1 Reply Latest reply on Jan 7, 2014 7:00 AM by Jeff_Coatsworth
    RH10: Help compiles without any an error. Preview never loads?
    mikejmoon
      I click 'index' and a tab opens - but I never see anything but a blank page and a 'flickering' icon on the tab. Why? How to troubleshoot? Here's the result of the compile:
      Starting compilation...
      WebHelp preprocessor 10.0.0.287
      Clearing output folder...
      Compiling I:\My Documents\Falcon\online help\onyx help\!SSL!\Onyx_Webhelp\Index.htm ...
      Preparing to create WebHelp...
      Preparing files for WebHelp...
      Copying files...
      Updating files...
      Finished preparing in 18 sec(s)
      Initializing compiler...
      Generating WebHelp 5.50 (10.0.0.287)...
      Processing TOC data...
      Processing Index data...
      Processing Glossary data...
      Processing Context-sensitive-Help data...
      Updating HTML topics...
      Updating About.htm...
      Updating Assay_Class_Selector_List.htm...
      Updating BarCodeScan_Btn.htm...
      Updating Build_and_Save_a_Test_Panel.htm...
      Updating Cancel_btn.htm...
      Updating Clear_Btn.htm...
      Updating Clear_Pos_btn.htm...
      Updating Container_Type.htm...
      Updating Date_Selection_Box.htm...
      Updating Days_left_on_board.htm...
      Updating Delete_Test_Panel_Popup.htm...
      Updating Done_btn.htm...
      Updating Enter_Manual_Code_btn.htm...
      Updating Error_Messages.htm...
      Updating Instrument_Pre_Run_Checklist.htm...
      Updating Introduction.htm...
      Updating Liquid_Type.htm...
      Updating Load_Reagents,_Beads,_Wash_and_Others1.htm...
      Updating Load_Samples_and_Link_Samples_to_Tests.htm...
      Updating Lot_Expiration_Date.htm...
      Updating Lot_Number.htm...
      Updating Maintenance.htm...
      Updating Manufacturer.htm...
      Updating Measured_Volume.htm...
      Updating New_Topic.htm...
      Updating On_Board_Date.htm...
      Updating Position_Number.htm...
      Updating Pre_Run_Checklist.htm...
      Updating QC_Calibration.htm...
      Updating QC_Control.htm...
      Updating Quality_Control_Filter.htm...
      Updating quickstart.htm...
      Updating ReadFile_btn.htm...
      Updating Reagent_Beads.htm...
      Updating Reagent_Grid.htm...
      Updating Reagent_Info_for_Position_Number.htm...
      Updating Reagent_Name.htm...
      Updating Reagent_Positions.htm...
      Updating Reagent_Rotor_Graphic.htm...
      Updating Remaining_Tests.htm...
      Updating Remaining_Volume.htm...
      Updating Remove_Tests.htm...
      Updating Reports_Print_Automatically.htm...
      Updating Reports_Results.htm...
      Updating Reports_Search.htm...
      Updating Run_Error.htm...
      Updating Run_Legend.htm...
      Updating Run_Main.htm...
      Updating Run_Schedule.htm...
      Updating Run_Selected_Sample.htm...
      Updating Sample_Detail_Screen.htm...
      Updating Sample_Grid.htm...
      Updating Sample_ID.htm...
      Updating Sample_Position_Screen.htm...
      Updating Serial_Number.htm...
      Updating Servic_eComm_Log.htm...
      Updating Service_Align.htm...
      Updating Service_Cuvettes.htm...
      Updating Service_Maintenance_Clean_System.htm...
      Updating Service_Motors.htm...
      Updating Service_Sensors.htm...
      Updating Settings_Database.htm...
      Updating Settings_Operators.htm...
      Updating Settings_System.htm...
      Updating Settings_System_Setup.htm...
      Updating Status.htm...
      Updating Test_Panel_Drop_Down_Selector_List.htm...
      Updating Test_Panel_Popup_Form.htm...
      Updating Test_Planning.htm...
      Updating Test_Type.htm...
      Updating Use_Run_to_Check_for_Errors.htm...
      Updating User_Input.htm...
      Finished updating HTML topics in 6 sec(s) : total 72 topic(s).
      Processing Full-text-search data...
      Finished processing Full-Text-Search data in 4 sec(s)
      Applying WebHelp 5.50 Template...
      Finished applying Template in 6 sec(s)
      Finished compiling WebHelp in 43 sec(s)
      Compilation complete.
