5 Replies Latest reply on Jan 3, 2014 6:46 AM by Szalam
    What can I do to speed up rendering?
    TriforceStudios
      THIS QUESTION. HAS. BEEN. ASKED. TO. DEATH. I  KNOW
      But the answers have become so common that someone like me who knows how to use AE but doesn't know about rendering does not understand the jargon
      I rendered a clip using Trapcode Particular and some flux to create a particle trail, and behind that I had a clip of paticular running with some glow. This is it.
      http://www.youtube.com/watch?v=fedcUIb1OIo
      NOW, that render took about maybe 5 minutes? probably less I don't remember, but it was short.
      I have renedered large clips in Pr and it takes at max maybe 15 - 30 minutes with tons of effects(short of warp stabalizer, and with every single clip having some type of Magic Bullet Looks effect). That took maybe about an hour for a 4 minute video.
      I go into AE, and I create this. https://www.mediafire.com/?iqg25p7i62826iw
      If you have Trapdcode, it should open, but since that's just an idea of what I have, hopefully I can explain whats in it.
      I have one comp where there's 3D text that has ray traced 3D and been moved to have a kind of corner alignment
      The next comp is THAT SAME ONE I JUST POSTED I just shifted it into this project/comp and took out all the backgrounds and other particles, now the only thing there is the "flame" particles. I also tracked that one to move throughout the first 30 seconds and then disappear
      Next comp is an audio spectrum, duplicated and fliped so the audio at both ends is the starting frequency.
      I precomped a lot of ****, but I cleared out what I didn't need and only have two comps left in the main composition.
      Why is it this render is taking 28 hours? Nothing on earth ever took this long for me, and you're talking to the guy who warp stabalized a 2 hour film because he could.(EVEN THAT TOOK 6 HOURS, UNDERSTANDABLE)
      What can I do to somehow reduce this time? I've already done the render as a quick time format thing, that reduced it to about 11 hours. But this clip is only 1:35 long.
      whyyyyy
      System Information
      Time of this report: 1/2/2014, 23:23:01
             Machine name: MGREENSCOMPUTER
         Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532)
                 Language: English (Regional Setting: English)
      System Manufacturer: Dell Inc.
             System Model: XPS 8300
                     BIOS: BIOS Date: 02/15/11 09:36:59 Ver: 04.06.04
                Processor: Intel(R) Core(TM) i5-2300 CPU @ 2.80GHz (4 CPUs), ~2.8GHz
                   Memory: 6144MB RAM
      Available OS Memory: 6126MB RAM
                Page File: 4724MB used, 7526MB available
              Windows Dir: C:\Windows
          DirectX Version: DirectX 11
      DX Setup Parameters: Not found
         User DPI Setting: Using System DPI
      System DPI Setting: 96 DPI (100 percent)
          DWM DPI Scaling: Disabled
           DxDiag Version: 6.01.7601.17514 64bit Unicode
        DxDiag Previously: Crashed in DirectShow (stage 1). Re-running DxDiag with "dontskip" command line parameter or choosing not to bypass information gathering when prompted might result in DxDiag successfully obtaining this information
      DxDiag Notes
            Display Tab 1: No problems found.
              Sound Tab 1: No problems found.
              Sound Tab 2: No problems found.
                Input Tab: No problems found.
      DirectX Debug Levels
      Direct3D:    0/4 (retail)
      DirectDraw:  0/4 (retail)
      DirectInput: 0/5 (retail)
      DirectMusic: 0/5 (retail)
      DirectPlay:  0/9 (retail)
      DirectSound: 0/5 (retail)
      DirectShow:  0/6 (retail)
      Display Devices
                Card name: AMD Radeon HD 6700 Series
             Manufacturer: Advanced Micro Devices, Inc.
                Chip type: AMD Radeon Graphics Processor (0x68BA)
                 DAC type: Internal DAC(400MHz)
               Device Key: Enum\PCI\VEN_1002&DEV_68BA&SUBSYS_31501682&REV_00
           Display Memory: 3823 MB
         Dedicated Memory: 1015 MB
            Shared Memory: 2807 MB
             Current Mode: 1440 x 900 (32 bit) (60Hz)
             Monitor Name: Dell SE198WFP(Analog)
            Monitor Model: DELL SE198WFP
               Monitor Id: DELF003
              Native Mode: 1440 x 900(p) (59.887Hz)
              Output Type: HD15
              Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.d ll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
      Driver File Version: 8.17.0010.1191 (English)
           Driver Version: 12.104.0.0
              DDI Version: 11
             Driver Model: WDDM 1.1
        Driver Attributes: Final Retail
         Driver Date/Size: 3/28/2013 21:37:02, 1155264 bytes
              WHQL Logo'd: Yes
          WHQL Date Stamp:
        Device Identifier: {D7B71EE2-2BFA-11CF-9571-5A11BEC2C535}
                Vendor ID: 0x1002
                Device ID: 0x68BA
                SubSys ID: 0x31501682
              Revision ID: 0x0000
