1 Reply Latest reply on Dec 6, 2007 7:48 AM by HomerGaines
    Combobox and set variable
      Here´s a example:
      I have a combobox with the following choices:
      Are you a male or woman?
      - Men
      - Woman
      And what´s your age?
      - over 40
      - under 40
      I want to set the variables and Post the variables to the server.
      I cant find any tutorials...(I´m using asp as server-script)
      I really appreciate some answer
        • 1. Re: Combobox and set variable
          Did something similar using jsp.
          Not sure if you have done this as of yet but you should have your variables set up in you code first like...
          var usrGender:String;
          var usrAge:String;
          You should write a listener that 'listens" for a change in the drop down. When a change is "hear", the code then writes the correct data value to your variables. When the usr submits the data, this data should be posted to your asp file.
