8 Replies Latest reply on Jan 6, 2014 5:01 PM by photoshopper77
    3d effects won't work
    photoshopper77
      I tried to create a 3d spherical layer by creating a 3d mesh from preset sphere, but I got an error telling me to check "Use Graphics Processor" in Performance Preferences. I checked and already had "Use Graphics Processor" checked. Any suggestions for how to get 3d working?
        • 1. Re: 3d effects won't work
          SG... Adobe Employee
          Can you go to Help> System Info... and paste the text from the resulting window in a reply?
          You may have an older driver, not enough VRAM for the version of Ps you using, or a card configuration that's mucking with things.
          regards,
          steve
          • 2. Re: 3d effects won't work
            photoshopper77 Level 1
            Sure!
            Adobe Photoshop Version: 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00) x32
            Operating System: Windows 7 64-bit
            Version: 6.1 Service Pack 1
            System architecture: Intel CPU Family:6, Model:10, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
            Physical processor count: 2
            Logical processor count: 4
            Processor speed: 1396 MHz
            Built-in memory: 4041 MB
            Free memory: 732 MB
            Memory available to Photoshop: 3255 MB
            Memory used by Photoshop: 60 %
            Image tile size: 128K
            Image cache levels: 4
            Display: 1
            Display Bounds: top=0, left=0, bottom=768, right=1366
            OpenGL Drawing: Enabled.
            OpenGL Allow Old GPUs: Not Detected.
            OpenGL Drawing Mode: Advanced
            OpenGL Allow Normal Mode: True.
            OpenGL Allow Advanced Mode: True.
            NumGPUs=1
            gpu[0].OGLVersion="3.0"
            gpu[0].MemoryMB=1796
            gpu[0].RectTextureSize=8192
            gpu[0].Renderer="Intel(R) HD Graphics Family"
            gpu[0].RendererID=278
            gpu[0].Vendor="Intel"
            gpu[0].VendorID=32902
            gpu[0].HasNPOTSupport=1
            gpu[0].DriverVersion="8.15.10.2509"
            gpu[0].Driver="igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumdx32,igd10umd32,igd10umd32"
            gpu[0].DriverDate="20110831000000.000000-000"
            gpu[0].CompileProgramGLSL=1
            gpu[0].TestFrameBuffer=1
            gpu[0].OCLSupported=0
            gpu[0].CUDASupported=0
            gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30  - Intel Build 8.15.10.2509"
            gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447]
            gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
            gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
            gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
            gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
            gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
            gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[512]
            gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[1024]
            gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[41]
            gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
            gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
            gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
            gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
            gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
            gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
            gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
            gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
            gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
            gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
            gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
            Serial number: Tryout Version
            Application folder: C:\Program Files (x86)\Adobe\Adobe Photoshop CC\
            Temporary file path: C:\Users\asopkin\AppData\Local\Temp\
            Photoshop scratch has async I/O enabled
            Scratch volume(s):
              C:\, 96.9G, 8.48G free
            Required Plug-ins folder: C:\Program Files (x86)\Adobe\Adobe Photoshop CC\Required\Plug-Ins\
            Primary Plug-ins folder: C:\Program Files (x86)\Adobe\Adobe Photoshop CC\Plug-ins\
            Installed components:
               ACE.dll   ACE 2013/07/14-12:09:50   79.543790   79.543790
               adbeape.dll   Adobe APE 2013/02/04-09:52:32   0.1160850   0.1160850
               AdobeLinguistic.dll   Adobe Linguisitc Library   7.0.0
               AdobeOwl.dll   Adobe Owl 2013/03/03-12:10:08   5.0.13   79.533484
               AdobePDFL.dll   PDFL 2013/03/13-12:09:15   79.499517   79.499517
               AdobePIP.dll   Adobe Product Improvement Program   7.0.0.1786
               AdobeXMP.dll   Adobe XMP Core 2013/03/13-12:09:15   79.151481   79.151481
               AdobeXMPFiles.dll   Adobe XMP Files 2013/03/13-12:09:15   79.151481   79.151481
               AdobeXMPScript.dll   Adobe XMP Script 2013/03/13-12:09:15   79.151481   79.151481
               adobe_caps.dll   Adobe CAPS   7,0,0,21
               AGM.dll   AGM 2013/07/14-12:09:50   79.543790   79.543790
