6 Replies Latest reply on Jan 6, 2014 3:45 PM by tonebone
    in element 3.0.2
    tonebone
      in element 3.0.2 having trouble with rendering-after rendering it goes into a avi. file with many clips and no audio.
      what could i be doing wrong? i added neat video to help clean up the video noise. also, are you suppose to take the many
      clips and put them back into the edit mode to be able to make your dvd?
        • 1. Re: in element 3.0.2
          It depends on what you're using for source video. What model of camcorder is your video coming from and what format and resolution is it?
          Version 3 is a very early version of the program, and there is pretty much only support for tape-based miniDV and HDv camcorder video. AVCHD and smartphone video was pretty much unheard of then.
          So if you're using video from something other than a tape-based digital camcorder, it's probably not going to work well.
          • 2. Re: in element 3.0.2
            tonebone Level 1
            thanks, i captured my video from an old vhs tape a non-prerecorded material, it captured and i can see it in the timeline, etc., and i have been able to edit, but again, problems with rendering.  the neat video software appears to work great in the non-rendering mode.  and, before rendering the video has a skipping movement in preview.  do i have the wrong software for this project?
            • 3. Re: in element 3.0.2
              What device did you use to capture it and what codec did it use to capture the video?
              Open one of the clips in G Spot or Media Info and report the resolution, frame rate and audio and video codecs it displays.
              As I've said, version 3 is not terribly versatile. So unless your digitizer was an ADS Pyro or Canopus AVDC capturing over a FireWire connection, it did not likely capture it in a format Premiere Elemetns 3 can work with.
              • 4. Re: in element 3.0.2
                tonebone Level 1
                i capture the video thru a usb device in it's software, then transfered/captured to version 3, and i believe at dv format.  as you can see i am a full rookie at this whole thing.  before doing any editing especially with neat video, everything looked good as far as being able to see the original video.  i went to neat video to get rid of the video noise that a vhs tape would produce.  this is a very important video and i would like to be able to clean it up and product the best video as much as possible.  thanks
                • 5. Re: in element 3.0.2
                  Please read below, and reply with a screen shot of what is inside your file
                  Codec & Format information, with 2 links inside to read -read both links in reply #1 http://forums.adobe.com/thread/1270588
                  Report back with the codec details of your file, use the programs below... A screen shot works well to SHOW people what you are doing
                  http://forums.adobe.com/thread/592070?tstart=30 for screen shot instructions
                  For PC http://mediainfo.sourceforge.net/en or http://www.headbands.com/gspot/
                  For Mac http://mediainspector.massanti.com/
                  • 6. Re: in element 3.0.2
                    tonebone Level 1
                    thanks,
                    i will not be able to try suggestings until later on this evening.
