3 Replies Latest reply on Jan 5, 2014 9:35 AM by A.T. Romano
    Stop markers in Premier Elements 11
    crankyuser1
      I am using Premier Elements 11 and tried to write a Blu-Ray disc with a menu and stop markers.  The disc works, but the stop markers do not, and the flow does not return to the menu.  In the known problems with Premier Elements 10, it says the stop markers do not work on a Blu-Ray disc!!  What about Premier Elements 11?  Is there a way to make them work?
      What about Premier Elements 12, is this conspicuous problem resolved or not?
        • 1. Re: Stop markers in Premier Elements 11
          A.T. Romano Level 7
          crankyuser1
          Stop markers in the Premiere Elements (any version) Blu-ray disc format on Blu-ray disc do not function in the play back of that disc.
          No fixes....unless you export the Timeline to a file saved to the computer hard drive and then import that file for menus and burn to with a 3rd party software.
          As I said this applies to Premiere Elements any version that has a burn to Blu-ray option, including the latest version 12.
          ATR
          • 2. Re: Stop markers in Premier Elements 11
            nealeh Level 5
            Not fixed - they don't recognise it as a problem. Their documentation states that stop markers are for DVD only (regular, not AVCHD).
            Cheers,
            Neale
            If this post or another user's post resolves the original issue, please mark the posts as correct and/or helpful accordingly. This helps other users with similar trouble get answers to their questions quicker. Thanks.
            • 3. Re: Stop markers in Premier Elements 11
              A.T. Romano Level 7
              crankyuser1
              Again, no fix to the Blu-ray Stop Marker business as nealeh has opted to confirm in this thread and in the thread of another in which you posted the same question today.
              The only menu marker perk that you are going to get moving to Premiere Elements 12 in the allowable number of menu markers which is now 99. If you care to read more about the Timeline menu marker count, please see details in my blog post on the subject
              http://www.atr935.blogspot.com/2013/11/pe-menu-marker-limitationimplementation.html
              Please do not hesitate to ask if you need clarification on anything written.
              Thank you.
              ATR