               ahclient.dll    AdobeHelp Dynamic Link Library   1,8,0,31
               aif_core.dll   AIF   5.0   79.534508
               aif_ocl.dll   AIF   5.0   79.534508
               aif_ogl.dll   AIF   5.0   79.534508
               amtlib.dll   AMTLib   7.0.0.169 BuildVersion: 7.0; BuildDate: Mon Apr 8 2013 2:31:50)   1.000000
               ARE.dll   ARE 2013/07/14-12:09:50   79.543790   79.543790
               AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
               AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
               Bib.dll   BIB 2013/07/14-12:09:50   79.543790   79.543790
               BIBUtils.dll   BIBUtils 2013/07/14-12:09:50   79.543790   79.543790
               boost_date_time.dll   DVA Product   7.0.0
               boost_signals.dll   DVA Product   7.0.0
               boost_system.dll   DVA Product   7.0.0
               boost_threads.dll   DVA Product   7.0.0
               cg.dll   NVIDIA Cg Runtime   3.0.00007
               cgGL.dll   NVIDIA Cg Runtime   3.0.00007
               CIT.dll   Adobe CIT   2.1.6.30929   2.1.6.30929
               CITThreading.dll   Adobe CITThreading   2.1.6.30929   2.1.6.30929
               CoolType.dll   CoolType 2013/07/14-12:09:50   79.543790   79.543790
               dvaaudiodevice.dll   DVA Product   7.0.0
               dvacore.dll   DVA Product   7.0.0
               dvamarshal.dll   DVA Product   7.0.0
               dvamediatypes.dll   DVA Product   7.0.0
               dvaplayer.dll   DVA Product   7.0.0
               dvatransport.dll   DVA Product   7.0.0
               dvaunittesting.dll   DVA Product   7.0.0
               dynamiclink.dll   DVA Product   7.0.0
               ExtendScript.dll   ExtendScript 2013/03/21-12:10:31   79.535742   79.535742
               FileInfo.dll   Adobe XMP FileInfo 2013/03/19-12:09:02   79.151561   79.151561
               filter_graph.dll   AIF   5.0   79.534508
               icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
               icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
               imslib.dll   IMSLib DLL   7.0.0.116
               JP2KLib.dll   JP2KLib 2013/02/19-12:28:44   79.248139   79.248139
               libeay32.dll   The OpenSSL Toolkit   0.9.8g
               libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
               libiomp5md.dll   Intel(R) OMP Runtime Library   5.0
               libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
               LogSession.dll   LogSession   2.1.2.1785
               mediacoreif.dll   DVA Product   7.0.0
               MPS.dll   MPS 2013/03/15-13:25:52   79.535029   79.535029
               msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
               msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
               msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
               msvcp71.dll   Microsoft® Visual Studio .NET   7.10.3077.0
               msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
               msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
               msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
               msvcr71.dll   Microsoft® Visual Studio .NET   7.10.3052.4
               msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
               msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
               PatchMatch.dll   PatchMatch 2013/06/11-12:08:08   79.542390   79.542390
               pdfsettings.dll   Adobe PDFSettings   1.04
               Photoshop.dll   Adobe Photoshop CC   CC
               Plugin.dll   Adobe Photoshop CC   CC
               PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (32 bit)   4.0.1.34
               PSArt.dll   Adobe Photoshop CC   CC
               PSViews.dll   Adobe Photoshop CC   CC
               SCCore.dll   ScCore 2013/03/21-12:10:31   79.535742   79.535742
               ScriptUIFlex.dll   ScriptUIFlex 2013/03/21-12:10:31   79.535742   79.535742
               shfolder.dll   Microsoft(R) Windows (R) 2000 Operating System   5.50.4027.300
               ssleay32.dll   The OpenSSL Toolkit   0.9.8g
               svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
               tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 1, 2012, 1003
               tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 1, 2012, 1003
               updaternotifications.dll   Adobe Updater Notifications Library   7.0.1.102 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   7.0.1.102
               WRServices.dll   WRServices Mon Feb 25 2013 16:09:10   Build 0.19078   0.19078
            Required plug-ins:
               3D Studio 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Accented Edges 14.1.2
               Adaptive Wide Angle 14.1.2
               Angled Strokes 14.1.2
               Average 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Bas Relief 14.1.2
               BMP 14.1.2
               Camera Raw 8.3
               Camera Raw Filter 8.3
               Chalk & Charcoal 14.1.2
               Charcoal 14.1.2
               Chrome 14.1.2
               Cineon 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Clouds 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Collada 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Color Halftone 14.1.2
               Colored Pencil 14.1.2
