10 Replies Latest reply: Jan 5, 2014 6:50 PM by SausalitoDog RSS
    How does Edit in... Work?
    Picturequest Community Member
      I ask because, I use PS, and a number of plugins. I'd like to see if it would be possible to add meta data such as edited in "Nik Color Efex" just prior to sending it to the plug-in. That would allow me to keep a smart collection, where i could find all files, edited in PS, All files edited in Silver Efex.
      If it is to hard to create my own Edit in... sub menu item, What about a macro, or key combination that could append the file name or meta data, then execute the Edit in... command.
      Are there any abilities in 5.3 (win7) that could do this?
      I know in PS and illustrator there are actions, and even java scipts that can be run.
      I just need to get my workflow organized.
      Maybe one day Lightroom will store these very important transition in a searchable way, but for now I'd like some process to "tag" the images.
        • 1. Re: How does Edit in... Work?
          SausalitoDog Community Member
          After you EditIn PS, you Save (not saveas) the file and it is saved in LR with "edit" appended to file name right alongside the original raw file.
          So you would know it was edited outside of LR. If you wanted to add some metadata, you could either add a keyword to search on or make a Virtual Copy and name it with whatever code you wanted. Actually, if you only use a few external editors, you could tag it with a color label, one for each editor. As an example, I always label any file I printed with blue - very easy to find printed files.
          Maybe some of the more experienced guys will have a more elegant solution, but this can get you started...
          Cheers,
          Tom
          • 2. Re: How does Edit in... Work?
            dj_paige Community Member
            I agree with SausalitoDog, if you want metadata to indicate that the photo was edited in a specific application, you would have to assign the metadata yourself. If you want to determine if the photo has been edited outside of LR, you could simply search for all photos with the same base name (for example, DSC_0001) and since LR adds "-edit" to the file name when you use Edit In..., then such a search would find DSC_0001 and DSC_0001-edit
            • 3. Re: How does Edit in... Work?
              My last shoot in Cuba was over 4000 images. Some multi exposure panos etc. In the perfect world, when I'm working on an image, after a half dozen virtual copy versions. Some edited out to NIK plug ins, or Topaz etc, I would carefully add meta data indicating my workflow. But that doesn't always work.
              So, I'm trying to figure a way to assist me in sorting these versions.  If I can tell which images were printed, most likely, those were the final best versions. So a smart folder PRINTED would be tremendously helpful.
              A smart collection for NIK COLOR EFEX would be very useful in reminding me what processes I did.
              I'm wondering if it would be possible to set up a menu item or key, that would  1) ADD THE META DATA I NEED, then execute the say Edit in Silver Efex.?
              Are there any features like PS or Illustrator's Actions etc?
              • 4. Re: How does Edit in... Work?
                JimHess Community Member
                This probably isn't going to solve the problem for you. But when I use the Nik plug-ins I like to do it from Photoshop rather than Lightroom. I don't like to clutter Lightroom with a lot of virtual copies. Using Nik in Photoshop stores each Nik adjustment on its own layer. Then I can save that image including the layers so that I can look at the workflow if necessary.
                • 5. Re: How does Edit in... Work?
                  Most of the stuff you would do in PS with actions, you do in LR with Presets, but I don't know of any way to manage metadata with presets.
                  I think if you can narrow your category of situations to 3 or 4, you would find that a color label (which is searchable and can be assigned with a single keystroke) will fix you up with a solution that is even simpler than a keystroke for an action...worth trying.
                  • 6. Re: How does Edit in... Work?
                    Jim-
                    Do you mean that you actually locate the file on your system and OPEN it in PS rather than LR?
                    If so, doesn't that render the image unsearchable in the catalog?
                    I rarely go from LR straight to a plugin but go Edit In PS and then use filters and plugins to my hearts content... To your point, I really don't know if it saves the layers when I save it back to LR. I really don't care so much about that in all but the rarest cases (where I would want to go back and insert changes in a single layer) as I do care about having everything in the catalog data base.
                    How to you handle these two conflicting mandates? (maybe I need a tweak in MY workflow)...
                    Tom
                    • 7. Re: How does Edit in... Work?
                      I prefer Tiffs to PS files. I'm pretty sure the roundtrip as a TIFF keeps all layer intact.
                      • 8. Re: How does Edit in... Work?
                        Geoff the kiwi CommunityMVP
                        It does....
                        • 9. Re: How does Edit in... Work?
                          I think you misunderstood my workflow. I always start in Lightroom, choosing to "edit in" Photoshop. After the image opens in Photoshop I start working with the Nik plug-ins, saving each adjustment from Nik to its own layer. When that image is saved and returned to Lightroom, if I haven't flattened the image removing all layers, those layers are retained the next time I open that image in Photoshop. I don't always retain the layers, but when I do they are always there and available.
                          • 10. Re: How does Edit in... Work?
                            Jim-
                            That's what I more or less assumed but wanted to state it like that for the benefit of Picturequest.
                            That's just how I use the plugins as well and love working that way.
                            Cheers,
                            Tom
