1 Reply Latest reply on Dec 6, 2007 3:28 PM by Newsgroup_User
    Flash 6 legacy use of _root
    Level 7
      I use Flash about twice a year, so I really only have half a clue...
      I have an old Flash 6 app that I want to reuse as part of a new project. It
      uses _root extensively. Soooo I toldya I only have half a clue :-(
      Anyway, I am trying to load it into a movieclip on screen:-
      myMovie = "mySwf.swf";
      This works just fine :-)
      Now, here's the thing. The file was built and published as Flash 6, and
      works fine on its own. But once I import it into a new Flash file, it stops
      working - specifically there is some XML parsing code used to dynamically
      create a menu that is failing.
      Among other things I've tried matching Flash publish versions - so make sure
      both old file and container are published as Flash 6, for instance. No Joy.
      So I tried publishing the old file as Flash 7 (and 8, 9), and it stopped
      working as standalone, and still didn't work in the container. I tried
      ActionScript 1 and 2 (either is fine as Flash 6) still no joy.
      Anyway - rather than bore you further, is there a good article anywhere that
      helps to troubleshoot and fix idiot use of _root?
      Oh, I should add that I have experimented with lockRoot too, with only
      limited success.