               CompuServe GIF 14.1.2
               Conté Crayon 14.1.2
               Craquelure 14.1.2
               Crop and Straighten Photos 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Crop and Straighten Photos Filter 14.1.2
               Crosshatch 14.1.2
               Crystallize 14.1.2
               Cutout 14.1.2
               Dark Strokes 14.1.2
               De-Interlace 14.1.2
               Dicom 14.1.2
               Difference Clouds 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Diffuse Glow 14.1.2
               Displace 14.1.2
               Dry Brush 14.1.2
               Eazel Acquire 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Embed Watermark 4.0
               Entropy 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Extrude 14.1.2
               FastCore Routines 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Fibers 14.1.2
               Film Grain 14.1.2
               Filter Gallery 14.1.2
               Flash 3D 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Fresco 14.1.2
               Glass 14.1.2
               Glowing Edges 14.1.2
               Google Earth 4 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Grain 14.1.2
               Graphic Pen 14.1.2
               Halftone Pattern 14.1.2
               HDRMergeUI 14.1.2
               IFF Format 14.1.2
               Ink Outlines 14.1.2
               JPEG 2000 14.1.2
               Kurtosis 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Lens Blur 14.1.2
               Lens Correction 14.1.2
               Lens Flare 14.1.2
               Liquify 14.1.2
               Matlab Operation 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Maximum 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Mean 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Measurement Core 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Median 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Mezzotint 14.1.2
               Minimum 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               MMXCore Routines 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Mosaic Tiles 14.1.2
               Multiprocessor Support 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Neon Glow 14.1.2
               Note Paper 14.1.2
               NTSC Colors 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Ocean Ripple 14.1.2
               Oil Paint 14.1.2
               OpenEXR 14.1.2
               Paint Daubs 14.1.2
               Palette Knife 14.1.2
               Patchwork 14.1.2
               Paths to Illustrator 14.1.2
               PCX 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Photocopy 14.1.2
               Photoshop 3D Engine 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Photoshop Touch 14.0
               Picture Package Filter 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Pinch 14.1.2
               Pixar 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Plaster 14.1.2
               Plastic Wrap 14.1.2
               PNG 14.1.2
               Pointillize 14.1.2
               Polar Coordinates 14.1.2
               Portable Bit Map 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Poster Edges 14.1.2
               Radial Blur 14.1.2
               Radiance 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Range 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Read Watermark 4.0
               Reticulation 14.1.2
               Ripple 14.1.2
               Rough Pastels 14.1.2
               Save for Web 14.1.2
               ScriptingSupport 14.1.2
               Shake Reduction 14.1.2
               Shear 14.1.2
               Skewness 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Smart Blur 14.1.2
               Smudge Stick 14.1.2
               Solarize 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Spatter 14.1.2
               Spherize 14.1.2
               Sponge 14.1.2
               Sprayed Strokes 14.1.2
               Stained Glass 14.1.2
               Stamp 14.1.2
               Standard Deviation 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               STL 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Sumi-e 14.1.2
               Summation 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Targa 14.1.2
               Texturizer 14.1.2
               Tiles 14.1.2
               Torn Edges 14.1.2
               Twirl 14.1.2
               Underpainting 14.1.2
               Vanishing Point 14.1.2
               Variance 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Variations 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Water Paper 14.1.2
               Watercolor 14.1.2
               Wave 14.1.2
               Wavefront|OBJ 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               WIA Support 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               Wind 14.1.2
               Wireless Bitmap 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00)
               ZigZag 14.1.2
            Optional and third party plug-ins: NONE
            Plug-ins that failed to load: NONE
            Flash: NONE
            Installed TWAIN devices: NONE
            • 3. Re: 3d effects won't work
              Level 7
              Your video card driver is over 2 years out of date (and Intel has fixed a lot of bugs since then).
