0 Replies Latest reply on Dec 5, 2007 10:15 AM by sldorman
    Getting different results from command-line compile depending on Flex Builder running or not
    sldorman
      I have an Ant script that uses the flex ant tasks to compile my .mxml files. If I don't have Flex Builder up and running, I get a .swf file for each of my .mxml files. If I have Flex Builder up and run the same Ant script from the same command window, I now get many files, including debug swf files (I don't have debug turned on in Ant). The size of my swf files is also quite different.
      Why would having Flex Builder running make a difference to the command-line compiler? I checked my environmental variables and didn't see anything change. The Ant script is referencing the compiler and libs in the Flex Builder 2/Flex SDK 2 directory.
      Thanks in advance.
