000
   Owners:               Enabled
   Partition Type:       Apple_HFS
   Bootable:             Is bootable
We really need an Adobe developer to chime in with what, exactly, the
"volume check" is doing.
I should say that flash has been working on this computer for years;
now, since I did an uninstall in an attempt to correct the failed install,
it doesn't work. I am massively annoyed.
/phj
Votes
Translate
Translate
Report
Report