              Go to Intel's website and update the driver software.
              • 4. Re: 3d effects won't work
                Thanks for the info. Are you intentionally wanting to launch the 32-bit version of Ps? Can you try launching the 64-bit to see if it makes any difference? Look for the application here: Application folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Photoshop.exe
                The driver for your Intel HD is a bit old as well. You may want to see if a newer version is available for your machine:
                https://downloadcenter.intel.com/Default.aspx?lang=eng
                regards,
                steve
                • 5. Re: 3d effects won't work
                  Thanks! I tried using the 64 bit edition and updating the driver and still can't seem to access lighting effects. here is the updated system info:
                  Adobe Photoshop Version: 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00) x64
                  Free memory: 547 MB
                  Memory available to Photoshop: 3405 MB
                  Display: 1
                  NumGPUs=1
                  gpu[0].Renderer="Intel(R) HD Graphics 3000"
                  gpu[0].DriverVersion="9.17.10.3347"
                  gpu[0].Driver="igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32"
                  gpu[0].DriverDate="20131031000000.000000-000"
                  gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Intel Build 9.17.10.3347"
                  Scratch volume(s):
                    C:\, 96.9G, 7.23G free
                  Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Required\Plug-Ins\
                  Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Plug-ins\
                     amtlib.dll   AMTLib (64 Bit)   7.0.0.169 BuildVersion: 7.0; BuildDate: Mon Apr 8 2013 2:31:50)   1.000000
                  PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 4.0.1.34
                  Required plug-ins:
                     3D Studio 14.1.2 (14.1.2 x001)
                     Average 14.1.2 (14.1.2 x001)
                     Bas Relief 14.1.2
                     BMP 14.1.2
                     Camera Raw 8.3
                     Charcoal 14.1.2
                     Chrome 14.1.2
                     Cineon 14.1.2 (14.1.2 x001)
                     Clouds 14.1.2 (14.1.2 x001)
                     Collada 14.1.2 (14.1.2 x001)
                     Conté Crayon 14.1.2
                     Craquelure 14.1.2
                     Crop and Straighten Photos 14.1.2 (14.1.2 x001)
                     Crosshatch 14.1.2
                     Crystallize 14.1.2
                     Cutout 14.1.2
                     Dark Strokes 14.1.2
                     De-Interlace 14.1.2
                     Dicom 14.1.2
                     Difference Clouds 14.1.2 (14.1.2 x001)
                     Diffuse Glow 14.1.2
                     Displace 14.1.2
                     Dry Brush 14.1.2
                     Eazel Acquire 14.1.2 (14.1.2 x001)
                     Embed Watermark 4.0
                     Entropy 14.1.2 (14.1.2 x001)
                     Extrude 14.1.2
                     FastCore Routines 14.1.2 (14.1.2 x001)
                     Fibers 14.1.2
                     Film Grain 14.1.2
                     Flash 3D 14.1.2 (14.1.2 x001)
                     Fresco 14.1.2
                     Glass 14.1.2
                     Google Earth 4 14.1.2 (14.1.2 x001)
                     Grain 14.1.2
                     Graphic Pen 14.1.2
                     HDRMergeUI 14.1.2
                     IFF Format 14.1.2
                     Ink Outlines 14.1.2
                     JPEG 2000 14.1.2
                     Kurtosis 14.1.2 (14.1.2 x001)
                     Lens Blur 14.1.2
                     Lens Flare 14.1.2
                     Liquify 14.1.2
