1 Reply Latest reply on Jan 4, 2014 12:24 PM by nealeh
    Import 8mm movies directly into Elements 12
      Curious to know if it is possible to directly import 8mm movies via a camcorder, through a Canopus ADVC110 analog to digital converter device, directly into Premiere Elements 12?  If so, how would that be accomplished, and what are the settings necessary for optimal quality?
        • 1. Re: Import 8mm movies directly into Elements 12
          nealeh Level 5
          Yes you can but I recommend (and always use myself) WinDV or Exsate DV Capture Live. There are no settings in PRE that affect the quality of DV import as it (and the other two tools I've mentioned) capture the complete raw video stream from the digitizer. It is the settings on the digitizer that can affect the quality of that stream and, frankly, I find the Canopus manuals so unhelpful and poorly written that I've always just gone with the defaults.
          If this post or another user's post resolves the original issue, please mark the posts as correct and/or helpful accordingly. This helps other users with similar trouble get answers to their questions quicker. Thanks.