                     Matlab Operation 14.1.2 (14.1.2 x001)
                     Maximum 14.1.2 (14.1.2 x001)
                     Mean 14.1.2 (14.1.2 x001)
                     Measurement Core 14.1.2 (14.1.2 x001)
                     Median 14.1.2 (14.1.2 x001)
                     Mezzotint 14.1.2
                     Minimum 14.1.2 (14.1.2 x001)
                     MMXCore Routines 14.1.2 (14.1.2 x001)
                     Mosaic Tiles 14.1.2
                     Multiprocessor Support 14.1.2 (14.1.2 x001)
                     Neon Glow 14.1.2
                     Note Paper 14.1.2
                     NTSC Colors 14.1.2 (14.1.2 x001)
                     Ocean Ripple 14.1.2
                     Oil Paint 14.1.2
                     OpenEXR 14.1.2
                     Paint Daubs 14.1.2
                     Patchwork 14.1.2
                     PCX 14.1.2 (14.1.2 x001)
                     Photocopy 14.1.2
                     Photoshop 3D Engine 14.1.2 (14.1.2 x001)
                     Picture Package Filter 14.1.2 (14.1.2 x001)
                     Pinch 14.1.2
                     Pixar 14.1.2 (14.1.2 x001)
                     Plaster 14.1.2
                     Plastic Wrap 14.1.2
                     PNG 14.1.2
                     Pointillize 14.1.2
                     Portable Bit Map 14.1.2 (14.1.2 x001)
                     Poster Edges 14.1.2
                     Radial Blur 14.1.2
                     Radiance 14.1.2 (14.1.2 x001)
                     Range 14.1.2 (14.1.2 x001)
                     Read Watermark 4.0
                     Reticulation 14.1.2
                     Ripple 14.1.2
                     Save for Web 14.1.2
                     Shear 14.1.2
                     Skewness 14.1.2 (14.1.2 x001)
                     Smart Blur 14.1.2
                     Smudge Stick 14.1.2
                     Solarize 14.1.2 (14.1.2 x001)
                     Spatter 14.1.2
                     Spherize 14.1.2
                     Sponge 14.1.2
                     Stamp 14.1.2
                     Standard Deviation 14.1.2 (14.1.2 x001)
                     STL 14.1.2 (14.1.2 x001)
                     Sumi-e 14.1.2
                     Summation 14.1.2 (14.1.2 x001)
                     Targa 14.1.2
                     Texturizer 14.1.2
                     Tiles 14.1.2
                     Torn Edges 14.1.2
                     Twirl 14.1.2
                     Variance 14.1.2 (14.1.2 x001)
                     Variations 14.1.2 (14.1.2 x001)
                     Water Paper 14.1.2
                     Watercolor 14.1.2
                     Wave 14.1.2
                     Wavefront|OBJ 14.1.2 (14.1.2 x001)
                     WIA Support 14.1.2 (14.1.2 x001)
                     Wind 14.1.2
                     Wireless Bitmap 14.1.2 (14.1.2 x001)
                     ZigZag 14.1.2
                  Flash:
                     Adobe Exchange
                     Kuler
                  • 6. Re: 3d effects won't work
                    Level 7
                    Can you use the rest of the 3D code other than Lighting Effects?
                    And is your document in 8 bit/channel RGB for Lighting Effects?
                    P.S. [jinx]
                    • 7. Re: 3d effects won't work
                      Curious. Were you able to successfully create a 3D layer using the sphere preset?
                      Can you post the message when trying to go to the Lighting Effects dialog? You are using an RGB 8 bit document?
                      regards,
                      steve
                      • 8. Re: 3d effects won't work
                        I can create a 3d layer, however, lighting effects will not work. I don't get an error message--I can't even push the Lighting Effects button. (It appears in gray while the other render effects appear in black). Any ideas?
